Question about Panasonic Audio Players & Recorders
F61 SHUTS OFF, ITS A PANASONIC MUSIC SYSTEM - Panasonic Audio Players & Recorders
    Brigadier General:
  • 8,546 Answers
F61 usually means the amp has detected a short.
Generally speaking, an amp protects itself from heat, shorts, overloads and operator exuberance by refusing to turn on or stay on.
Overloads can be from excessive periods of high output or marginally low impedance loading by the speakers; and shorts would be wiring issues or a speaker blowing up.
You should be able to feel if it's hot. WHY is it overheating? Make sure it has sufficient ventilation on all sides and that vent holes are not blocked by dust balls. Ensure the fan (if equipped) is running as designed (some only operate on demand). Clean dust and debris from it.
If the amp comes back on after cooling, you're lucky. They only have so many self-protection cycles in their lives so continuously resetting or cycling their power without addressing the cause can do more harm than good.
If it protects immediately on a cool power up you should disconnect the speaker connections and try it 'naked'. If it comes up then diagnose which lead(s) are shorted. If it does not come up the problem is internal and should be left to an experienced and competent hands-on tech.
Check for loose speaker connections at the speaker as a root cause for intermittent shutdown.
Posted on Mar 11, 2011
  • 39 Answers
SOURCE: F61 error
Hello....
Isolate problem by disconnecting Amplifier ic (RSN),if f61 still appeares after disconnection of RSN ic ,than check voltage supply rails ,may be one of them has irregularities.
Gopali
Posted on Dec 14, 2007
  • 4 Answers
SOURCE: F61 error in my SA-AK25 Panasonic Audio System
CHANGE STK --------IC
Posted on Mar 27, 2008
pjbaldi
  • 8 Answers
SOURCE: How to fix F61 error?
First re solder any dry joints on Transistors Q502, 504, 507, 515 & CN500, IC501. If there are no dry joins replace IC501 (STK470-0??) & maybe D501 (16.V) zener
Posted on Feb 26, 2010
SOURCE: error f61 on a panasonic SK-AK640 CD stereo system
when i turn the power on , it goes off in 3 sec after displaying "f61"
Posted on Mar 01, 2010
  • 19 Answers
SOURCE: I got panasonic- sa-ak240 stereo
F61 is an Error Code......it's basically indicating that something inside the stereo is malfunctioning or broken.
the stereo has gone into Protection mode.....could mean there is Direct Current on one of the output rails....most likely the Power Amplifier IC in your Stereo has gone bad....a new one should solve this problem....you'll need to send it in to Panasonic for replacement of the faulty parts.
Posted on Oct 30, 2010
My panasonic music system (SA VK-960) Is not working properly it shows (F61) error all the components are well attached with music system but there is still F61 error . Help us to resolve this error.
See page 40
Power Supply Error Code Table http://diagramasde.com/diagramas/otros2/panasonic_sa-vk960gc.pdf
Suggest checking power resistors in amp circuits for failed resistor. replace with identical rating in that the power resistors are used in the saftey circuits. Also check around these resistors for failed solder connection.
Hope this helps?
Jun 29, 2017 | Panasonic Audio Players & Recorders
How can I correct F61 error?
See page 37 of the user manual.
Get from lil given here.
Error F61
Check and correct the speaker cord connections. If this does not fix the problem, there is a power supply problem. Consult the dealer.
http://service.us.panasonic.com/OPERMANPDF/SAHT730.PDF
Feb 01, 2016 | Panasonic SC-HT730 System
MY MUSIC SYSTEM PANASONIC AK88 THIS SYSTEM ERROR IS F61 PLEASE DIOGRAM OF REPAIR IN MY SYSTEM
As far as the fan is concerned, please reject it as ak-88 is not equipped with 1. the f61 is the errror code for blown power supply ic, you have to get it changed.I have the same system and 2 times i had the same problem. IC is stk 470 0405_28_2012_9_55_21_am.jpg
Feb 27, 2012 | Audio Players & Recorders
We have a panasonic sapt550 music dvd player and want to play dvds in Australia-can you help
I Have problem with DVD play. Panasonic DVD home tHeater system SA-PT550. COMES UP WITH F61
Mar 07, 2010 | Panasonic Home Theater System System
F61 error
I Have a panasonic mdvd home theater modl#SA-HT920, WHEN I RAISE THE VOLUME IT SHUTS DOWN AND INDICATES F61 ON THE LCD SCREEN HOW CAN I SOLVE THE PROBLEM
Feb 22, 2009 | Panasonic Home Theater System System
Panasonic SA-HT940
F61 is a problem with the output amplifier pac. It is the equivalent of "protect" mode. The output pac needs to be replaced. I'll look up the part number for you.
Dan
May 14, 2008 | Panasonic sa-ht930 Home Theater Audio...
Sa-ht680 service manual
The F61 indicates protect mode. There is a problem with the output stage of the amplifier section and the unit shuts down to prevent further damage. This unit will require service of the amp section. You can try to contact Panasonic for the service manual.
The output amp pac is an RSN311W64D at a cost of $95 plus shipping.
Dan
Apr 09, 2008 | Panasonic SC-HT930 System
F61 code
yes i did see this code F61  but turned off and back on and the surround and center speakers still don't work
Jan 06, 2008 | Panasonic SC-HT720 System
124 people viewed this question
Top Panasonic Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Panasonic Audio Player and Recorder Expert? Answer questions, earn points and help others
