Question about Toshiba Televison & Video
I have a thosiba dlp and all ready change the lamp, but it has no image and it turn off,and turn on by itself what could be problem?
  • 1,476 Answers
Ghryz_la_usa,
See my tip at
http://www.fixya.com/support/r7807925-ballast_diagnosis_replacement_in_lcd
which could help solve your problem.
Thanks for using FixYa and for the great rating.
hardrocko
Posted on Mar 11, 2011
The picture is not bright in a light-filled room. Will a change of DLP lamp help? Are there different lamps that will improve picture quality?
Yes.Depend how old is ur DLP tv,the Projection Lamp only a light source,mostly depended on the Light projection Engine itself.Get the original RCA DLP lamp or same lamp model now inside the tv,will help and work best for ur tv.Just don't get generic DLP tvs lamp,it cheaper poorer quality.
Dec 17, 2010 | RCA HD61LPW167 61" HDTV
I replaced the lamp on my Samsung HLS5086WX/XAA DLP set. How do I reset the timer on the lamp?
I have a Samsung DLP HLN617WX/XAA. After turning off by itself, the three indicator lights were blinking... signifying a defective lamp. I've re-seated the old lamp several times with no change. I bought a new lamp and reset the lamp hours through the "service menu" with no change. My television is still turning itself off and still blinking the same indicator lights. What should I look at, next?
Oct 26, 2010 | Samsung Televison & Video
Changed lamp in 61 inch jvc dlp and still can't get tv to turn on
Ballast board is what turns Lamp on and CK your Fans if Lamp Fan is defective TV willnot come on.
Dec 11, 2009 | JVC HD-61Z575 61" Rear Projection...
I replaced the lamp in my dlp tv .It turns on for about 5-10 seconds then the lamp turns off and the bulb signal light flashes res
Check to make sure that the lamp housing is fully seated in the compartment, and that the door is properly closed and secured. There's a microswitch on the lamp access door that will shut the lamp off if the door isn't in place properly. That switch itself can be bad and can cause your problem.
Good luck.
Nov 28, 2009 | LG RU-52SZ51D 52" Rear Projection...
I have had this Samsung DLP HL-P 4663W for about 3 years now.
    1. Ensure that the TV is off. It may be advisable to unplug the TV as well.
    2. 2 Using a Phillips screwdriver, remove the single screw affixing the lamp cover (the small, grill panel on the back of the set) to the chasis. There is also a grill that is held in place by tension. Just "pinch" the thumb clamp on the bottom of the grill and slide it out. This is the same procedure you would perform to change the lamp, except in this case you will not need to remove the lamp itself.
    3. 3 Inspect the spring-loaded blue safety switch to ensure it is making good contact when the panel is secured. The switch should deflect downward when the panel is replaced. If the contact with the panel is suspect, very gently bend the metal bracket on which the switch is mounted.
    4. 4 Replace the grill cover and the lamp door, and continue to enjoy your TV.
    jQuery('.article ol .image').each(function(i,e){ var $this = jQuery(this); $this.find('img').error(function(){ jQuery(this).remove(); $this.remove(); }); });
  • 5.Check some basics first. Make sure the sleep timer on your TV hasn't been turned on, telling your set to turn off at a certain time. If your DLP TV is acting erratically, Samsung recommends turning the set off and unplugging it for 30 minutes. After 30 minutes plug it back in and turn it back on. Unplugging the set resets it, and that may fix the problem.
  • 6 Check your power supply. Make sure your Samsung DLP is securely plugged into a working outlet. Plug the TV into a different outlet to see if the problem still exists. Make sure that a fuse hasn't blown in your house or a circuit breaker hasn't flipped.
  • 7 Replace the lamp. If your Samsung DLP is shutting off or won't turn on, a bad lamp is the most likely cause. To replace the lamp, remove the lamp cover from the back of the TV by removing the screws with a Phillips screwdriver and slide it out and away from the TV. Remove the screws on the lamp assembly and slide it out of the TV. Disconnect the old lamp and insert a new lamp into the assembly. Slide the assembly back into place and replace the screws. Do the same for the lamp cover.
  • 8 Check for signs of overheating. Samsung DLP TVs generate a sizable amount of heat. If the components inside the TV get to hot, the TV will shut itself off as a protective measure. Make sure your DLP is out 12 inches or so from the wall. Make sure that all of the vents on the set are clear of any obstructions. Allow the TV to cool down for 30 minutes before turning it back on.
  • 9 Contact Samsung. If none of the above tips help, it's time to contact Samsung, as the problem is likely something that should only be fixed by a qualified service technician. More serious problems may include a bad power supply or a bad ballast. Attempting to repair those yourself will void your warranty and may cause more serious damage to your set.
  • The safety switch exists so the user does not accidentally remove the lamp door while the TV is on. Doing so could, theoretically, result in burn or electrocution. This spring loaded switch causes the TV to shut down when the door is opened.
  • Since the TV's chasis is plastic, expansion and contraction can cause the switch to lose firm contact with the lamp door. The TV's behavior could then be such that after being on for a while (getting warm) the plastic expands and the switch loses enough contact to cause the TV to shut down. The frequency with which this phenomenon occurs is not only dependent on the internal temperature of the TV, but also the ambient temperature of the room as well as the relative tension on the switch itself. The user's perception is that the TV starts up fine, but then "randomly" turns itself off after being on for a while.
  • If you have recently moved your TV, it is very common for random shut-downs to occur. This is because the move has shifted the flimsy plastic chasis of the TV, thereby loosening the contact between the lamp door and the switch.
  • Make sure your TV is off and cool when performing this procedure.
  • Sep 17, 2009 | Samsung DLP HL-P4663W 46" Rear Projection...
    Sound but no picture - won't stay on
    you may check your lamp first. other than that i would say a faulty mains board.
    Apr 16, 2009 | Samsung DLP HL-P4663W 46" Rear Projection...
    Samsung tv turns of by itself
    The lamp can cause this but also a faulty lamp door switch will cause the same thing
    Make shure that when you replace the lamp
    the lamp door switch is in the up position before the door is put back on
    Jan 28, 2009 | Samsung DLP HL-P4663W 46" Rear Projection...
    Samsung Dlp- Lamp does not turn on
    You most likley have the little copper colored flat ribbon inserted into the plug backwards.Filp it over this should fix your problem.Common mistake.
    Jan 11, 2009 | Samsung HLN5065W 50" Rear Projection...
    Colour spots
    turn your color all the way down and observe the black and white, contrast and grays . should be crisp. if sorted looks still like blurry grays with little contrast...... your problem lies in the video processing circuit.
    Oct 23, 2008 | Samsung DLP HL-P4663W 46" Rear Projection...
    Televison & Video Logo
    19 people viewed this question
    Top Toshiba Televison & Video Experts
    Jaime Hernandez
    Henry  Thomas
    Henry Thomas
    Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
