Question about Cardo scala-500 Wireless Headset
My scala 500 won't charge and or stay on - Cardo scala-500 Wireless Headset
My scala rider g4 detects iphone but does not pair
All I did was clear it from the phone and made sure I had a full charge on my scala. Then I just reconnected it. That was it. Once I had made sure I had the full charge that was it.. Done. Hope this helped. Regards, Denise
Jun 09, 2014 | Cardo scala 700LX Bluetooth Headset
The scala rider Q G A won't pair with my I Phone it keeps saying swich your scala on
The scala rider Q G A won't pair with my I Phone 4S it keeps saying nothing
Nov 10, 2012 | Radio Communications
Manual to CARDO scala 500 bluetooth
You can get the manual on the link below. scroll down to product detail to get it .
http://www.amazon.com/Cardo-Systems-500-Bluetooth-Headset/dp/B0006GFARG
Good Luck
Nov 22, 2010 | Cell Phones
Headsets won`t pair.
I am having the same problem. Did you ever find the solution?
Jun 02, 2010 | Rider Cardo Scala Q2 Multiset Headset...
How to connect with bluetooh
You need to:
  1. ensure the bluetoothicon1.png setting is turned on on the handset
  2. switch on the scala 500
  3. press and hold the scala 500 power button until the red and blue lights are both flashing (you have to hold the button in for quite a few seconds)
  4. now you can search for new bluetooth devices from your handset and it should find it to enable you to connect
  5. if it asks you for a code/passcode the default is 0000 for this headset
Sep 20, 2009 | Motorola Mobility Cardo Scala 500...
Can't get existing bluetooth headset to work with new phone
I had that problem when I changed handsets. You need to:
  1. ensure the bluetooth setting is turned on on the handset
Jan 27, 2009 | Cardo scala-500 Wireless Headset
PIN Number
Most of the time 0000 is the code. I hope this helps, Mike
Jun 10, 2008 | Cardo scala-500 Wireless Headset
Battery removal
Okay here's how to remove the battery:
1.Lay phone back up on a flat surface
2.You will see a tiny little tab that you can with your nail pull back that is like a safety release.
3.Then with your other hand grasp the two sides of the back and pull it off
Ta dah you did it
Aug 30, 2007 | Sanyo Katana SCP-6600 Cellular Phone
Cardo scala-500  Wireless Headset Logo
41 people viewed this question
Top Cardo Radio Communications Experts
Eric Sutherland
richie46
Tom Chichester
Are you a Cardo Radio Communication Expert? Answer questions, earn points and help others
