Question about Flowtron LE-800 Electric Leaf Shredder
I have an old Flowtron electric leaf shredder with a small hopper. The leaves won't **** into the grinder anymore. They stay stuck in the hopper. What could be wrong?
  • 718 Answers
You can't chop wet leaves, and is it plugged in?????
Posted on Mar 12, 2011
I am having problems putting the hopper back in the burr grinder
Sometimes my wife or I pull the hopper out before the grinder is totally stopped and then some coffe gets behind the hopper. Thre are a couple of small slots that hold the coffe and the hopper will not slide back all the way again...we then need to take a knife and clean everything out good before it will work again...
heatman101
May 02, 2010 | Solis Maestro Electric Burr Grinder
Flowtron LE-900D Leaf Shredder- Spinner flies off.
The screw is a common one, Make sure it is at least a grade 5 or grade 8. The o-ring may be another matter, but should be available at hardware and most definitely a hydraulic hose shop would have it.
Jan 16, 2010 | Flowtron LE-800 Electric Leaf Shredder
I can't remember the simple key to disassembling the Solis Maestro for more thorough cleaning. I need to get beyond the top burr removal stage.
Hi
Rotate the bean hopper counter clockwise until it stops. Lift the bean hopper out. Remove the outer burr with the wing-lets. Can go back in either way. Clean with air or vacuum out grounds. Use small brush to help clean grounds. Reinstall burr. Line up notches of the bean hopper with shell ( large tab in large slot, and small tab in small slot). Rotate bean hopper clockwise a small amount and test.
Nov 10, 2009 | Solis Maestro Electric Burr Grinder
It stopped as I was pushing leaves through it
there might be a red button (overload) on the motor.
Nov 07, 2009 | RTO Deluxe Electric Leaf Shredder
Machine has major problem with grinding beans.
Try removing all beans from bean holder - then use a vacumn machine to remove the bits down amongst the grinder "teeth'. You may have had a small stone in your coffee and if so it may have jammed the grinder.
Once it looks clean, try making a cup of coffee without the beans in the hopper - you should be able to see and hear the grinder revolving and also hear the brew unit moving between the grinder outlet and the water inlet. If it all seems ok now, then add a small amount of beans back into the beans hopper and try making a coffee. If it still will not work, get it serviced. There's not much the average person can do inside these units other than to do more serious damage or kill themselves with an electric shock.
Nov 05, 2009 | Saeco Magic De Luxe Espresso Machine
Flowtron LE 900, The Ultimate Mulcher, just quit
I found a reset switch on the leaf-chipper. I was then careful to fill it more slowly, and to keep out sticks and clumps of wet leaves.
May 28, 2009 | Flowtron LE-900 Leaf-Eater Mulcher
How do you intall the cutting string on a Flowtron leaf eater?
I have an electric weedwacker which may be different. In the leaf wacker there are four small holes very near the center screw on the revolving shaft. These holes form two small tunnels. cut two pieces of line (10-12 inches) and stick one through each tunnel. Center each line, put the two ends together and poke them out through the small hole on the edge of the rotating shaft. You end up with two sets of plastic line facing out from the central shaft. Flowtron may be different. Good luck.
Mar 23, 2009 | Flowtron LE-800 Electric Leaf Shredder
Grinder setting stops at drip. Can't turn further to espresso.
Another suggestion is while the grinder is off, turn it up side down and rotate the bean hopper from coarse to fine a couple of times. This will clean out grounds that have gotten into the threads and it will prevent the bean hopper from not turning to a finer grind.
If you start to get a clog in your grinder, open it up to a coarse grind for a few seconds. The coarser grind will clean out the chute and then you can turn it down again while it is still grinding.
Dec 15, 2008 | Solis Maestro Electric Burr Grinder
Flowtron LE-800 Electric Leaf Shredder Logo
121 people viewed this question
Top Flowtron Garden Experts
Dennis Key
Dennis Key
roeb
john h
Are you a Flowtron Garden Expert? Answer questions, earn points and help others
