Question about American Standard 6034.STE5.002 Chrome Rain Sliding Door
My sliding patio door will not unlock - American Standard 6034.STE5.002 Chrome Rain Sliding Door
  • 718 Answers
Spray some WD-40 in the lock and see what happens, if that don't work find a big red brick and throw it at the door!
Posted on Mar 12, 2011
  • facemirej08 Mar 29, 2011
    if that don't work make sure that your latch isn't bent and your latch lines up with the catch
Rumbling noise when open close a glass sliding patio door
plastic rollers and dirty running track
take door off ... clean the track
may have to replace the rollers
Mar 05, 2017 | Cars & Trucks
Crossly turntable/cd tape player
If there's a small hole in the front of the door anywhere, push a paperclip in there to release the door.
Mar 04, 2014 | Slide-Co Sliding Glass Patio Door Latch...
What is benefits of sliding doors?
There are several benefits of sliding doors. I have shared 3 main benefits of sliding below.
1. Size of the door- The large size of the door is one attraction of the sliding door.
2. Space- You don't need to spare huge space in your home to install these doors. On the other hand, as the doors do not swing open and close, you can confidently place the art crafts near the door.
3. Transparency- Sliding doors are always the best ones to be installed in your patio. For you to enjoy the beauty of the surrounding landscape, no other type of doors would be apt like glass sliding doors.
For more information about sliding doors. I would like to refer at http://www.lghausys.com/in/product/windows/124nd_sliding.jsp
Oct 26, 2013 | Cars & Trucks
Why are patio doors most convenient for renovations?
Patio doors are the most convenient product available for renovation on the market today. They also happen to be one of the most secure options available. Standard tempered glass and multi-point locking for the highest levels of security for a door opening. Patio doors are also affordable because of standard sizes such as five and six feet. There are numerous options for patio doors including grills, colors, custom sizes, locks, glazing and blinds.
Jul 15, 2013 | Heating & Cooling
Rear passenger sliding door will not unlock on 2004 caravan
if all the doors lock and unlock except the one sliding door then the right rear sliding door locking motor has gone out.but if both the back sliding doors did not unlock it would be a door unlock relay.
Apr 02, 2010 | 2004 Dodge Caravan
My sliding patio door is sticking
usualy there are 2 ajustment screws at the bottom in the flashing
if you lift the door out of the track and look at the bottom you will see the rollers and likely the ajustment screws is there are no adusters make sure the rollers are free f not spray with penetrating oil and let sit untill free then try again
if sash or frame is tight try spraying it with pledge furnature polish the light grease coat will allow plastic parts to move freely once again
Jul 23, 2009 | Locks & Locksmithing
Removing a slider door to patio
open the slider 7/8 of the way open and lift the slider up and out of the track. you may have to get a helper as the slider is heavy. there might be little plastic clips in the top track of the door that need to be removed before lifting the slider out.
Jun 06, 2009 | Anderson Manufacturing Greg Anderson,...
Glass on sliding door
this is the link to the information http://www.swisco.com/Screen/how-to-repl...
Opening your patio sliding glass door should be an easy task. If your sliding door is giving you a work out every time you open it, most likely it is your rollers that are causing the problem. The rollers are located on the bottom of the sliding door and give the door the ability to slide. Often times they get dirty and wear out, making it difficult to open the door. If you have an older sliding glass door your rollers may have become rusty because sliding door units did not always use stainless steel rollers.
Hiring a professional to replace your rollers could cost you around $100 not including the cost of the replacement parts. Below are detailed steps containing all the information you will need to know to replace your patio sliding glass door rollers yourself.
* Before you start, understand that you need to take the sliding glass door out of its frame to work on the rollers. The sliding glass door is heavy. You may need the assistance of another to help you remove the door.
1) Your patio glass door will have two separate glass units. One unit is the door that you slide and the other unit is stationary. First, stand outside your house and look at your sliding glass door. If the stationary unit is between you and the sliding unit you will most likely have to remove the stationary unit so that you can get to the glass sliding unit.
Before you go through the trouble of removing the stationary unit, first try to go inside your house and see if you can remove the sliding unit. Usually you cannot because there is a lip along the bottom of the patio glass door frame (it keeps moisture out of the house) that prevents the sliding glass door from being removed from the inside.
If the rollers on the bottom of the door are difficult to get over the lip, you can adjust them to help you create more room (go down to step 2). If it is not the rollers but the sliding unit�s frame preventing you from pulling the sliding unit out of the door frame, you are going to need to remove the stationary unit first before you can remove the sliding unit.
To remove the stationary unit, you first need to take out your screen door (if you have one). Lift one end of the screen door frame and use a screwdriver to lift the roller on the bottom of the screen door frame off of the track. Do this to both ends of the screen door and your screen door will pull out of the door frame.
The stationary unit is held in place by a metal piece that runs along the bottom of the track from the corner of the stationary unit to the bottom of the side jamb (there is a chance this piece is missing but if you do have one remove it from the track). After you have removed the metal piece, look for screws holding the stationary unit frame in place. After removing all of the screws try pulling the stationary unit out of the door frame. If you are having trouble pulling out the stationary unit, try placing a screwdriver between the stationary unit�s bottom frame and the track it is resting on. Lift up on the screwdriver while you have a helper pull out the stationary unit from the door frame. Be careful not to use too much force with the screwdriver so that you do not damage the door track.
2) You may need to create more room when you attempt to remove the sliding unit from the door frame. To create more room you can adjust the rollers on the bottom of the sliding unit. By turning the adjusting screws on the rollers clockwise the wheels move up into the sliding unit�s frame giving you more room. The adjusting screws are located either at the bottom of the sliding unit�s frame or in the sides of the frame. There is a chance that there are plugs covering the screws.
After you adjust both rollers (one on each side of the sliding units frame) try to remove the sliding unit from the door frame. If the unit is still getting stuck you may need to get someone to help you. Have your helper lift one side of the unit and pull outwards while you try to pry the other side of the unit over the track.
3) To remove the rollers from most sliding units you need to remove the bottom of the sliding units frame. Most likely the screw that holds the roller in place is the same screw that holds the frame together. Remove the screw from both sides of the unit. Then try to remove the bottom piece of the frame off of the sliding unit; you may need to use a rubber mallet or a piece of wood and tap on the bottom of the frame until it comes off of the sliding unit.
Now that you have removed the bottom of the frame you can take a close look at your patio glass door rollers. Remove one of the rollers and match it up with one of the rollers on this page http://www.swisco.com/page/SI/CTGY/patio...
It is a good idea to replace both sliding door rollers at the same time to prevent extra wear-and-tear to one new roller, which will have to work twice as hard when paired with an older roller.
4) After your new rollers come in, replace your old rollers with the new ones. To make it easier to install the sliding unit back into the door frame, adjust the rollers to be all the way up into the frame. Once you have the sliding unit back in the door frame you can adjust the rollers for optimal performance. Keep adjusting the rollers until the door is sliding back and forth easily
Jun 22, 2008 | 1996 Ford Windstar
American Standard 6034.STE5.002 Chrome Rain Sliding Door Logo
306 people viewed this question
Top American Standard Home Experts
Donni Steen
Mike
john h
Are you an American Standard Home Expert? Answer questions, earn points and help others
