Question about Toshiba Computers & Internet
Screen flickers and goes dark u can see the image if u shine a flashlight on it. what could be the problem ?
  • Toshiba Master
  • 1,606 Answers
There are a couple of Cold Cathode Fluorescent Lamp tubes behind the screen. They have probably reached the end of life. (If you had no flickering, I would suspect a failed inverter.)
Replacement requires disassembling the display housing, then removing a screw from the side of the display next to where the fat pink and white wires go in. On most displays, you can then slide the tubes and their reflector out of the display by pulling on the wires. Be very careful - the CCFL tubes are long, skinny, and very fragile, and they contain mercury. Tubes usually come bare, with short wire leads at each end. Soldering the old wires onto the new tubes is a delicate task best reserved for experts. Alternatively, you can buy replacement tubes with wires already attached for an extra $8 each. See this tech support link at LCD Parts for more details.
Posted on Mar 11, 2011
  • 1,940 Answers
It sounds like your LCD Backlight has burned out. You will most likely need to replace your LCD Screen, since you can still see a faint image.
I’m happy to help further over the phone at https://www.6ya.com/expert/jeremy_69f3cc28d95bf514
When I turn on my Sharp TV the picture comes on for a second then goes black. The sound is working but the picture stays black.
hi quick test, in a dark room shine a flashlight on the screen, if you a can see an image, bring the menu up if you can see it the led or leds in panel may blown, thanks
shaun
Feb 15, 2017 | Televison & Video
Toshiba 37xv555db no picture
Its a LCD set--try in a dark room (very dark) to shine a small flashlight at the screen with set on-------------do you see a very faint image or picture on the screen?
Oct 29, 2012 | Toshiba Televison & Video
Screen stays black when power comes on
Audio really does not matter here---in a very dark room shine a flashlight at the screen with set on to see if you see a very dim image on the screen or not.
Oct 29, 2012 | Proscan 32LB30QD 32 in. LCD TV
Monitor has power. Will come on very briefly and the go to black screen. Can turn power off and back on and get the same above result.After a 2-3 hour period may come to life...may not.
It appears as if the monitor's back lighting is failing. To test the theory, take a bright flashlight and shine it on the lcd monitor screen when it goes black. If you can see the images that were on the screen before it went dark while shining the flashlight on the screen, then the back lighting is failing. Depending on the monitor, it could have florescent or L.E.D. back lighting, but it's usually more economical to simply replace the monitor with a new better performing monitor, than to attempt repairing the back lighting on the failing monitor.
Dec 01, 2010 | Samsung SM225BW 22 inch LCD Monitor
Flickers, then goes black. If you shine a
It is definitly an inverter of the monitor take it to the nearest service center and they will replace it.
May 08, 2010 | Toshiba Satellite A205-S5812 Notebook
Had my monitor for four years, great performance
jlallen54, When lcd panel goes to a dark condition please shine a bright flashlight 1 inch from screen an tell me if screen data is still displayed during this "blackout" condition. It might be just a single (1) poor and now thermally intermittant solder connection on the printed circuit board inside the monitor. Do some reading first and then you will understand the problem that your monitor has. 12fixlouie
Jan 17, 2010 | Sony SDM-HS73P 17" LCD Monitor
The Screen is Dark and Cannot be Bright by the Brightness Keys. It Flickers when it first comes on but goes Dark. Can see it if you shine a Flashlight on the Screen. Also the Lid Switch if you Press that...
Assuming all of the connections are secure this is most likely due to a failing LCD inverter which is basically the backlight of the screen. If it's less than a year old cash in on the manufacturer's warranty. If it's not you might as well buy a new one. Hope this helps.
Apr 13, 2008 | Computers & Internet
Monitor is Flickering and screen becomes pink
Hi this is the way how to examine what's wrong with your LCD monitors. Power on both CPU and monitor. After it goes back to white, you have to check that if you can see the image on the screen or not by shining a flashlight into the screen, not directly but find the best angle to the screen and take a look very closely. If you can see the icons or any image, there will be a minor problem. I used to check my LCD monitor and could see window image using flashlight and found out that Some of CCFL lamps inside were broken and it is very easy to replace. If you cannot see anything on the screen, there'll be some problems with inverter board. If you have soldering tool and want to fix it by yourself, check the caps first. It may cause this problem. Some caps might show leaking or burn spot on the board because of too high temp. If you don't have soldering tool, you better go get a technician to do so.
Thank you,
Tan
Mar 10, 2008 | Acer AL2017 20" LCD Monitor
Dim picture
This is the way how to examine where the problem is. If the screen is going dark. You have to check that you can see the image on screen by shining a flashlight into the screen, not directly but find the best angle to the screen and take a look very closely. If you can see the icons (Power on both cpu and monitor), there will be a minor problem. Like me, I can see window image using flashlight and check lamps inside. Some of them were broken. If you cannot see any icon on the screen. I would say that there are some problems with inverter board. If you have soldering tool and want to fix it by yourself, check the caps first. It may cause this problem. Some caps might show leaking or dark spot on the board because of too high temp. If you don't have soldering tool, you better go get a technician to do so.
Feb 09, 2008 | Dell E176FP 17" LCD Monitor
Open Questions:
Cloud Backup For Small Business 'Dataalign We understand the difficulty of reaching a great quality tech support at time. We all have gone through the phase of struggle when we have to look for reliable tech support in affordable prices. Toshiba support is now available at just a click away or just a phone call away on toll free helpline number. Toshiba support by well-informed and erudite experts who have made it a mission of their lives to provide best tech support for their customers. Customers have shown over whelming response to Toshiba tech support as it a one and only needed platform for all tech issues faced by the customers ever. Toshiba support provided by TechFree has always gained appreciative remarks from customers. They have always been praised for their hard work and dedication over the years which has resulted them in gaining a lot of fame for their work. Toshiba customers face many type of issues like dealing with their slow performing Toshiba devices, treating issues faced in Gmail, yahoo or any other email supporting site, networking issues, software not working issues, issues with viruses, malwares and issues in printers, routers or other relatable peripheral devices. These issues and many more are professionally resolved without much delay. Tech support professionals of Toshiba support use their knowledge and experience of years and together with highly advanced technologies to resolve issues of their customers in the right way. They get highly acclaimed by their work and the way they treat their customers with respect and courtesy. They make sure to patiently listen to their customer's issues in order to be able to understand the issue in depth and provide right type of support for longer lasting effects. Tech support of Toshiba can be reached via the toll free helpline number +1 888 784-9316 and they assure to be assisted by expert tech support executives. These executives work 24/7 throughout the year. They also provide 30 days money back guarantee and free device check-up along with free online data backup. For any type of tech support or computer repair services at any time of the hour call on toll free helpline number +1 888 784-9316
Jul 05, 2018 | Toshiba Computers & Internet
Computers & Internet Logo
166 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
