Question about ASUS EN9600GSO TOP/HTDP(384M) (384 MB) PCI Express Video Card
Asus en9600gso 512 mb. pci -e I just got this from a friends system where it was working just fine. It worked for 30 minutes and then overheated to the point that I had to remove it. this was my 1st pci-e card .....I did attachd teh power cable marked pci-1 from the power supply . I have it removed now. what could be teh problem? My current setup is Giga micro mobo with 450 power supply. in a mid tower and no other fancy items attached.
4 Suggested Answers
ButtFuzz
  • 463 Answers
SOURCE: hang problem
If MB has on-board video, too, make sure it is turned off and not just on "auto". Make sure that the amount of shared RAM (if MB uses this 'feature') is set to 'disabled' or "0", even if on-board video controller is turned 'off. If this is AGP controller, make sure bios setting of AGP multiplier matches that of Video Adapter. Remove drivers for old(er) video card if you have not done so already. Did you go to Windows update and accept an updated version of the driver for said card? Roll it back... Don't overclock RAM, BUS, Video System, etc. Remove overclock software from machine. Go to MFG website and download their latest driver and install.
Posted on Sep 27, 2007
xptareq2000
  • 1447 Answers
SOURCE: My Asus EN7200 GS stoped working, lines appeared in my monitor
you must be reset your bios put on jumper coms clear choice 2-3 then reset configure position again 1-2 then computer is ready activate built in agp
Thanks
Posted on Nov 22, 2009
  • 43 Answers
SOURCE: my graphic card asus EAH3450
Hi!
I think your GPU is overheating and that causes the problem. Download GPU-Z and install it. Start up your game and then pause it, Alt + Tab back to Windows, start GPU-Z > Sensors and check the temperatures. If it`s above 70-80 C you have a problem so you have to upgrade your cooling system. Try to install as many case fans as you can(side coolers>sucking the air in, back side coolers>blowing it out). If that doesn`t help you`ll have to buy a bigger cooler for your GPU.
Good luck
Posted on Mar 16, 2011
Why won't my ATI HD5450 work on my ASUS P5LP-LE mb?
Are you sure that the 5450 works? Try it on another PC, if it does work fine on another system then it could mean that the PCI Express slot on your ASUS board could be faulty. Uninstalling the on-board drivers won't make a difference.
Dec 15, 2011 | Computers & Internet
Ge force 9500gt, 512mb, ddr2 compatible with asus a7n8x deluxe
The ASUS A7N8X only supports AGP8X, the 9500GT is PCI Express. There is no way the 9500GT will work with this board.
Dec 12, 2011 | ASUS NVIDIA GeForce 9500GT, (512 MB) PCI...
Hi i have en210 512 ddr2 card i install the card but soundcard cannot work
I'm assuming you have the card installed properly, have run your installation cd and, as you're good as far as video. I don't know what system you have and there appears to be support for Win XP, Vista, and Windows 7 through Asus. This particular card does not provide sound. You will have to use on board sound or, get a sound card. It is a low profile card so, you may be able to install a sound card in your PCIe slot(internal) if you have room or, you could go with a USB sound card(external).
Apr 20, 2011 | ASUS GeForce 210 Silent - 512 MB GDDR3 -...
Thanks
Nov 22, 2009 | ASUS EN7200GS/HTD/256M-256MB PCI-E DDR...
Games are not working Properly, Video is lagging
try putting nvidia 9800 video card, that shoud solve your problem.. and check the game requirements if it runs on 512 or 1gig.. tnx tell me if goes well..
Dec 13, 2008 | ASUS motherboard P5S-MX SE LGA775 SiS671FX...
Not able to install RAM > 512 MB
Try to run a system repair.
Jul 14, 2008 | ASUS K8S-MX Motherboard
Installed GeForce 8500 GT PCI-E video card and pc will not turn on
If your mboard has a builtin video card you should configure that b4 u can use that add on card.
1. connect the add on card.
2. connect the monitor to the built in VGA.
3. start system and press "F2 or Delete" to go to bios setup.
4. on bios setup " refer to the manual on installing addon PCI express card".
you find it here: http://support.asus.com/download/download.aspx?SLanguage=en-us.
or enlosed in the board.
After configuring your system restart and unplug in the wall outlet and then connect the monitor in the add on card.
Hope you find in order.
Jan 18, 2008 | ASUS P5GD1-VM Motherboard
Video card
Hi Yosemic..
Bad news for you... your computer don't have an AGP or PCI-e slot, so a video card upgrade is possible, but no recommended cause you will have to buy a PCI VGA (very slow).
Your computer only have 3 PCI slots as you can see at this link
http://support.dell.com/support/edocs/systems/dim2400/en/sm_en/specs.htm
Better buy a new one..
Regards
Dec 21, 2007 | Dell Dimension 2400 PC Desktop
ASUS EN9600GSO TOP/HTDP(384M) (384 MB) PCI Express Video Card Logo
Top ASUS Computers & Internet Experts
David
David
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
