Question about Dryers
It is an older electric front load dryer with Parts number 3393434
  • yadayada
    yadayada Mar 11, 2011
    I have no way to reference part numbers, only model numbers.
  • 552 Answers
You can watch a video that explains how to test all the components of the dryer by clicking on the link below.
http://www.appliancerepairlesson.com/
Posted on Mar 12, 2011
Have a affinity front load dryer that comes on runs five min then shuts off and all three lights by the start button come on and flash wont heat up
Hi Friend, this is Z. I appreciate your inquiry!
I interpret that you are having trouble with your Frigidaire dryer (FASE7073NW) not starting. Let's try resetting your dryer by flipping the household circuit breaker to the off position. It is necessary to wait roughly ten minutes and then turn on your dryer. Confirm that the door is securely closed and select a cycle. If resetting the power does not correct the issue, I have identified that it could potentially mean a number of things: a potential wiring failure, damaged cord, faulty door latch assembly or control board. Because it could be a number of any one of several underlying causes, I would personally contact a professional to accurately diagnose your dryer to determine the root cause to reduce the risk of unnecessary parts. Best regards!
Aug 21, 2014 | Frigidaire Affinity FASE7073NW 27"...
Removing front panel on electric dryer model number 110.66732500
sure..you'll need to unplug the machine, tip it back a bit, and access those screws from underneath. Do NOT lay this unit on it's back. 45 degrees at most.
and by the way, put something underneath it while working on it.
Mar 09, 2008 | Dryers
My front load dryer the knob to turn it on is cracked inside how do i get a replacement for it?
You can order one online from any number of appliance parts sites, such as ereplacementparts.com. Enter your brand and model number, then pick out the part you need from the displayed illustration.
If you live in a larger metropolitan area, then find a local appliance parts supplier in the yellow pages.
Apr 15, 2014 | Hotpoint Ariston Aquarius WD420 Front Load...
Dryer turnes but no heat on clogged lint filter 220 voltes pludneed part number for heating element front load top filter
Sorry to read about your problem, I hope this helps you out.
your heater coil part number is 3387747
Try getting your parts here, www.aplusapplianceparts.com and use this coupon code 1051 for a discount.
I tried to help you. Please help me and Rate/Vote on my response. We take the time to answer your question. take the time to rate us.Thanks and good luck
4 Thumbs - Very Helpful
3 Thumbs - Helpful
Jan 01, 2011 | Whirlpool GEW9250 Electric Dryer
KENMORE DRYER WILL NOT HEAT ON ANY SETTINGS OLDER DRYER DO NOT HAVE ANY REPAIR MANUALS OR PARTS MANUALS. HAVE NOT CHECKED ANYTHING OTHER THAN TRIED DIFFERANT SETTING FOR DRYING.
is it gas or electric?send the model number?if you haven't cleaned the dryer out in a long time you could have popped the thermal fuse located on the blower wheel housing,if the lint filter is on top it's in the back of dryer,if the filter is inside the fuse is in the front on top,take the duct off that the lint filter slides into clean it out and the fuse is on top and to the right of the wheel,vac out the dryer and clean out the vent line,if it's a long run blow it out with a leaf blower,you should do this once a year,if it's not the fuse you gotta send model number and i can help you
Feb 11, 2010 | Kenmore Dryers
My door on the dryer is letting out moisture. It seems to be bowed out. I put a new screw into the one that was lost but it is not repaired. What do I do? This is a Maytag dryer LDE8704ACE. It has a front...
There is a front panel seal ($3.11) and a door seal ($3.20) that you can replace. If the hinges are not worn out, these two parts should fix the dryer. If you go to www.appliancepartspro.com and enter your model number, you will see every part inside your dryer. you can order the parts from this site also.
Please rate solution
Sep 07, 2009 | Maytag PYE2300AY Electric Dryer
Maytag front load dryer thumps while turning, empty, full etc.
If your Maytag is like my Maytag, there are two screws at the two bottom corners of the front panel. Once you remove both screws the front panel will lift out, up, and off. Then you can see what is going on inside.
Mar 28, 2009 | Maytag Dryers
Electric dryer makes a rumbling when tumbler is turning.
Check the drum bearing, a load noise, and often spinning problems are symptoms of a bad drum bearing.The bearing is at the base of the drum and accessing it is not easy.
You can find diagrams and replacement parts entering model number here.
Jan 06, 2009 | Maytag PYE2300AY Electric Dryer
Dryer won't heat
If it is an electric heater that means that either the heating element,or the thermistor , or the cirrcuit breaker connecting the element mustbe replaced.
You find diagrams and replacement parts here, just enter the model number.
See also following suggestions from repairclinic :
There's no heat.
How Dryers work
Find a part for your Dryer
Oct 14, 2008 | Malber WD1000 Front Load Washer/Dryer
Dryers Logo
47 people viewed this question
Top Dryers Experts
