Question about Yamaha HTR-5730 Receiver
When using tuner both speakers work but when using turntable one speaker is very low?
    Brigadier General:
  • 8,546 Answers
ONLY one channel low with a turntable?
Are you using a self-preamlified TT or an outboard phono preamp, because the HTR has no facility for direct attachment of an old-school TT.
It could be a turntable problem if you have phono preamplification most likely. Swap the two channels to prove it or not.
Try another input.
Register and download the manual for free at retrevo.com
http://www.retrevo.com/support/Yamaha-HTR-5730-Receivers-manual/id/1075bh230/t/2/
Posted on Mar 11, 2011
With phono, I only get sound from one speaker, but no problem with tuner. Any ideas?
You can start to troubleshoot the issue.
Change the phono plugs reversing right/left. Does the working speaker change? If yes, problem is in turntable or cartridge. If no, problem is in your receiver.
If the problem is in the turntable or cartridge, pull the cartridge off. Is it directly plugged into the arm, or does it have 4 wires on it? If wires, swap right/left. Change in speaker? No? Problem in turntable wires. Yes? Replace cartridge.
If it's plugged directly into the arm, clean the connections with a pencil eraser (gently). Fixed? No? Try connecting turntable to a different receiver, comment.
What we're trying to do is to isolate where the problem is, so you know what to replace or fix.
Oct 02, 2015 | Audio Players & Recorders
I bought this amp. It switches on. It crackles and pops through the speakers and headphones. I disconnected the speakers. It keeps doing it through the headphones.
Hi George:
Old amp volume and tone controls are "pots" or potentiometers. They actually have contact points in them. If you can clean them you should get rid of a lot of the noise. Your local music store may be able to coach you. Old amps can be every bit as good as the newer ones. I have a 1950's Traynor tube model. Gotta luv it! Rock on.
Mar 15, 2015 | Vintage Audio Players & Recorders
Ps-lx 430 1 speaker gives low volume. Otherwise speakers work with other components
This is an old-school turntable so it requires a PHONO input on the amplifier (or a Phono Preamplifier). It will not produce either enough volume or the correct frequency response without it. Google Phono RIAA
Jul 01, 2010 | Sony PS-LX250H Turntable
Half the signal only through left speaker
Try the switch in the other position and see if that fixes the problem. some turntables had a phono level that is different than a standard rca line level input. Also try a different cable if the rca is not hardwired in to the turntable. The cable could be bad. If worse comes to worse upgrade to another amplifier or tuner that has a separate phono input. hope that helps.
May 09, 2010 | Stanton T.120 Turntable
Hi there! i just bought a numark tt1650 and an ortofon arkiv cartridge, connected it properly to my old technics a700mk2 amplifier (phono, grounding and all that) but it still has a buzzing problem...
Try connecting the turntable to one of the other inputs like CD / tuner etc and see if the buzzing disappears. if so then your turntable has a built-in pre-amp so it can be connected to any input except 'phono' as this would obviously be used for turntables without a pre-amp.
a lot of modern turntables now have built-in pre-amps to compensate for certain amps and receivers made without a phono input and can now be connected just like a CD player, tuner etc.
hope this helps.
May 05, 2010 | Numark TT1650 Turntable
Low volume from my thorens td-145 record player
Have you checked the cartridge in the turntable arm?Also check to make sure receiver/tuner is switched to Phono or Aux..Also check to see if there is a speaker switch on receiver.
Mar 07, 2010 | Thorens TD-170 Turntable
Very low volume from my technics sl6 even when tuner is turn up to max. volume.
Hiya, first and foremost, is it plugged into the amps correct sockets? Turnatables have to in the PHONO (turntable) Any others , CD, AUX, MIC etc will not work. (sorry if that seems obvious, wasnt sure on the info provided)
If that is OK then check the stylus, probably requires a new stylus or/and cartridge.
Best of luck
Jul 16, 2009 | Technics SL-1210M3D Turntable
Getting occasional popping sound through speakers. My system consists of preamp, amp, turntable, tuner and cd player. It seems to happen when only using cd player. Hasn't happened when using only tuner or...
Describe your system in greater detail. Does the preamp have a mechanical selector for the tuner/phono/CD or does it have a digital selector that you can operate with a remote? The problem might just be a dirty selector switch that need to be sprayed with Deoxit contact cleaner. It could also be bad cables so try swapping cables with the tuner.
Dec 20, 2008 | Audio Players & Recorders
Low volume on PS LX250h
This turntable has a built in pre-amp, under the platter is a on-off switch. Turn it to "on".
-Former PS-LX250H owner
Dec 12, 2008 | Sony PS-LX250H Turntable
Yamaha HTR-5730 Receiver Logo
126 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Electro Med Services...
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
