Question about Bissell Vacuums
How do I get the filter out of a bissell model number 6583?
  • 694 Answers
Instruction can be found on page 8 of the manual on the below link.
http://www.bissell.com/assets/0/132/134/228/78366bd2-6286-4bf0-a2c1-0aa5491466e6.pdf
Posted on Mar 11, 2011
How to change vacuum belt on bissell 6583-x
I am not familiar with this model but the first step would be to
remove the brush bar cover...this may be attached by screws
or numbered tabs which are released in sequence starting
with #1. With the cover off pull the brush bar out and slip the
belt off the pulley. Be sure to buy the correct belt and line up
the groove on the brush bar with the motor pulley...put the belt on
the pulley and stretch the brush bar forward and insert into the
slots on the sides. I hope all this applies to your vacuum.
Regards,
Dennis
Aug 10, 2014 | Bissell Vacuums
Bissell 1630-5 Deep Cleaner Parts need filter Where can I purchase this?
Go on line to Bissell and seek the parts department and purchase from them. If you care to enter the part number of the device you need into the command line of MSN.COM; they can send you to several sites that can fill you needs.
May 10, 2014 | Bissell Carpet Cleaner Powerbrush Deep...
My bissell 6583 worked fine for 2 years no problems . Today I vacuumed my sons room, turned the vacuume off, 2 hours later it won't turn on... Help please I'm in the middle of my spring cleaning.
Hi Mary. I can understand how frustrating this can be especially when Spring cleaning.
Here is a quick link to troubleshooting steps to assist you with the no power: http://www.bissell.com/FAQDetail.aspx?id=1457&cid=ccsocial
Apr 14, 2013 | Vacuums
Bissell bagless 6583 brush won't turn after new belt
Sorry to hear about the difficulty with the brush. If your brush does not turn by hand freely, then your brush needs to be replaced.
Here is a quick link to order a new brush:
http://www.bissell.com/parts/?id=9143&sc=part&partid=17048&cid=ccsocial
Mar 20, 2013 | Vacuums
Brand new bissell #6583 upright vacuum worked for 15 min
The belt may be broken. The following link is to the User's Guide which explains how to check and replace the belt if needed.
http://www.bissell.com/searchresults.aspx?searchType=find+a+user+guide&searchtext=6583&mode=userguides
Jul 14, 2010 | Bissell 6594 PowerForce Bagless Upright...
I received as a gift, but it doesn't have a manual and I cannot find one on Bissell's website for Model 6583. Do you possibly have a cross reference? Thank you very much.
BISSELL User's Guides can be downloaded at www.bissell.com
On the front page under Customer Service click on User's Guides and enter the model number of your unit.
User Guide will be displayed as a PDF file.
Jun 22, 2010 | Bissell 6594 PowerForce Bagless Upright...
My bissel bagless vacume is not sucking
This is a fairly common problem with the Bissell bagless vacuums unfortunately. Bissell uses a series of filters throughout their machines, and if you haven't washed this filters recently, this may be the cause of the lack of suction.
If you'd like, please just reply to this repair with the exact model of your Bissell. This model number can be found on the bottom or the back of your vacuum cleaner on a sticker that also contains the serial number. This information will help me identify where exactly your filters are located.
Most Bissell's have a hidden filter inside of a trap door that most people aren't even aware of. First check to see if your model has a filter located directly under the bagless dirt cup. It's usually in a black colored tray that says "PULL". Slide this tray out, and check the filter that's in there. If it's all dirty and caked on with dirt, then this is probably your problem. This foam filter can actually be washed, just rinse it under the sink, but make sure it's completely 100% air dried before putting back in your vacuum.
If your model doesn't have a filter here, then you may also have a filter above the dirt cup. When you remove the dirt cup, look directly above the dirt cup in the clear plastic part that stays on the vacuum. There should be a circular shaped plastic part in the top part, Simply turn the plastic part to left while pulling downwards, and this filter should pull out. This filter is also washable, just make sure that it's dry before using the vacuum again.
Again, if you'd like to give me your exact model number, I'd be more then happy to better diagnosis the vacuum cleaners suction loss for you. Please just use the clarification request here on Fixya.
If this was helpful to you, please be so kind and rate my answer as helpful by clicking on the thumbs up icons in the top right hand corner of the repair. Thank you very much, this is greatly appreciated. If this wasn't helpful, rather then rating it unhelpful, please let me know more detailed information, and I'd be more then happy to walk you through the repair.
Chris J.
GoVacuum.
Apr 06, 2010 | Vacuums
REPLACEMENT FILTERS FOR THE POWERFORCE 6 BAGLESS VACUM.IS THERE A BISSELL STORE IN THE DETROIT MICHIGAN AREA I CAN FIND BISSELL BELTS FILTERS ETC.
Here are Bissel's numbers, they can tell you who to contact.
Service Center Dept. Phone Number:
(800) 457-1509
Service Center Dept. Fax Number:
(800) 517-9535
Hours:
M-F 8:00 a.m. - 5:00 p.m. ET
Aug 10, 2008 | Bissell Vacuums
Open Questions:
Vacuums Logo
57 people viewed this question
Top Bissell Vacuums Experts
Jim Thurston
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
