Question about Garden
Its not starting believe the wiring is wrong but need to see a diagram to make sure
    Sergeant:
    Champion:
  • 250 Answers
You have to first check for spark by removing the sparkplug and reatach the plug wire and ground the plug to the metal on the engine. Pull the cord and see if it sparks between the sparkplug gap, the porslin and the metal. If it does not spark switch the 2 wires around to see if it makes a difference.
Posted on Mar 11, 2011
Wiring diagram needed
Most riders have a wiring diagram in the back of the owners manual.
Sep 16, 2015 | Garden
What do i do after installing starter and still no start but al other elec works and battery good? Cables to starter on wrong a possibility?
You put the positive battery cable on the starter? I don't know how you could get that wrong, so the battery is hot at the starter there, and as soon as the small wire on the starter solenoid activates the solenoid (it should with the key in start, the only time that small wire has power on it) then the battery is connected directly to the starter motor and the engine should crank.
Find a wiring diagram of the start circuit for your vehicle, and trace the circuit from the start position of the ignition switch to the starter solenoid. There may be a starter relay involved, there surely will be a park/neutral safety switch or a manual clutch switch depending on the transmission you have, and there may be a theft deterrent module that is involved or maybe not. You will need a wiring diagram to diagnose it and a voltmeter would be very helpful. Post back with year, make, model, and engine size- I might be able to look at a wiring diagram, or send you a link.
Aug 03, 2015 | Cars & Trucks
90cc yamaha mini dirt bike wiring diagram photos
Hi, Baileyjason1 for more information about your question and valuable "FREE" downloads that you will need please click on the links below. Good luck and have a nice day.
yamaha dt 90 wiring diagram Google Search
Yamaha Motorcycle Wiring Diagrams
PDF Moto Manual
OEM parts for Yamaha
http://mybikemanuals.com/yamaha/yamaha-dt
Nov 29, 2012 | Yamaha Motorcycles
Lifestyler 8.0 29740 wiring diagram
Dear Sir:
You have 2 options: go to the manufacturer with your information and ask the wiring diagram and buy it.
or go to the next web: www.fitnessrepairparts.com and pay for the diagram.
I do not believe that you will find anything for wiring diagram in Internet, since this is only offered for Service Tech, do not waste your time.
sincerely. God bless you.
ernesto cuadra
managua, nicaragua.
Feb 11, 2012 | RTO Lifestyler 8.0 MPH Treadmill Walking...
I need help wiring a Delta 28-280 model bandsaw from 220v to 110v. The saw came 110v from the factory, but the previous owner re-configured the wiring to 220v. I need it back to 110v. Thank you.
Rewiring the motor isn't hard, but be aware that you can hurt/kill yourself if you mess this up.
That said, manual is here.
Before you start, make sure you have a couple wire nuts (orange & yellow are a good sizes), a replacement plug, and some electrical tape.
1.) Unplug the cord from the wall. Go ahead and remove the prongs since you're going to need to switch it back to a 120V type prong adaptor. Don't put new prongs on until you've got things rewired. This will help keep you from accidentally electrocuting yourself.
2.) Open the saw base and have a look at the motor. There's a cover held on by a single screw. There should also be a wiring diagram on the motor that looks something like:1aa0c59.jpg
3.) When you remove the cover you should see three groups of wires. There should be numbers on the wires, but you can also figure them out by looking at the number of wires grouped together (see wiring diagram).
4.) You want to change from three groups of wires to two groups of wires per diagram, so when you're done, 1,3, & 5 should be grouped and 2,4, & 8 should be grouped. This is assuming your wiring diagram matches mine.
Make sure you don't have any exposed copper (cover w/ electrical tape if necessary). Make sure you have the wirenuts screwed on securely. Make sure you close the cover up and put the screw back in reasonably tight.
Put the prong on the wire, plug it in, and hit the start button. If you did everything right, it will start right up and no breakers will trip. If you goofed a pair, your motor may spin in the wrong direction. Otherwise, enjoy.
Jun 04, 2010 | Saws
Need wiring diagram
check the capicitor if it is domed up on top bad check the wires at the compressor to see if burnt take a insulated object and bump the contactor in to see if comp starts if so then out on low voltage circ check for call from stat on common to yellow then follow the connections may be out on low psi switch located in the suction line
May 09, 2009 | Heating & Cooling
Spark plug wiring diagram
3.9L V6 Engine. Engine Firing Order: 1-6-5-4-3-2. Distributor Rotation: Clockwise.............did i guess the right motor? let me know/rate me
Jan 14, 2009 | 1991 Dodge Dakota
'91 honda accord
Ok start from the beginning, you are going to need a factory wiring diagram to make sure you are connecting the wires to the ignition coil where I believe you need to start
Sep 01, 2008 | 1991 Honda Accord
Garden Logo
Top Garden Experts
Dennis Key
Dennis Key
john h
