Question about Odyssey 4 Wheel Full Size Mobility Scooter by Drive
On a new odyssey scooter are you required to connect the battery before charging.
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 347 Answers
Please visit:www.alldatasheet.com
Posted on Mar 12, 2011
My scooter will not fully charge
This could be the charger socket is worn and not making a good connection when charging or it could be the charger itself at fault. Now you have changed the batteries, I presume new and both the same type, you need to look at the charging side.
Apr 03, 2013 | Rascal 600 T Electric Scooter w Seat Lift...
I need to replace the battery case for my Golden tech liteway scooter. Or i need to see a wiring diagram. Can you help?
This scooter requires (2) 12 volt 15 Ah batteries. Typically you would open the case and replace the two batteries inside not the entire case and batteries.
Locate the screws that hold the case together and open it. Make a diagram of the how the batteries are connected. Obtain the new batteries locally or on-line, install and fully charge.
Hope this helps.
Apr 24, 2011 | Golden Technologies Golden Liteway...
I have a brand new scooter the batteries wont hold the charge
Bill have them replace the batteries. They are under warranty for 6 months and the provider is responsible for providing free replacement batteries under warranty. If they won't contact the manufacturer of the chair and explain your problem (that the provider will not replace bad batteries) they should require the provider to give you new batteries or send some to you. Make sure that you charge the new batteries before use and that you charge them nightly for 20 days If you use the scooter daily charge it every nite when you go to bed and unplug it in the morning hen you get up. Remember to have the power off to the charger whenever you plug or unplug it from the scooter. if the charger is an onboard one then just plug it into the wall and unplug when charged Hope this helps
Apr 08, 2011 | Electric Strider Mini 4 Wheel Mobility...
I have a new Drive Medical Odyssey that will not charge. Several attempts but the yellow "charging light" will not turn green, even after 24 hours. Once I disconnect the charger and turn on the...
soo Have the provider install new batteries. No telling how long the "new" batteries sat on a shelf and in the showroom without being charged. The batteries are warrantied and should be replaced. While you're at have them check out the scooter after the new batteries are installed and remember to charge before use. Hope this helps
Mar 25, 2011 | Drive Medical Odyssey Full Size Scooter
On a odyssey handicapped scooter 4 wheel new do you have to connect the battery or is it connected at the factory
Harv if you turn the scooter on and the lights come on then the batteries are connected. Yes charge before use and the provider that sold you the scooter should have installed the batteries
Mar 11, 2011 | Health & Beauty
My mother's scooter will not charge. The unit has been plugged in for over 24 hours with no change to the charged indicators. The horn works but the unit is not charging.
The horn requires very little energy to operate, so that is not a good indicator. Check all the wire connections. Take out the battery from the case and with a flashlight, check the terminals where the battery makes contact with the post of the unit. Carbon and oxidation can build up on these terminals very quickly if the scooter is used outside. Use a very fine sand paper to lightly remove this residue without removing the zinc plating then wipe with a clean cloth.
Jan 16, 2011 | Pride New Mobility Victory XL 4 Wheel...
The battery takes a charge, but will not power scooter
This scooter require two batteries, not one. It is usually a good idea to replace both batteries at the same time, even though one is obviously bad, and the other "seems" okay. These 12 volt DC batteries (VDC) work in tandem to produce the 24 volts that the scooter operates on. In a perfect world, they would both live a long and happy life, but reality is that some die young, others old. Since they are joined together, the one that's going out saps the life out of the other one, so take a bullet and replace both batteries. Make sure you completely charge the scooter when you get the new ones in. Verify that your charger is working properly. To properly charge the 24 VDC system, the chargers have to have an output of about 26-28VDC. The output must be higher than the rated voltage of the two batteries put together to charge. While you have the shell off the scooter, you can see if the charger is working by measuring across the terminal on each battery with the charger off. Note the meter reading. It should be 12-13 VDC. Put it on the charger and retake the reading, and each battery should show an increase in the voltage due to the boost from the charger. After three hours, each battery should show about a 13.5 VDC reading which should hold above 12 for a good 8-10 miles. Always charge your batteries overnight, and if not in use, disconnect them completely with a full charge on the batteries.
Jul 11, 2009 | Golden Technologies Avenger 4 Wheel...
Odyssey 4-wheel electric scooter - The following has happened twice in a 6 month period near the same geographic neighborhood location. While driving the scooter, which is fully charged and operating...
Always check the battery connections first because too many times it is a loose connection or battery bolt. it would happen more if you drive it a long distance, or up a hill and the controller over heats or if you are hitting a bump. when the controller cools down it drives again.
Mar 01, 2009 | Odyssey Drive 4-Wheel Scooter - Color Blue
Scooter has full charge but still won't go.
It probably means that the connections or wiring from your battery are loose or broken. When you add the extra current required to run the motors, the voltage is being lost. Monitor the battery voltage with a meter while trying to drive the scooter will prove this.
Nov 25, 2008 | Pride Go-Go Ultra X 3-Wheel Travel Scooter
Odyssey 4 Wheel Full Size Mobility Scooter by Drive Logo
47 people viewed this question
Top Odyssey Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you an Odyssey Health and Beauty Expert? Answer questions, earn points and help others
