Question about Husqvarna 20HP Hydrostatic 42" Cut Riding Mower
Wont start. where is main fuse located? or could it be another prob?
  • 718 Answers
There is another problem.
Posted on Mar 12, 2011
Where is the main battery fuse located on a 1998 BMW Z3 1.9 liter
from memory there is no main battery fuse what is the prob? sounds like you have a bad main battery earth lead connection problem check that first
Nov 14, 2017 | BMW Cars & Trucks
My camry 95 wont start doesn't even turn the switch key light on no power what so ever.... heelp!!!!
It sounds like your main fuse has blown or the power main relay has failed.Check the 40A and 30A fuses in junction block 2, and the power main relay in block 1. See here p10-11
http://www.turboninjas.com/camry/be.pdf
Jan 05, 2013 | Toyota Camry Cars & Trucks
Trying to find the location of the fuel pump relay in a 1997 4cyc outback looked under driverside dash but didnt find it
most fuel pump relays are located in the main fuse box,under the hood. look for a black box on the drivers side,or passenger side fenderwell under the hood. lift cover off and look on underside of the fuse box lid for location of the fuel pump relay and main engine fuse.hope this helps and thank you for choosing fixya.com
Jan 29, 2011 | 1997 Subaru Outback
Put a new starter in and cleaned terminals. but it still does nothing.it wont start
have you checked your battery terminals? are they both tight? try to boost it from another car. if it starts from a boost,it may be a bad ground. do your headlights come on? it may be a bad fuse in the main fuse box under the hood.black box,lift cover,under the cover you will see locations of the main fuses and relays that operate the main components of your engine. look for blown fuses 1st then move on to check for bad relays[the square black box like components in the main fuse box] hope this helps and thank you in advance for choosing fixya.com
Jan 22, 2011 | Dodge Ram Pickup 2500 Cars & Trucks
My dryer wont start or turn on at all
When the dryer wont start it is the thermal fuse that is bad, you can test it with a voltmeter before replacing. This fuse is located inside the rear panel and it cannot be reset. If the fuse tests fine then it is the main board that has gone bad & you will have to replace it to solve this issue.
Hope this will help...
Dec 31, 2010 | Dryers
02 suzuki volusia wont start battery good but nothing happens when key turn to start
Check your fuse box, your main fuse is probably blown. Some times the main fuse is located on or by the starter solenoid. If all the fuses are good you may be having problems with a dirty or broken contact base on your ignition switch.
Sep 03, 2010 | Suzuki VL 800 Volusia Motorcycles
Got s,reg nissan mirca turns over but wont start never had prob before any ideas what might be wrong batt fine ,spark good
fuel pump, fuel pump relay or fuse, or crank sensor.
the crank sensor is located near or behind the main bottom pulley on the front of the engine. it is a very likely problem and is usually an easy replacement, but the fuel pump and its fuse & relay could be the next most likely problem.
Oct 24, 2009 | 1993 Alfa Romeo Spider
Washer wont start
your vent is prob. stoped up so the dryer got to hot a blew a thermal fuse..it is located at the top of the element housing
Apr 12, 2007 | GE WSM2700W Unitized Spacemaker Washer and...
Husqvarna 20HP Hydrostatic 42" Cut Riding Mower Logo
123 people viewed this question
Top Husqvarna Garden Experts
Phil Walker
Phil Walker
Roland W VanLue
Roland W VanLue
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
