Question about Andis AGC2 Hair Trimmer
I have an andis agc 2 super pet clipper which has just been serviced. on its return the area where the blade fits looks wrong. the black metal which i think is called the blade lock latch which you push up to release the blade, hangs down from underneath the silver metal tonge on which the blade is fitted, if you push it up it just returns. i was sure it used to be tight under the silver part when no blade was fitted and the top of the black metal part touched the black plastic part. can you tell me if i am right or wrong.
  • 193 Answers
Actually this all sounds ok the hinge has two springs which will push the Latch down.
Posted on Aug 22, 2011
Blade not staying on tight
If you can pull the blade away from the clipper without pressing the blade release button then either the hook on the Latch is broken (which will mean all blades have the same problem) or the blade socket on the blade may need adjustment or replacement. Please view the part in question Latch
Mar 12, 2014 | Andis Agc Super 2-speed Clipper...
Moser max 45 won't cut
Most common cause will be the blades have gone dull and should be sharpened or replaced. Check that the 2 screws on the blade latch assy are tight where it screws onto the front housing, blade off to check them. 3rd thing to check is for excessive wear in the lever that drives the blades, if it is worn replace it.
Sep 15, 2013 | Andis Agc Super 2-speed Clipper...
Andis Clippers not locking
Make sure you are putting the blades on with the clippers running otherwise the blade will not locate correctly. Failing that it could b e a broken 'latch' AGC
May 01, 2013 | Andis Dog Clippers - AGP Super 2-Speed...
Problems Andis AGC 2
Sounds like it's time to replace the clippers with something much better.
Apr 24, 2013 | Andis Agc Super 2-speed Clipper...
Why is clipper over heating
Either your blades need cleaning and oiling or it's possibly a faulty armature without testing the clippers and part mentioned with a multimeter it's hard to say. Armature
Apr 01, 2013 | Andis Agc Super 2-speed Clipper...
My clipper smoked and now it wont run at all
Sounds like your motor went out. You might as well buy new clippers for the price to fix them. One thing that causes that is when you spray your coolant to not hold your clippers blade up. Keep them blade down. The coolant can run into your clippers and burn them up. You only want to use grease inside your clippers.
Jan 21, 2013 | Andis Agc Super 2-speed Clipper...
Andis clippers are shaking and loud
sometimes it is the blade and not the clipper
Jun 20, 2012 | Andis Agc Super 2-speed Clipper...
CisfI bought an Andis Pet clipper AGC 2 speed. Have 2 blades - 7FC and 10FC. have lost directions on how to change the blades - can you send me directions so I can print them?
With the clipper running, grasp the blade set by the edges and flip it down away from the clipper on its hinge. Simply slide it forward off the tang and slide another blade while the clipper is running. Snap it up toward the clipper and you're set.
Apr 10, 2011 | Andis Health & Beauty
Andis super Agr+ / Andis Agc super maintenance
There is little needed most componets such as the motor and carbon brushes are fairly complicated and should be checked when the units are serviced.
Keep an eye on the Blade Drive Assembly as with most clippers they wear on the sides causing cutting problems such as lines in cut fur and snagging blades, alternatively send them, to our Clipper Repair department.
Mar 01, 2010 | Andis AGC Super 22360 Hair Trimmer
Andis Super 2 Speed AGC Clippers - The blades get very hot !
Buy some Kool Lube (Oster) or Andis Blade Coolant. Both are aerosols. Your 2-speed runs faster, so your blades heat up quicker. Check them often by touching them to your inner wrist, and spray them when they are hot. A bonus is that the sprays also disinfect! (FYI a hot blade can badly burn a pet, so make sure you keep them cool)
Apr 09, 2009 | Andis 29745 Clipper Headliner Hair Trimmer
Andis AGC2 Hair Trimmer Logo
146 people viewed this question
Top Andis Health & Beauty Experts
Anglia Clipper...
shaveroutlet.com
shaveroutlet.com
Kolbrun...
Are you an Andis Health and Beauty Expert? Answer questions, earn points and help others
