Question about Watches
Can't get lock icon off health smart watch/pedometer. Don't know which button to push.
Watch Problems
PROVIDE US HERE THE WATCH MODEL..
AND ALSO PROVIDE A DETAILED PICTURE IF POSSIBLE...
Sep 17, 2008 | Watches
Aspen watch
this should work with your aspen watch let me know if it doesn't
http://dive.scubadiving.com/members/gearreviews.php?s=593
Quote
For the alarm: If you want to use it (I think both it and the light use battery faster than when not used), you set it by pushing mode button twice, as indicated above, then go to hour or minute setting by pushing the lap/reset button, and advance to the time you want by pressing the start/stop button. Pushing mode will take you back to normal time again.
To turn alarm on or off, hold lap/reset button in and at the same time push the start/stop button. Alarm icon will show on or off. When you release the lap/reset button, it will revert to normal time.
If the alarm is on, at the designated time it will start beeping for awhile or until the lap/reset button is pushed (off) or start/stop button (snooze).
Aug 08, 2008 | JCPenney Armitron Sport Link Bracelet...
Skmei # 1058 Pedometer watch - I didn't receive an instruction manual with my watch. I need some instruction to help set the watch...
Hi Keith
The guy in this video finds a paper manual in his package.
You can probably freeze frame it and take a screen snapshot of th manual. Cmd Shift 4 on a Mac places the screenshot photo on the Desktop
Good Luck SKMEI 1058 Waterproof Pedometer Heart Rate Wrist Watch
pedometer how to use YouTube
Mar 14, 2016 | Watches
How do I display multiple lap times? I push the lap button and get the first lap time but I don't know how to see the subsequent laps.
From Timex: You cannot recall the laps on the expedition watch. You can only view the last lap run and the split time.
Aug 28, 2011 | Timex Expedition C45981 watch
I dont know how to adjust the time in nike led watches
My Nike LED watch has 4 buttons on it--two on each side. The two buttons on the left light up the screen, but don't do anything of note. The two pushers on the right side do all the work.
To adjust the time on your watch, push the top right button to illuminate the time. Then, while the time is displayed, push the lower right button. You need to give it a good push--a bit longer than just to light up the time. The hour digit should start flashing. Use the top right button to advance the hour to where you'd like it to be, then push the lower right button to switch to setting the minutes. Pushing he lower right button again will advance you through the opportunity to adjust the month, date, and year. When you've cycled all the way through and can see the time again, push on the top right hand button to restart the timekeeping function, and you should be good to go.
Jun 14, 2011 | Watches
My watch keeps beeping, can i turn it off?
Yes, you can. Go to the settings mode, push the pushbutton till you see the blinking bell icon. Repeat to push the button till the icon disappear.
Rate me, please.
Jul 31, 2009 | Watches
My watch beeps every hour.
Yes, you can. Go to the settings mode, push the pushbutton till you see the small blinking icon. Repeat to push the button till the icon disappears.
Rate me, please.
Jul 30, 2009 | Watches
How do i reset my timex ironman
There are only 4 buttons. One of them will put you into "reset" mode, but which one? Before you guess, here is the trick: you have to hold it for a couple of seconds (you don't want it resetting accidently, right?) Ok, so start with your 1st guess (ok, pick top left) did the display give you any clue that was the lucky button? (ok, the display --the seconds, will not increment, but instead will just flash the same number) You are over the hurdle...if not try another one of those 4 buttons. Once you get the seconds to flash, you now have to somehoe reset whatevaitwas you needed to reset. Which means you need to pick another button...such fun! Pick the bottom right one and look for the hour display to flash (if the light comes on, this is the wrong button...you know that) and once it does you have found the "mode" for resetting the hour. So only a couple of buttons left: pick one to see if it increments the flashing hour hand (if the light comes on...you know what to do) and push it till you like the hour number. Then push the first button that started you on resetting this thingie to let the watch know you are done messin with it.
Now you are set to fix your daughter's watch...or your grand-daughter's watch...You B so smart now...you can fix anything!
Jul 03, 2008 | Timex Watches
Watches Logo
Top Watches Experts
Ansel Alberto
Ansel Alberto
Are you a Watch Expert? Answer questions, earn points and help others
