Question about Refrigerators
Kenmore top mount 106.63832302 refrigerator - freezer not working, but refrigerator is. What could be the problem?
SOURCE: kenmore elite refrigerator, model # 59676534500
I went ahead and signed up for Sears' service warranty since I knew I had to get someone to come out.  IT costs $200/yr.  They say it covers everything, but when the technician came out, he told me that it just covers $500 per visit.  He said that a new motherboard and the labor alone was going to make it $498.  Anyway,   he had ordered a new motherboard. Apparently the motherboard wasn't working.  It is located in the back bottom left side of the refrigerator behind the panel.  There is a compartment on the lefthand side that slides out and houses the motherboard.  He put that in and also had to fix the fan that is in the back of the freezer.  That fan is the one that sends cool air up to the refrigerator part. When I had looked at the fan before the repair man came, it was not moving at all.  So at least take a look at the fan in the freezer.  Just take out the freezer drawers, and the fan is located in the top center of the freezer behind the compartment cover.  Maybe that's the problem with your refrigerator, the fan.  Hope that's all it is. Good luck!
Posted on Jun 25, 2008
SOURCE: fridge doesnt work both freezer and refrigerator part not making ice
TRY REPLACING OVERLOAD RELAY..PARTS #67005560....IT COST TO ORDER AT THE INTERNET AT $27.45..........REPAIR SERVICE WILL CHARGE YOU , AS WHAT THEY DID TO ME $69.43 PLUS $120.00 FOR LABOR....IT SUCKS.....FROM ALEX ESMENA ..NORTH LAS VEGAS NEVADA
Posted on Nov 09, 2008
  • 93 Answers
SOURCE: I have a Kenmore refrigerator/freezer.
your defrost timer is not working repkace timer cost about 20.00 look at back bottom some on upper top ofin fresh food compartment near the light thanks from gilles
Posted on Mar 15, 2009
SOURCE: kenmore coldspot model 106: top freezer leaks
Have you tried adjusting the freezer temperature to a higher level? This worked for my Kenmore. It will take a couple of days to quit leaking.
Posted on Dec 19, 2010
heatman101
  • 43501 Answers
SOURCE: kenmore coldspot model 106-54592400. The
Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Posted on Dec 27, 2010
KENMORE ELITE TOP MOUNT #2218591. I have to keep 2 bowls in the back of the refrigerator on the top shelf beacause water is leaking from somewhere. It has an ice maker. Could that be the problem?
this is a a frozen drain . kenmore has a drain heater kit the will correct the problem .. very common with top mount freezers .. .. hope this helps mmm feed back pls /
Jul 09, 2011 | Kenmore Refrigerators
Looking for a manual for Kenmore Elite Refridgerator MFG 2005 Model #106.74219400
http://www.managemylife.com/mmh/owner_manuals/5877
/KENMORE-ELITE-Top-Mount-Refrigerator-L0408620
Apr 20, 2011 | Kenmore Top Freezer Refrigerator
Kenmore Elite top mount refrigerator getting ice on top shelf and watr accumulating on bottom and in vegetable drawer. I cleaned the freezer and unblocked clogged ice but it still is a problem.
Check out these tips...they can help you figure out whats going wrong with yourrefrigerator and why it is not cooling
heatman101
Sep 20, 2010 | Kenmore 21.7 cu. ft. Top Mount...
I need a manuel for my top freezer refrigerator by Kenmore purchased in 2008
http://www.managemylife.com/mmh/owner_manuals/6003/
KENMORE-Top-Mount-Refrigerator-L0504597?brand_name_search=64722
Jul 09, 2010 | Kenmore 64722 Top Freezer Refrigerator
Top mount freezer drain keeps freezing up causing water to collect in refrigerator compartment. Drain is not clogged until it freezes.
Check the Evaperator Fan in freezer for correct operation low air flow will cause the problem. Check defrost timer, heater and limit thermostat, If it is not defrosting correctly it will cause the problem.
Mar 29, 2010 | Kenmore 21.7 cu. ft. Top Mount...
My kenmore top freezer doesnt work my
the refrigerator may need some refrigerant, it might have a leak.
Mar 06, 2010 | Kenmore 64722 Top Freezer Refrigerator
Kenmore elite - Water dripping from freezer to refrigerator
Your refrigerator has a defrost drain blockage behind the evaporator in your your freezer compartment. Some models like yours have leak in the turns as the water leaves the freezer. I recommend that you unplug and remove the cover to the evaporator and check the defrost condensate tray below the evaporator. A wet vacuum cleaner and poring a solution with clorox in the drain will help you clean locate the leak and where the blockage may be downline.. I do have the manual on yours and can help you solve this. Some times this is a factory defect and I can help you solve the freezing drain problem. Let me know, Sea Breeze
http://fixitnow.com/wp/2009/05/26/the-permanent-cure-for-repeatedly-freezing-condensate-drains-in-whirlpool-roper-kitchenaid-top-mount-refrigerators/
http://servicepartstec.blogspot.com/
Jul 01, 2009 | Kenmore 20.6 cu. ft. Top Freezer...
Kenmore top freezer leaking water on the inside when defrosting
MAKE SURE THE FAN IN REAR OF FREEZER COMPARTMENT IS RUNNING , SOME TIME YOU MUST DEPRESS THE DOOR SWITCH ON THE FREEZER DOOR TO WATCH FAN IF NOT REPLACE FAN , NOT BAD MOST UNPLUG , IF THIS IS NOT IT YOU COULD HAVE A INTERMITTENT DEFROST TIMER OR A BAD DEFROST HEATER
Feb 24, 2009 | Kenmore 18.9 cu. ft. Top Mount...
Freezer not working in garage top mount freezer on refrigerator
Sears is technically correct. It wouldn't work with the old coolant either. The principle is simple. The refrigerator is the same temp as your garage - it is not running. It must be in a 60 degree room to work properly. The sensor to turn it on is in the fresh food compartment, and it never calls for cooling; therefore it appears you freezer only is out - but they both work together. Hope this helps!
Feb 17, 2009 | Kenmore 64522 Top Freezer Refrigerator
Refrigerators Logo
75 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
