I am trying to setup a intermec 700c to communicate with a Windows Web Server 2008 using a Zoom 56K Modem. I have the Handheld configured correctly as far as I know. I have been working with the intermecs for about 2-3 years. I have set connections on the handheld for dialing instead of wi-fi. Yet, when I go into Connections/Settings and tap on the name, I select to connect. After a few minutes it comes back and says: "The answering modem has disconnected. Check your settings and try again." I am not sure what else to look for.
5 Suggested Answers
thesuperdude
  • 97 Answers
SOURCE: Connect MC9090-G to an Intermec 2100 Access Point
Make sure that the ESS ID and security features match the ones on the AP.
Also, from the MC9090, you will need to click on the radio icon, select options and in the top drop down menu, choose regulatory. select the country where you are and uncheck the box named enable 802.11d.
This should have the terminal connected on to the network.
Posted on Mar 26, 2009
  • 61 Answers
SOURCE: Keep getting error Cannot execute btcc.exe
If your device is registered at Intermec.com you should be able to dowload a firmware flash for the device. Follow the instructions and reflash the device. If this does not work the bluetooth radio could have malfunctioned.
Posted on Apr 05, 2009
aviral_srms
  • 1216 Answers
SOURCE: Hi Jay,
Hi , Jay
You should call costumer support for vodafone.
tell them you handset name and model no . and ask for settings.
They will send you a push message on your phone .
You just need to save it on your phone.
After this just restart your phone and you're done.
If this does not help nay be that you did not activated your GPRS and you need to confirm it from your service provider
1 Aur Baat
I just ignore this paragraph
Select "start" ---->>> select "settings" ------->> select "connection"----->>> select "connections"Now Select "Add a new modem connection"Connection name::"Give any name"Moden:: select "Cellular line (gprs)"Select "Next"Access point name:: "portalnmms"select "Next"Username:: (blank)Password:: (blank)Domain:: (blank)Select "Finish"Now Select "Setup/Edit my proxy server" below that "Add a new modem connection"Select the two check boxes1.) This network connects to the internet2.) This network uses a proxy server to connect to the internetNow you ll have proxy server box below that you will have "advanced" Select "advanced"Select "HTTP" --->> Server:: "10.10.1.100" port:: "9401" select "ok"Select "Wap" ---->> Server:: "10.10.1.100" port:: "9201" select "ok"Give ok to all options.
and believe this has accidentally happened because this also seems a solution to me.
Regards......
It's good night this time in delhi.
Posted on Oct 18, 2010
  • 37 Answers
SOURCE: I have a D-Link DVG-G1402S
The router's PPTP passthrough and IPSec settings assume that you're connecting to an external VPN server on the public side of the network, but it sounds like you're hosting your VPN server inside your local network. If this is the case, you may just want to have your windows VPN box in a DMZ, or get a router that you can exert more control over. Be wary, if you're doing this at a residential location, your internet provider will probably block or "shape" this type of incoming traffic to your local network.
Posted on Mar 05, 2011
Testimonial: "it is a good solution, However even I tried put DMZ to the VPN box, it still doesn't work. I'm wondering if DVG-G1402S supporting GRE protocal at all."
Shows error633
When you try to use your modem on a Windows computer, you may receive an error message similar to the following: Error 633 Modem is already in use, or is not configured for Remote Access dial out or The port is in use.
Try this one after the other
1. Verify no other applications that are using the modem. You can open Task Manager to check that by press CTRL+ALT+DEL. Another way to test it is reboot the computer.
2. This behavior may occur when another device with a driver, for example outdated Palm Pilot software, conflicts with the modem.
3. Telephone.ini or unimdm.tsp is missing or damaged.
4. Make sure the modem is setup correctly and may apply SP.
5. Removing and reinstalling it, or apply the new drive may fix the problem.
6. Make sure no two ISDN installed on the same machine and attempt to connect to the same server.
Apr 01, 2010 | Conexant All 56K Modems: Amigo V.92...
HP USB Modem does not break dial tone
If the information connected to your post is all correct (56k V90 usb), and you are using one line for both the internet and the fax, you should hang up from the internet before you try to dial out the fax.
You have not indicated your PC model, so I don't know what operating system you are using. For XP and newer versions, you have to set up and configure the fax using the wizard or configuration software. If you have not done that yet, you need to.
In xp, go to start, Programs , Accessories , Communication , Fax , and then click Fax Console.
You said your computer is new. Win 7 and Vista are much the same:
1.Click the Start button , click All Programs, and then click Windows Fax and Scan.
2.At the bottom of the left pane, click Fax, and then click New Fax on the toolbar to launch the Fax Setup wizard.
3.Click Connect to a fax modem and follow the instructions.
You also need to make sure that your fax/modem is correctly listed in the control panel. In XP, start, control panel, printers and devices. If you do not have a fax printer listed, you need to "install a local fax printer."
The installation wizard should work in both OS without much trouble. If you do have difficulty, Microsoft and adobe both have "virtual printers" you can use. Look in Microsoft office or online.
Also check control panel of 7 to make sure that your modem and fax are listed correctly. Thanks for using Fixya.
Jan 01, 2010 | HP (56K V90 USB) Modem
D-Link DI-524 is not communicating with modem
Checklist:
* Is DHCP configured correctly?
* Connect your server and laptop to a switch (not directly with the cable)
* Can they ping each other?
* Check that the firewall is configured (or switched off if you have another FW in place)
* Default gateway should be your router, not the computers (until you have configured RRAS for example)
Here you can find more information about how to configure various roles in 2008: http://technet.microsoft.com/en-us/windowsserver/2008/default.aspx
Sep 07, 2009 | D-Link AirPlus DI-524 Wireless Router
Cannot login to configure Belkin SMB KVM-over-IP swith
This happened to me until I installed the activeX control. Were you prompted for that, and did it install successfully?
After the activeX installed, did it also prompt you to install the secure certificate to access the site without IE prompting about invalid certificates?
Since you've tried multiple machines, I doubt security settings on IE are causing the problem. But my switch did these two actions before I was able to login successfully.
Jan 30, 2009 | Computers & Internet
Dialup 56k modem not responding.help says harware failure
whts the name of the modem and the light status and , whts the error message u get when u try to connect to the internet
Nov 15, 2008 | Compaq 56K Modem
Zoom router
Have you tried configuring the ADSL modem router for the internet connection?
Its possible that since you have changed the ADSL modem router, you may have to configure the ADSL modem router for it to work fine. The configuration depends on what Internet provider you have but you may try these steps for now:
1. Make sure the connections are correct. Connect the computer to the LAN port and the ADSL line to the port assigned for that behind the device.
2. Launch an Internet browser and access http://10.0.0.2 and press enter. If a dialog box appears, set the user name as admin and password as zoomadsl and press enter.
3. On the basic setup page of the ADSL router, set the appropriate encapsulation and other settings based on the settings of your provider. If you do not know the settings for your provider, there is a table specified on the user guide for the ADSL router. Here is the link: http://zoom.com/documentation/adsl/5590_UserGuide_EngD.pdf
Jul 19, 2008 | Zoom X6 (5590) DSL Modem (55900003)
Need XP driver
YOU WILL NEED TO DOWNLOAD THE DRIVE
YOU MAY WANT TO GO TO www.dooyoo.co.uk/modem-communication/elsa-microlink-56k-pci
look for the driver that work for xp
any problem let me know
john
May 29, 2008 | Elsa MicroLink 56k Internet (56003) Modem
Zoom x6 model 5590 wireless router
Make sure the Connection Type is set to Static IP on the setup page of the router
Mar 10, 2008 | Zoom X6 Adsl Wireless Gateway Rohs Router
Hayes Accura 56k modem external
Hi, the best way is go to the manufacturers web site which can be found on the modem or the user manual. and the 2nd way is goto www.drivers.com or www.modemdrivers.com where you can find the suitable drivers
Oct 02, 2006 | Zoom Hayes ACCURA 56K Modem
How To Configure FM114P or FR114P for an Internet Connection and Printer Sharing
There are three steps: 1. Configuring the router for Internet access 2. Installing and configuring the print server 3. Adding the printer to the Windows configuration To Configure the Router for Internet Access 1. Connect the modem to the router's Internet port and your LAN computers to the router's LAN ports. 2. Shut down your LAN computers. (Power them off.) 3. Power off the router. 4. Power off the modem. 5. Power on the modem. 6. Power on the router. 7. Start the LAN computers. 8. Enter 192.168.0.1 in a Web browser's address. 9. Type username and password (by default admin and password). 10. Click Setup Wizard to configure the router's Internet access. To Install and Configure the Print Server 1. Install the Printer Server Driver program on a computer. 2. After installation, make sure to select the Run Print Port Setup now box. 3. Click Finish. Print Port Setup runs, showing you the firewall and the printer. 4. Click Port 1. 5. Click Add. A pop-up message says whether a port was created, then the Add Printer wizard starts. To Add a Printer With the Windows Add Printer Wizard 1. Continuing from the last section (or clicking Start > Settings > Printers > Add Printer), click Next. 2. Select Network Printer, and click Next. 3. Click Next again (leaving the port as LPT1). 4. Select the manufacturer and printer model of your printer. (If your printer does not appear, you need to get the CD or floppy that came with the printer, and use Have Disk to specify the file location. Note that it is looking for a file that ends with .inf.) 5. Click Next. 6. Change the printer name to something users on your LAN will recognize easily. 7. If prompted by the Add Printer Wizard about sharing: DO NOT enable sharing! Now test the printer. Other information about Windows configuration is available in Windows help in the article "To connect to a printer on a network".
Feb 19, 2006 | NetGear FR114P Router
Computers & Internet Logo
29 people viewed this question
David Payne
David Payne
