Question about Konus 2109 KON (30x60) Binocular
I have a Konus NewZoom 10 (10 30x60). The zoom lever only controls one side. Could I fix it myself and, if not, is it worth trying to get it fixed?
  • 6,771 Answers
The product will require you to send it in for service because there is a critical alignment that must be done to give the 3D effect which requires special equipment. My sense is the repair with parts and labor would not be cost effective to repair but cheaper to replace.
Posted on Mar 11, 2011
How can I fix my camera when stating write project
If you have a memory card in it take it out and on the side of card like a little switch slides up and down what ever position it is in put it in the other and should be fixed.
Aug 16, 2014 | GE Power Pro X400 Black 14MP Digital...
Zoom lever sticks
try a few drops of denatured alcohol- applied with a q-tip...
May 08, 2014 | Kodak EasyShare Z950 Digital Camera
How to fix zoom lever?
Try a can of dry air.Sometimes the smallest piece of grit can stop the action.Give it a good clean with the spray.
The zoom lever is not working moves but doesnt change
If the zoom lever is not working then I would recommend buying a new pair without a zooming mechanism. Zoom binoculars are more trouble than they are worth. Sorry!
Feb 20, 2010 | Minolta Classic II Binocular
HF10 zoom goes without any explicit request
My HF10 started to mysteriously autozoom as well, and I had made no setup changes. I don't have exactly the same symptoms as you describe except that it would begin to zoom when I didn't want it to. I noticed the [I.AF] (Instant AutoFocus) icon, so I went into the menu (Camera Setup - AF Mode) and turned the "Instant AF" to "Normal AF". After that, the autozoom seemed to have stopped. I set it back to "Instant AF" and it did not autozoom again. I wouldn't know how to turn the autozoom back on again even if I wanted to, but thankfully it appears to be gone now. Hopefully it will stay in manual zoom mode. Hope that helps.
Dec 22, 2009 | Canon VIXIA HF10 HDV Camcorder
HI MY ZOOM LEVER ON MY C-5060 HAS COME OFF WITH THE SHUTTER BUTTON. I CAN SEE THAT THERE ARE THREE LITTLE PLASTIC SUPPORTS BROKEN THAT HOLD THE ROUND LEVER ON . IS THIS EXPENSIVE TO GET FIXED? I JUST...
hi,
you just try this ,first cut plastic picise size of the pins ,may be there is west calculator's plastic is best for it, and fix it properly by using plastic solution ,like FAVI QUICK just try this carefully,
hope you are understand ,
Aug 31, 2009 | Olympus Camedia C-5060 Wide Zoom Digital...
Heat comes out driverside/cool air comes out the passenger side?
It sounds like your blend doors are broken. As it turns out, this is a VERY common problem with grand cherokees. My father and I fixed this problem on my 2001 Jeep Grand Cherokee Limited 4.7 about 2 months ago using a product called Heater Treater, found here: http://www.heatertreater.net/
You can find a very helpful detailed write-up of the fix/installation here: http://www.jeepsunlimited.com/forums/showthread.php?t=854246
Trust me, this REALLY works and a lot of Jeep Grand Cherokee owners, including myself, have done this. YOU WON'T HAVE TO REMOVE YOUR DASHBOARD, as the repair is done by simply removing your glove box. The downside is that you will lose Dual Climate Control, as the driver side thermostat will now control both sides. For me, it was worth it. Only spending about $150 for a Do-It-Yourself solution, versus spending about $1000 to have a mechanic remove my dashboard to fix it.
Dec 05, 2008 | Jeep 10 x 20
Broken zoom
The E18 error is fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension.
Here's some things that you can do to try to correct it. They only seem to work for about 50% of lens errors, but they're worth a try:
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Jan 16, 2008 | Canon PowerShot A520 Digital Camera
Can't zoom
To my regret you can't repair it by yourself and it should be repaired in a professional lab. Following the repair cost you should decide, whether it worth it.
May 02, 2007 | Canon PowerShot SD600 Digital Camera
Konus 2109 KON (30x60) Binocular Logo
59 people viewed this question
Top Konus Optics Experts
Joe Lalumia aka...
Joe Lalumia aka...
Mark Schmit
Mark Schmit
Are you a Konus Optic Expert? Answer questions, earn points and help others
