Question about Canon CanoScan CS8800F Flatbed Scanner
Scanner is placing a thin line across the scanned image. How do I prevent that from happening? The line makes the scanner useless for preserving images.
  • Canon Master
  • 1,679 Answers
Clean the Glass with cloth. It should Fix the problem
Regards,
Ron
Posted on Mar 11, 2011
During scanning I am hearning a knocking sounds and after the carriage finishes it's path ; th screen show half image
Knocking -- whether it comes from an automobile or a finely tuned scanner -- never good.
It sounds like an obstruction is preventing the scanner from moving fully across.
You can test this by repeating the scan but keeping the lid up. Please don't look directly at the bright light... but see if you can observe the movement from watching the edge of the path.
Other than that... see if you can make the scanner completely level.
It could be as simple as replacing a belt that is slipping, but you might call HP if this scanner is very new.... you might be eligible for a warranty replacement.
Sep 25, 2010 | HP Scanjet G2410 Flatbed Scanner
Why do I have a black line down the side of my scanned documents?
If you are using the ADF (Automatic Document Feeder) there is likely debris in that section of the scanning glass. The ADF parks the scanner in place and moves the paper over it, if something is on the scanner it will show up as a line. Check the thin section of glass at whichever end of the scanning deck for dust and clean it with a dry towel. If this is happening with documents on the scanner bed the debris is likely in the scanner and will likely need professional servicing.
Jun 09, 2010 | Office Equipment & Supplies
Black line on image
It's possible that the black lines you're experiencing are an internal image adjustment issue with the scanner itself. If the scanner glass is otherwise clean, try going to the Canon DR2050/2080 utilities installed as part of the set up of your scanner and running the Adjustment Tool - it asks you to place the "adjustment paper" in the scanner. The term, "adjustment paper," appears to mean anything which has an image or text on it. Be sure you clean the scanner first before running this utility. It will have you put the "adjustment paper" through twice, and that in turn should remove the black lines in your scans, as long as there is no dust on the scanner glass. Office Depot sells cleaner sheets for laser and inkjet printers which also work on faxes and scanners and which will clean the glass for you.
Nov 08, 2009 | Canon DR-2050C Path-Through Scanner
White lines across my scanned images
I had the exact same problem! the problem seems to be with the CCD calibrating itself before it starts to scan.
If you look into the scanner, the scanner glass extends itself into the casing of scanner where the CCD rests. Every time before the scan starts the CCD starts to calibrate itself in its housing before it starts to scan. If there is any reminiscence of dust or anything object (like a piece of paper) stuck in the edges where the CCD rest, the white balancing is thrown off and it causes white lines to appear along the entire line where the dust was present.
Ideally the solution would be to open the scanner casing to clean the housing where the scanner CCD rest. This would solve the problem.
If you are unable to open the scanner casing, then try using a piece of paper or a thin edge of a cloth, slightly dampened to reach into the edge of the scanner glass where the CDD rests and clean it. This is what i did and this solved the problem.
Jul 09, 2009 | HP PhotoSmart C4385 All-in-One Printer
Vertical line is appear when make scanning from document feeder .. thanks
The glass the document is dragged across has an ink mark or liquid paper mark on it.
Clean thin document glass under the feeder.
Apr 27, 2009 | Ricoh IS420 Flatbed Scanner
Picture sizing from scanner
in photoshop or a imaging software, you open the picture, and go to image size, then chose your target size with the "preserve scale" option
Nov 22, 2008 | Epson Perfection 4490 Office Flatbed...
Facing copying problem from scanning section
Although you didn't specify the scanner model, this solution should work.
If the scanner has a top feeder, open it.
You will see a thin strip of glass, either to the left, or right of the large scanner glass.
There is most likely a small spec of ink, white out, etc on it.
Clean the strip glass with rubbing alcohol and the line should go away.
Apr 09, 2008 | Office Equipment & Supplies
DR-5010C scanner yellow line
First clean the glass thoroughly using IPA (Iso Propyl Alcohol) Dont use any solvents. If you are getting the same result even after this, there could be a module problem.
S. Mohan
Mar 31, 2008 | Canon DR-5010C Path-Through Scanner
Canoscan 9950f red line on scan
Try running a calibration. This is done thorugh ScanGear in Advanced mode. Once in Advanced Mode, in the Image Settings section there should be an option for Calibration (you may have to scroll down in this section to see it). After running the calibration, try performing a preview scan with nothing on the scanner glass. If the red line shows up on the preview now, then most likely the scanner needs to be serviced.
Mar 12, 2008 | Canon CanoScan 9950F Flatbed Scanner
Black area above the scanned image.
If you set Automatic brightness/Contrast this happens. Try manual setting. Adjust different settings and select the best suited for a particular type of drawing. The scanner takes couple of milliseconds to judge the best lighting, by then the paper has moved little. This area appears black. This is easily solvable.
S. Mohan, Chennai, India
Dec 06, 2007 | Canon DR-9080C Path-Through Scanner
Canon CanoScan CS8800F Flatbed Scanner Logo
124 people viewed this question
old marine
old marine
