Please help me with this problem at my canon mp495 printer E02 flashing led and the printer dont load paper what can i do? thanks cristian
Roonie Tunes
  • 136 Answers
SOURCE: I am having trouble loading paper into my Canon MP190 Printer?
Try loading less paper AND try this trick:
Holde the stack of paper you are going to load with both hands... grip tight with the right hand and "bend" the paper like an arch. Then grip tight with the left hand, loosed grip with right, and "bend" the paper like a valley. Repeat this a few times to quickly seperate the individual pages so they don't stick together and thus jam in the printer!
Hope this helps!
-- RT
Posted on Sep 01, 2009
SOURCE: Printer won't pull paper into printer
Check the "Feed Switch" button on the control panel (below the ON/OFF button) to be sure the green light at the back of the picture is lit. If not, try pushing the button and then printing again. It worked for me and it was so simple!
Posted on Sep 07, 2008
  • 38 Answers
SOURCE: How do I fix error
Error P22 is a scanner error.
The only solution I can find is to replace the Scanner Unit and Logic Board.
Posted on Jan 09, 2011
  • 10406 Answers
SOURCE: how to install a canon pixma mp495 printer with no
CANON puts its device-drivers onto its web-site: http://www.canon.com
Click "Support" or "Downloads".
Enter your model-number.
Select your Operating System.
Download the device-driver.
Install it.
Print.
Posted on Feb 01, 2011
Testimonial: "You guys are awesome thanks"
  • 2340 Answers
SOURCE: Where can i find the serial mumber on my canon
PIXMA Printers and All-In-Ones
The serial number is located inside your PIXMA printer. To find it, open the printer lid as if you were to access the cartridges tray: the serial number is printed on a white sticker. Be careful to not confuse this number with the power supply serial number that can be found on the bottom of your printer.
Hope it helps.
Posted on Apr 26, 2011
How do I find ip address for canon pixma mp 495 printer?
Two links for you
Pixma MP495 Printer not detected - Canon Community
community.usa.canon.com/t5/Printer-Multifunction.../Pixma-MP495-Printer.../25583
  1. Cached
  2. Similar
May 26, 2013 - So I have a Canon Pixma 495 printer that worked great wirelessly ... Hi I have the Canon Pixma MP495 and I can't seem to find the IP address.
PIXMA MP495 Wireless Connection Setup Guide - Canon Europe
www.canon-europe.com/.../pixma_printer.../mp495_printer_wireless_connection_set...
  1. Cached
  2. Similar
This method is by far the easiest way of connecting your PIXMA MP495, so if your ... Press and hold the [Maintenance] button (A) on the printer for approximately 5 ... regarding pressing the WPS button, please refer to the access point manual.
ip address for canon pixma mp 495 printer Google Search
Oct 04, 2016 | Canon PIXMA MP495 InkJet Printer
What does E02 mean
PDF]canon printer error code e31.pdf - WordPress.com
https://maitioprolur.files.wordpress.com/.../canon-printer-error-code-e31....
... on Canon. Printer MP287 : E02 E31 Cause : The printer is not connected to the computer ( the printer is ... Canon Pixma MP287 All in One Printer List of Error Codes There ... Cartridge: Canon E31 Toner CANON Printer + Copier + Scanner -.
Aug 26, 2015 | Canon PIXMA Office Equipment & Supplies
My black ink button on my pixma mp495 printer is blinking. Why?
A B LED light denotes that the black ink cartridge is running low.
A C LED light denotes that the colour ink cartridge is running low.
If the alarm light is on (lightning bolt in a triangle) it should be accompanied by an error code.
Canon MP495 - Error Codes If the printer displays an error message, the following information should help to diagnose the problem.
The led screen on the printer will flash a letter E and will then be followed by two numbers:
Error Description More Info Error E02 The machine is out of paper or will not feed. Error E03 Paper jam or output tray is closed. More Info Error E04 The Cartridge cannot be recognised. More Info Error E05 The Cartridge cannot be recognised. More Info Error E07 Cartridge is not installed in the correct position. More Info Error E08 Ink absorber is almost full. More Info Error E13 The remaining ink level cannot be detected. More Info Error E14 The Cartridge cannot be recognised. More Info Error E15 The Cartridge cannot be recognised. More Info Error E16 The ink has run out. More Info Error P02 Carriage encoder error. More Info Error P03 Line feed error. More Info Error P07 The waste ink absorber is full. More Info Error P08 Print head fault. More Info Error P10 Print head fault. More Info Error 5100 Carriage Encoder error. More Info Error 5200 Print head fault. More Info Error 6000 Line feed error. More Info Error B200 Print head fault. More Info Error 5B00 The waste ink absorber is full.
Feb 24, 2015 | Canon PIXMA MP495 InkJet Printer
Flashing C button
E then 3 then 0 means that it cannot determine the page size of the document to be printed.
E then 0 then 3 means there is either a jam in the output tray or the door to the output tray is closed. This is the tray where the paper comes out after printing. Try closing and opening the tray. A sensor could be stuck.
Here is the link to the manual. http://www.usa.canon.com/cusa/support/consumer/printers_multifunction/pixma_mp_series/pixma_mp495#BrochuresAndManuals
Nov 25, 2013 | Canon PIXMA MP495 InkJet Printer
Canon pixma mp495
Hi
Try turning the machine off and on.
Completely disconnect the printer from power and then connect it again.
Turn it on.
Check through the paper paths for any obstructions or stuck papers and gently remove them.
Hope it helps.Thanks!
Mar 24, 2012 | Canon Office Equipment & Supplies
Canon pixma mp495 error
Solution 2 is correct there is either a paper jam, or somthing obstructing the print path. First check to make sure you don't see no paper jamed, if not look in were you would put the paper to see anything that may have fallen that is causing jam, gentel turn printer side to side to see if u see hear or see anything moving around. If u see nothing then somthing has surly has fallen in printer has gotten stuck in printer rollers more then likly. To find out what's stuck find a piece of thin cardboard, I used the front cover of my phonebook and push cardbord through printer and what ever is jamimg the paper should pop out on the other side. In my case it was a flower seed and I was able to use twizzer to remove and issue was resolved. Printer is working fine
Feb 25, 2012 | Canon Office Equipment & Supplies
Alarm light is on says I have paper jam but no paper
Hi Amanda,
Turn the printer off and on.Solved?
Disconnect the printer completely from PC and unplug from power.
Restart the PC and connect the printer again.
Try printing now.
Hope this helps.Thanks!
Please rate this answer.
Dec 12, 2011 | Canon PIXMA MP495 InkJet Printer
Canon pixma mp495 error E,1,6 .and light up at C
Hi there :The error E1.6 is :E, 1, 6 (LED display) The ink has run out. In your case that should be the Cyan cartdridge .I hope this helps you
Sep 03, 2011 | Canon PIXMA MP495 InkJet Printer
740 people viewed this question
jasbo
jasbo
