Question about Honeywell HZ-680 Oil Filled Radiator Heater
How do i refill the oil? can i use water? - Honeywell HZ-680 Oil Filled Radiator Heater
  • yadayada
    yadayada Mar 11, 2011
    These are sealed, what have you done here. And no not water.
My Nissan terrano mix water and oil in the engine
This is almost certainly due to a blown head gasket, which will have to be replaced. Oil and water systems will need to be flushed and refilled with clean oil and coolant
Sep 16, 2016 | Nissan Terrano Cars & Trucks
Drain and refill Ram and how much fluid to refill the Ram
Not sure which fluid has water in it? Oil? Transmission fluid? differentials?
Each of the fluids I listed would be in the operators manual. Dodge has several tranny's and differentials.
Feb 12, 2016 | Cars & Trucks
09 Suzuki King Quad has oil in the radiator
Hi Joshua
Obviously a seal or head gasket is leaking oil to the water jacket.
Clean out the radiator and refill with water and see how long it takes to get oil back in water. Re Tighten head bolts if maybe loose.
Good Luck
Nov 02, 2014 | Motorcycles
Ford ba xt ute auto slipping & auto oil in coolent
Replace radiator with a new one remove pan and replace filter. refil and run then drain tranny and refil again . There will be water contaminant in the torque converter so it may be best to have a transmission expert change the auto oil when the engine is running. It may cost extra for the oil used but it will be cheaper in the long run
Mar 16, 2013 | Cars & Trucks
What do I do If I Put Water Where the Oil goes in my car
First off, dont run the car. Secondly fully drain the oil/water mixture from the sump drain screw and then refill with new oil.
Dec 05, 2012 | 2003 Saturn VUE
Need some info on changing my water pump on a 2000 Suzuki GSX-R600
Remove the lower fairing.
Remaove radiator cap, disconnect water hose from the water pump and drain coolant.
Remove the oil drain plug to drain engine oil, remove the coolant reservoir tank.
Remove gearshift lever and engine sprocket cover.
Disconnect water hoses.
Remove the water pump mounting bolt and the water pump assembly.
Replacement is the reverse and don't forget to refill the oil!
Feb 19, 2011 | Suzuki GSX-R 600 Motorcycles
Heaters were not heating up machanic replaced water pump + thermastate and timing belt as radiator wasnt heating up now the water is boiling nut has not oil in it the oil level light is flashing but has no...
I don't understand why the timing belt was replaced for a heater problem. Is the car running rough or missing badly? Have you actually checked the oil or just relying on the oil level light. Check the oil and look for signs of water in the oil. If the oil doesn't show signs of water, refill the radiator with antifreeze and bring the oil level up to the full mark. Run the engine until it gets hot. Turn the engine off and let it cool enough so that you can remove the radiator cap. If the radiator is empty again, there must be leak somewhere. If you can't find a leak then it may be going inside the engine. If that is the case then the engine should be running very rough. Let me know what you find.
Dec 27, 2010 | 1993 Toyota Previa
Oil is creamy but coolent is fine dosent smoke has been sitting in garden for nearly a year?
Creamy oil means there is water/moisture in it
Maybe from a cracked head, or a bad head gasket
Maybe from condensation but don't run it until you find out Moisture can destroy your bearings
Drain the oil, change the filter, refill the crankcase with diesel, start and run for 1 MINUTE, drain oil, change filter, refill with the proper oil, run for 5 minutes, don't ride it just run it slightly above idle
IF your oil is still milky you have a big problem
Apr 04, 2010 | 1996 Suzuki GSX-R 750 T
I accidentally got water in the oil part of the engine
Definitely DO NOT start the car...drain the oil pan, replace the plug, and refill with the proper amount of oil. Start the car and run until the engine temp is at the normal range for at least 15 minutes. Then drain the oil, change the filter, and refill with fresh oil.
Jan 22, 2009 | 2005 Pontiac Grand Prix
Honeywell HZ-680 Oil Filled Radiator Heater Logo
97 people viewed this question
Top Honeywell Heating & Cooling Experts
Bill Long
Paul Carew
vance jones
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
