Question about Bosch Dishwashers
Model SHU33AO2UC /40 The top rack leaves lots of residue and stuff on glasses. We had a repairman out, he cleaned out the pump intake, and we are careful to clean everything before putting it in the dishwasher. I have made sure all holes in the spinners are clean and don't crowd the glasses. We have also tried different detergents. The dishwasher is 4 yrs old and is used daily. We also use jet dry.
    Top Expert:
  • Bosch Master
  • 21,443 Answers
Lack of salt causes this.
Posted on Jul 31, 2017
  • 641 Answers
SOURCE: dishwasher leaves residue in top rack only
Most cleaning problems are caused by the dishwasher not getting enough water. It could be cause of the switch level, which control water level in the tub. The switch level is usually a diaphragm device with a small clear tube attached between the switch and the bottom of the washer's outer tub. I am not familiar with your machine, but if you will open the rear panel you will find it easily. Be aware you should discoonect the power cable !!! Clear the tube (attached between the switch and the bottom of the washer's outer tub) from any obstruction.In case it will not solve the problem, you should replace the switch. Good luck !
Posted on Jun 01, 2006
aborcass
  • 2651 Answers
SOURCE: top rack not cleaning
load 4 cups right side up in all four corners of top rack, move all wash arms to a known positon(pointing foward just want to check there rotaiton). start diswasher, when you hear it start washing give it 30 sec or so andpop it open try to focus on middle spray arm when opening, shlould be turning quite well. and glasses sould be starting to fill. at least thats how it SHOULD operate
Posted on Feb 26, 2008
  • 677 Answers
SOURCE: GE Profile Dishwasher (5 years old); Leaving residue on dishes
There is a new product out that actually filters the water going into your dishwasher. My dishes came out amazing after the first load. No more cloudy glasses. I was very impressed. Who knows whats in the water cleaning your dishes so i thought this filter was great. It is very affordable and you can get it at www.dishwasherfilter.com. Hope this helps some people.
Posted on Jan 06, 2009
SOURCE: Bosch dishwasher
Although I previously posted with the same problem of a film on the dishes after cleaning, I did find a section in the owner's manual which solved my problem. Lift up the rinse aid cap on the inside door - the factory setting is on "4". The rinse aid works in conjunction with your local water, which has variations in it's hardness or softness. When your dishes are streaky, lower the rinse aid setting to 1 or 2. If your dishes are spotted, raise the rinse aid setting higher.
Posted on Feb 20, 2009
  • 38 Answers
SOURCE: whirlpool built-in dishwasher - has
Yes, you will need to purchase a set of torx style screw drivers at your local hardware store. Remove the upper and lower spray arms and clean the debris out of the spray holes. Remove the screws that hold the filter in place and remove the gunk out of the sump. In the future stop using gels or gelpacks, just use electrasol powder or cascade powder. The gels and gelpacks clog up dishwashers like you would not believe. Run some Lemi-shine through the machine on a monthly basis, Lemi-shine is available at most walmarts.
Posted on Feb 23, 2009
The dishwasher is not cleaning the plates and glasses as should, leaving a lot of residue on everything
It sounds like water isn't being forced through your spray lines, which could be a result of either you trap being clogged or the sump pump not working. It could also mean that your heater element isn't heating the water hot enough for it to clean.
If it only the upper rack then it could be a blockage for the upper sprayer, but if it is throughout the machice, then it would either be the sump pump, trap or heating element as the most likely causes.
Jul 03, 2011 | Dishwashers
Dishes aren't clean, lots of white dried on stuff on top of glasses and dishes
The problem is most likely that there is still water residue at the bottom of your machine. If the machine is not fully drained it picks up some of the residue and sprays that onto the dishes during the final rinse, leaving an unhealthy and unsightly film on everything.
Remove the bottom strainers plates and make sure that the outlet pipe is not kinked, that there is nothing obstructing the pipe or the pump or selector valve. If possible back flush through the outlet pipe and try draining the machine once more before using it again.
Jun 29, 2011 | Dishwashers
Residue has been remaining only in the glass glasses on the top rack
Remove the bottom strainers and make sure that there is nothing obstructing the outlet pipe and the pump. If possible back flush through the outlet pipe and try draining the machine again before using it again.
Feb 19, 2011 | Dishwashers
Hello, Recently my dishwasher has been leaving particles of food residue in glasses or other glass items. This is a particular problem when using the top rack, but the problem sometimes is also on the...
The scum, film and white residue problems have started since the reduction of phosphates in dishwasher detergents.
Here is a tip that will help you to solve the problem of films, residue, and scum in your dishwasher.
Dishwasher Residue and Film on Dishes
heatman101
Jul 05, 2010 | Bosch 24 in. SHU43 Built-in Dishwasher
Leaving residue in glasses in top rack mostly have taken out the spinning arms and cleaned them out.
check the filter down in the pump. if that is clear you probebly have a bad water intake valve
Feb 26, 2010 | Kenmore 15892 Built-in Dishwasher
My dishwasher is leaving a lot of residue on dishes
I had the same problem and fixed it by disassembling the lower spray arm and return filter, and cleaning all the junk out.
Most dishwashers have 'risers' that bring the water up to the top sprayer or arm located under the top rack. If the recirculating pump is plugged even a little there won't be enough volume or pressure to get the water up there.
Test this by putting a dry muffin pan in the top rack, flat, and running the dishwasher for a bit. If there is no water on the top (or the bottom) either the top sprayer or the sprayer arm underneath the top rack is not getting enough volume.
To fix this you need to clean out the screen and filter, where the water returns to be recirculated. If you don't have any confidence to remove the parts and clean it out yourself, get an appliance repair person to do the job.
Aug 26, 2009 | Dishwashers
Kenmore Dishwasher not cleaning dishes - especially top rack.
put a pump kit in the dishwasher..and the water coming up is a house drain problem
Aug 06, 2009 | Kenmore Elite 45986 Front Load Washer
Whirlpool Gold dishwasher
Either:
  1. not enough water gets into the dishwasher. check water valve, water level float and water pressure.
  2. the pump is clogged - there is water, the motor will run but no water is circulated. Check pump filters, check chopper and impeller.
Good luck,
Vlad
First Choice Appliance
Mar 21, 2009 | Whirlpool GU2700XTSB / GU2700XTSQ /...
Dishes not getting clean
the problem is hard water leaving the residue. go to www.dishwasherfilter.com and get the dishwasher filtration system. it will reduce the hard minerals that leave the residue and your dishes will be clean as can be. it is very affordable and fits right under your sink.
Mar 10, 2009 | Maytag MDB6000 Dishwasher
Dishwasher leaves residue in top rack only
Jun 01, 2006 | Smeg 18 in. DWF410SS Slim-Line...
Dishwashers Logo
77 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
