Question about Kenmore Sewing Machines
Model no. 158.17741. the belt is moving, the motor is running, but the part that goes up and down with the thread is not, the belt seems to be tight enough
  • Kenmore Master
  • 1,388 Answers
Check the centre of the handwheel, there will either be A) an inner wheel or B) push/pull device to disengage the needle arm when bobbin winding....it needs to be A) tight, or B) pressed in to re-engage the clutch for sewing......your manual will probably have a diagram,
I could not find a picture of this model, so unsure of the exact mechanism, but it is in the middle of the handwheel
Posted on Mar 11, 2011
Machine running very slow . Does it need serviced ?? Is it machine problem or foot pedal problem ?
take it in for a service as slow machines can be from thread and fluff jamming the shafts , foot control or motor problems
Nov 21, 2015 | Janome Memorycraft 6500P Computerized...
Every time i step on the foot control the needle goes down to sew amd stays stuck and all the lights are bleenking it wonr sew!! Some one Please Help Me
1. If the machine will move smoothly by turning the hand wheel this means your machine is free.
2. When the machine is on it's way down does the needle hit the side of the hole in the throat plate? If yes you will need to adjust it so it doesn't do this. There are a lot of "how to's" over the internet.
3. Take the bobbin assembly out and try the machine without it. If it moves freely then the assembly needs to be adjusted or the machine needs to be timed. The assembly on most top bobbin load machines must be set so it doesn't move around. There are screws there (two). If it is set so tight to not move this is a problem also. So give it a little slack that a thread can go through with ease.
4. If your belt is out of alignment this could be a real problem with power of the motor being used. Uncover the belt that goes to the motor. Once you have done this so you see the belt try the foot pedal so the motor moves slowly. Loosen the bolts on the motor. Step on the foot control slowly and move the motor around until it moves with the most speed easily. This will adjust the belt in just the right point. Be careful though!
Jun 26, 2015 | Sewing Machines
Janome hello kitty 525 won't feed fabric or needle does not move up and down. Everything seem to be thread correctly and clean.
Hi Thi: make sure the machine is not set to wind the bobbin. Turn the handwheel towards you and see if the needle moves. You may have a belt that has come off. Does the machine make noise like the motor is running when you press the foot control?
Sep 02, 2013 | Janome Sewing Machines
How do I get Featherweight out of first gear?
Hi, unless you have thread caught up in the hook area the problem may very much be that the belt is too tight. It should be seemingly loose or just tight enough to turn the machine. There is a big screw to the motor mount. Loosen the motor and adjust it to loosen the belt. Belt too tight and slowing machine is common issue.
Rick
Jun 06, 2012 | Sewing Machines
I have the Janome 6600 P. Beginning a seam the thread knotted and the machine made noise and needle would not move either up or down. I manually moved the needle using the handwheel and cut away the...
Replace the needle.
The tension on the bottom may be too tight(loosen) or the top tension may not be tight enough (tighten). Try to fix with the top tension being tightened first.. Move the hand wheel first for a couple of rounds. If it is still a problem the bottom tension will need to be loosened. Always make sure all of the old threads are cleaned out thoroughly. Now, here is a problem chart to look at if this isn't a fix.
E5: The machine is jammed or the foot controller is defective. A. Replace the foot controller. B. Check for a tight or stuck clutch by the hand wheel. C. The machine may be jammed. Remove the timing belt to locate whether the bind is on the upper shaft or lower shaft. If it is the upper shaft, there may be thread caught in the take-up lever or crank pin. If the lower shaft is binding, check hook clearance, hook backlash. D. If you continue to have the problem, loosen the screws that hold the metal, lower shaft supporter. While the machine is running slow-to-medium speed, tighten the screws. E. Clean the sensor on the DC motor and check if the shield plate on the motor is not loose or hitting the sensor. If either the sensor or shield plate is damaged, replace the motor. F. Check the lower shaft sensor. Make sure the shield plate is going perfectly thru the middle of the sensor. Replace the sensor and/or shield plate if damaged. G. If you still get the error, replace the DC motor or lower shaft sensor (in this order).
Apr 15, 2017 | Janome Sewing Machines
Needle will not move..motor runs fine when pedal pushed down, but needle will not go up and down. Not in ''bobbin mode'' and knob is pushed in. (Sorry, still a beginner with all this, so I don't know all...
Check that the belt is tight, make sure you do not have any thread stuck in the machine, take the bobbin case out and the raceway completely to check
May 27, 2010 | Kenmore 15343
Machine stopped sewing
The thread is caught in the hook...Remove the upper thread and bobbin case, turn the hand wheel backwards and forwards by hand and remove the thread remands. Good Luck
May 28, 2009 | Sewing Machines
1968 kenmore sewing machine
belts and oil it in any point that has metal to metal
Oct 02, 2017 | Sewing Machines
Old kenmore sewing machine model # 1237 ( not found in search) - prob. purch.'d in 198o's
Check the handwheel. If it is pulled out, the clutch is not engaged. Try pushing it in! (It would be really nice if the solution is this easy!)
Sep 08, 2008 | Kenmore 15516 Mechanical Sewing Machine
Sewing Machines Logo
94 people viewed this question
Top Kenmore Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Kenmore Sewing Machine Expert? Answer questions, earn points and help others
