Question about Dyson DC07 Animal Bagless Upright Cyclonic Vacuum
I havethe first generation purple Dyson Animal model. The brush rotates fine, but doesn't make sufficient contact with the floor/carpet, therefore does not pick up most items on carpets (suction still works however). If I put my foot on it and push down a little, it works. However, since I'm not an accomplished acrobat, this is not easy to do. :-) Any suggestions on whether this is fixable? Or should I just save up to buy a new one?
  • 7 Answers
SOURCE: I have a Dyson Animal. Roller bar won't turn/belt intact
Actually, I'm the poster who said I have the same problem, but it turns out I have the DC07 animal, not the DC14, but perhaps the solution is the same for the DC14 and it doesn't cost anything! I called DYSON and they told me the clutch needed to be reset, so she had me recline the vacuum from its upright position, lay it on it's side, turn the carpet/bare floor dial slowly back and forth between the two settings about 6 times and it apparently reset the clutch and now the cleaner bar spins normally and there's no more loud grinding-type noises. She said if that didn't work, the next step would be to remove the bottom protective panel (secured with the three large plastic screws) and lift the entire cleaner bar (do not remove the belt) out about an inch or so and then reinsert it and reattach the bottom plate. I hope this helps your problem. Good luck.
Posted on Apr 18, 2009
  • 389 Answers
SOURCE: My dyson vacumn is hard to push on carpeting. How do i fix it?
This happens when the bristles in the brush roll get worn down too short. Put in a new brush roll and the machine will pull itself over the carpet, so you hardly have to push at all.
Posted on May 19, 2009
  • 5 Answers
SOURCE: Replace dyson 07 animal brush roll assembley
The end caps of the brush assembly which contain the bearings are only a push fit onto the spindle (quite tight). Remove these and the brush bar will pass through the drive belt loop. To achieve this the belt has to be stretched slightly so care has to be taken not to over-stretch what might be a belt getting to the end of its life. When refitting the end caps do not forget to aline them properly so they fit into the sole plate recesses correctly.
I cannot see at the moment how to replace the drive belt on the DC 07 without significant dismantling (that will probably be my next job) I do not see the use of the Dyson tool you offered.
Posted on Oct 27, 2009
Vac Belts
  • 701 Answers
SOURCE: Older Dyson 07 Animal, loud ratcheting noise on carpet setting
That is an indication that the belts are worn, stretched or broken. You simply need to replace the belt. Here is a link to the belt(s) you need and a manual you can view:
Dyson DC07 Belts and Manual
Posted on Dec 05, 2009
askdyson
  • 2572 Answers
Official advice and support for Dyson technology
    Verified Fixya Pro
    SOURCE: The carpet brush on my
    Hi there, it's Jack at Dyson.
    DC25 doesn't include a dedicated reset switch - instead, the reset mechanism is built into the main on/off and brush control switches.
    Once you've checked the cleaner head for obstructions and removed any threads or hair from around the brush bar and endcap, you should be able to resolve your issue by following the simple steps shown in our support video guide: https://www.youtube.com/watch?v=q--faamcC7g
    If you're still having difficulties, please get in touch with us, free, on 08002980298 (UK), or 1866MYDYSON (US), so we can run through some checks over the phone.
    Posted on Jun 09, 2011
    Dyson dc44 animal cordless handheld brush not turning but suction fine what can it be
    remove the brush from the enclosure. use a quarter rotate the cover, pull out the brush and clean any debris. operate the unit before installing the brush to see if the device in fact operates as designed. if not replace the unit, if so install the brush and bust out laughing!
    Aug 13, 2016 | Dyson DC44 Animal Cordless Vacuum
    How to Turn off beater bar
    DC44's brush bar is engineered to rotate on both hard floors and carpeting. The brush bar includes stiff nylon bristles to agitate and remove stubborn dirt and pet hair from carpet, and anti-static carbon fibre filaments to remove fine dust from hard floors and crevices.
    For this reason, the brush bar is designed to run on all floor surfaces when the machine is in use, and cannot be turned off. You might find our Getting started guide useful:
    I hope this answers your question, but if there's anything else we can help you with you're welcome to contact our experts directly on 0800 298 0298 (UK), 1-866-693-9766 (US), 1-877-397-6622 (CA) or 1800 239 766 (AU).
    Aug 21, 2014 | Dyson DC44 Animal Handheld Vacuum Cleaner
    The Dyson DC25 grips new carpet. How can I adjust the brush height
    Like most Dyson upright vacuums, DC25 is engineered to adjust automatically to different carpet piles, without stopping to adjust any fiddly levers or dials. You can also turn the rotating brush bar off to clean hard floors and delicate rugs - just press the silver brush control switch next to the red on/off switch.
    If you're having difficulty using your DC25 on a particular type of new carpeting, we'd recommend checking directly with the carpet manufacturer for their advice. They should be able to recommend the best way of caring for this flooring.
    For any additional assistance from our experts, you can reach us by calling 0800 298 0298 (UK), 1-866-693-9766 (US), 1-877-397-6622 (CA) or 1800 239 766 (AU).
    Aug 10, 2014 | Dyson DC25 Animal Bagless Upright Vacuum
    Install brush bar dyson dc14 animal
    Check the belts, it sound like you have a broken belt or a belt you didn't not reconnect
    Feb 05, 2018 | Dyson DC14 Animal Bagless Upright Cyclonic...
    Dyson dc14 brush bar is not turning at all. Everything else seems to be fine. I just replaced the brush bar but still no movement. What else could it be?
    I'm sorry to hear you're having difficulty with your DC14 Animal. If the brushbar doesn't rotate, please check you have the brush control set to 'Carpets', not 'Hard floors'. The brushbar will not rotate when the machine is standing upright, so please recline it into the vacuuming position before testing it.
    If this doesn't resolve the issue, please give our Helpline a call on 0800 298 0298 (UK), or 1-866-693-9766 (US), so we can provide further assistance.
    Best wishes,
    Jack
    Dyson Online Customer Support
    http://www.dyson.com
    Mar 24, 2012 | Dyson DC14 Animal Bagless Upright Cyclonic...
    How do I reset the brush bar please
    If your DC14's brushbar doesn't seem to be rotating as usual, please follow the steps shown in our online support guide to make sure everything is correct with the machine:
    http://www.dyson.com/support/help.asp?article=668&product=DC14-ALLFLOORS_US
    Please note, the brushbar will never rotate when the cleaner is standing in the upright position, or if you've set the brush control to 'Hard floors' instead of 'Carpets'.
    I hope this helps - if you'd like any further assistance or advice, please call us on 0800 298 0298 (UK), or 1-866-693-9766 (US).
    Best wishes,
    Jack
    Mar 01, 2012 | Dyson DC14 Animal Bagless Upright Cyclonic...
    Just purchased a reconditioned model. Makes a ton of noise and the bottom brush doesn't seem to turn like in my old Oreck. Does that indicate it needs a new belt?
    Your Dyson does have a belt but its one that cant be replaced it is called a clutch assy. if your roller brush isnt spinning then it could be that you dont have the purple knob on the left hand side if your facing the vacuum to the carpet setting. if you do have it on the carpet setting and its still not spinning then your clutch need to be replaced.
    dyson roller brushes donot rotate as fast as Oreck roller brushes. in fact they are rotate at about half the speed. so keep that in mind.
    Apr 17, 2011 | Dyson DC14 Animal Bagless Upright Cyclonic...
    Brushbar not spinning
    did you make sure that the dial is set to carpet if you have a dyson animal then the dial will be purple and on the right side or the vacuum make sure it is in the carpet posistion
    Jun 24, 2009 | Dyson DC07 Animal Bagless Upright Cyclonic...
    The brush bar on my Dyson DC17 stopped turning.
    If this model has a brush control - i.e a roller at the side of the model which controls brush to spin or not, then its a protected brush model - therefore even if the drive belt is intact the Dyson would have to be repaired by a service personnel or professional. The brush protection isn't able to be taken apart and sounds like it may well have slipped off due to tension.
    Mar 31, 2009 | Dyson DC14 Animal Bagless Upright Cyclonic...
    Dyson DC07 Animal Bagless Upright Cyclonic Vacuum Logo
    63 people viewed this question
    Top Dyson Vacuums Experts
    AskDyson
    AskDyson
    Samyfam
    Samyfam
    Are you a Dyson Vacuum Expert? Answer questions, earn points and help others
