Question about Hoover HF712 Front Load
On my Hoover mod HNL7126 its not draining i have put a new pump on still not draining.
    Brigadier General:
  • 6,277 Answers
May I suggest you read through these notes especially near the end on how to check that the pump is or is not actually running? I hope they help.
Here are my complete, general pre-typed guidance notes for checking filters and motors ;-0)
If you are unsure where the filter is, it is often behind the front lower (kick) panel (or in some machines at the rear in an awkward position!) and held in by a round cover/knob.
REMOVE POWER AND ENSURE YOU HAVE A WATER RECEPTACLE/RAGS TO SOAK UP THE WATER WHICH IS BOUND TO POUR OUT!
It's surprising what people have found in theirs! It is always worthwhile checking it on a regular basis.
Now- whilst the filter is removed it is normally possible to see the drain motor and ensure it is not jammed by a foreign object such as a needle or a toothpick. It should be able to be turned by hand/finger- the power IS OFF!
At this point it is also possible to test if the motor works. No clothes or water in the machine, select a spin cycle and put the power back on. You should be able to see the motor turning at some point, possibly straight away. If it doesn't work then the motor is malfunctioning!
Hope the filter is the problem and good luck!
John C
Posted on Mar 11, 2011
My hoover 350m stopped at the end of the cycle but was still full of water. Could it mean a new pump or something else?
Could be just a blockage in the pump. Take pump off and clean it out. If still no drain then probably needs new pump but really needs pump tested first to make sure.
Dec 04, 2015 | Hoover Washing Machines
How to remove the drain pump from my hoover washing machine
bend machine one side locate drain pump remove drain hoses, screws and pump, replaced with a new one
Dec 03, 2014 | Hoover Washing Machines
Hoover nextra HNL 686
Check there are no loose wires and the plugs are connected.
Jul 14, 2014 | Hoover Washing Machines
Washing Machine won't drain away water.
Hi, can you hear the pump running when you select a drain program?
Mar 11, 2013 | Washing Machines
My Hoover elite 920 goes through it's cycle put
the pump is bad. not worth the repair bill. get a new washer
Nov 03, 2011 | Hoover Washing Machines
My hoover washing machine (hnl6166, 4yr old) won't pump the water out. I have replaced the pump as it was not working and checked for blockages. But still it won't drain, I've drained it manually for...
If you have replaced the pump with a new one and still no pump, check the hose from the washbowl to the pump. Usually a convoluted hose . It possibly has a blockage. Take the end of this hose off of the pump and check up it ....you might be surprised
Mar 23, 2011 | Hoover Washing Machines
Hoover hpe 236. water not draining, stops mid cycle, lights flash
Have you checked the pump filter, and or that the pump is actually working. if it spins o/k with no water in, then I would suspect a draining problem.
If filter clean and pump o/k, then it could be a control module fault. if this were the case, then it would probably be wiser to purchase a new washer.
Hope this is of some help to you.
Jan 16, 2010 | Hoover Washing Machines
Why wont my hoover 2320LAUS washing machine drain water
Sounds like the water pump is not running either from power lack or defective pump motor.
Nov 15, 2009 | Hoover My Dad Can Arrest Your Dad Kids...
F 21 fault ?? on a kenmore mod 110.47512601
First if you have a wet vac pull the drain hose out of the drain spout and use the vac to pull the water out of the washer through the drain hose.If not you will need a pair of radiator hose clamps from the auto parts store. Pull the screws from the lower panel at the front of the washer and remove it.in side you will see a rubber hose coming down from the tub to the drain pump. Put the radiator hose clamp there if you didn't have a shop vac.On the front of the pump is a round part with a handle turn that and remove the pump filter .Clean any foreign objects out of the pump and look inside the pump to make sure no impeller blades are broken if any are you will have to replace the pump. put the filter back in and tighten it. If you had to use the hose clamp remove it now.reassemble and don't forget to give the tech his four boxes if this fixes it
Feb 17, 2008 | Kenmore 46462 Front Load Washer
Error e3
Drain pump probably not working. Put machine on cycle 7 and it should turn on the drain pump straight away. you can hear this near the bottom of the machine. if it is silent hten the pump probably needs replacing. I repaired mine be removing it and then dismantle the magnet from the tube then give it a good clean out.
Feb 03, 2008 | Hoover 24 in. HD97E Free-standing...
Hoover HF712 Front Load Logo
Top Hoover Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Hoover Washing Machine Expert? Answer questions, earn points and help others
