Question about LaCie (300770) 250 GB Hard Drive
How do i transfer my data from my old la cie 80 gig 107443, to my new la cie 250 gig 300770? both boxes look the same, with the same connections [firewire, usb, 2 others].
  • 1,548 Answers
Connect both drives to the computer at the same time. If you don't have enough USB ports, connect one to a USB port and the other to a Firewire port. Open a file management window (Explorer in Window, Finder in Mac OS) for each drive. Click and hold the left mouse button (only mouse button on most Mac models in the window for the 80 Gig drive and drag across several folders/files to select them. Release the mouse button, then click on and drag the selected group to the new drive window. When this copy operation is done, repeat with another group of files.
You could select (-A or -A) and drag everything on the old drive at one time, but sometimes the system will bog down on copying large amounts of data (greater than 4-8 GB at a time).
Posted on Mar 11, 2011
How do I transfer from my la cie to my computer
Remove the USB module from the LaCie Write Card and plug it into a free USB port on your computer. Your computer should assign a new drive letter to the USB module (such as D: or higher letter). In Windows use Windows Explorer (on a Mac use File Manager) and you will be able to copy files from your LaCie USB module to your computer.
https://www.lacie.com/download/datasheet/DS_WriteCard.pdf
Sep 25, 2014 | LaCie La Cie 131057 Write Card Flash Drive...
Can i replace 80 gb hd with 500 gb harddrive?
Of course. Get a transfer cable to move the 80 g data to the 500g then remove the 80 gig and plug the cable from the 80 g into the 500g.
Jun 29, 2012 | Apple Power Mac G5 Desktop
My old 40 gig ps3 died, so we bought an 80 gig, but when 40 gig hdd is inserted in place of 80 gig hdd, it wont accept the hdd, and i had 9 months worth of saved games on 40 gig hdd. how do i get game...
Unfortunetly the HDD's can't be swapped like that. The only way to get the old stuff is to some how get the 40gb working so you can back up your system. Tell me what happend to the 40 and I might be able to help you get it up long enough to back it up so you can get all your stuff transfered. Another way is if you can get the 40gb machine to work the PS3 has a mode to hook a CAT5 cable from the new to the old and transfer that way.
A little more on the HDD swap. The HDD's are machine spacific and can only be recognized by the machine they were in and any other PS3 you try to put them in won't recognize the device without a format will saddly enough wipe the drive clean.
Let me know what's wrong with the 40 and I will see if I can help getting it back up so you can get your saved stuff off of it.
Sep 25, 2011 | Sony PlayStation® 3 (80GB) Console
My external La Cie 500Gig HDD has worked well for 3 years or more. Now when I connect it (via USB as aI have always done) ..The following happens: 1 I see the drive usually but not always under "My...
your drive has failed at either the power supply level or internal hard drive level.
First, please verify your power supply. When plugged into the power outlet, it should be silent. A defective power supply will hiss or have a high pitch noise to it. If it is defective, replace it and check if the issue is resolved.
If the power supply is silent, one or both of the internal hard drive is failing. If no data is needed, you can either replace the defective one which you will have to isolate by connecting the internal hard drives to a computer or with another enclosure and running a block scan software like hdTune which is free to download. The other option would be to scavenge the healthy drive and use it in another enclosure or inside the computer directly.
If you need the data and the problem was not the power supply, you will need to contact a data recovery center.
Regards,
Jan 07, 2011 | LaCie Big Disk 500 GB Hard Drive
Help transferring files from computer hard drive to La Cie
Well you can ONLY transfer/Move DATA as Programs and Documents & Settings and User Directories, cannot be shifted at all. So It is only the Files and Data that can be Moved off a drive. To gain space back, Right Click on the HDD, go to properties, in properties Under the general, tab the first window, select disk cleanup, remove everything in those boxes and after, that look under Tools tab, & do a disk defragment. This may get you space back. If not you may have to get a new bigger drive, and clone your old drive, then install the new drive and reinstall the Cloned image back onto the new drive?
Mar 30, 2010 | Computers & Internet
Data transfer between PCs
The easiest way is with a USB data transfer cable. You just plug it into both computers, run the software and select the data to move. The sit back and in just a few minutes the data is moved. You should be able to get the cable from a local computer store, if not contact us at the address below. We have them available for shipment to you, they run $18.00 plus shipping.
I hope this helps, if so please rate our solution.
Buddy
Corporate Computer
www.ccl-la.com
tech@ccl-la.com
Dec 14, 2009 | ATI POWERED BY RADEON 9200SE 128MB DDR...
New 360
Your old 20 gig will work with your new xbox, the hard drives are compatable no matter how old the 360 is. You can transfer all the stuff but you will have to call xbox and get a transfer kit. Its an adapter so you can attach both hard drives to the same xbox and a disc that runs the program. call 18004MYXBOX and tell them you want one. They are free and you will get it in the mail in around a week.
Oct 20, 2008 | Microsoft Xbox 360 Console
Powerbook g4 - la cie 500gb doesn't mount.
no, but why not ask La Cie? They have pretty good support, and if your computer isn't recognizing it, you can feed them all the information they need by downloading a freeware program called Balarc advisor, which not only tells you everything in your computer, with model numbers for hardware and all of your software (with their unique codes), but will also inform you if you are missing any needed Windows updates. Once you know what you have, go to
http://www.lacie.com/support/faq/faq.htm?faqid=10338 You may need to download something from them for your poswerbook different from your g5..
Feb 29, 2008 | Computers & Internet
La Cie External Hard Drive 160 gig
A clicking noise from a harddrive is defenenly NOT a good thing. It usually means that the harddrive is going bad.
Nov 17, 2007 | Computers & Internet
sounds like hd is getting hot via firewire try and use the usb lead if same problem then get your files off quick and repace drive any thing above 80 gig will get hot in use that's why I use harddrive coolers on my large 300gig 400gig internal and only use my 250 gigs and 160 gig only when i need the files off they are turned off all time
Jun 07, 2007 | LaCie (300740) 160 GB Hard Drive
LaCie (300770) 250 GB Hard Drive Logo
125 people viewed this question
Top LaCie Computers & Internet Experts
Raj Patel
Tony
Are you a LaCie Computer and Internet Expert? Answer questions, earn points and help others
