Question about Frigidaire FEX831CS Top Load Stacked Washer/Dryer
I am not getting the required heat in the dryer
  • Frigidaire Master
  • 43,501 Answers
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Posted on Mar 18, 2011
No heat the drier dosn't heat up
Dear Yakov, I am going to provide some answers without knowing to much about your dryer. First if it is 220V? If so it is important that 220volts is reaching the electrical contacts at the back of the machine. It requires knowing how to take a reading and I would suggest you not try this unless you are trained. Secondly be sure and try different setting on the unit to see if any other settings which require heat work and the heater coils. If not it could a fuse, thermostat, or the heater coil itself. Much information on YouTube to check out. If it is a gas dryer and you are not getting heat check fuses and thermostats first, ignition second and timer last.
habitacionesparalatinos org
Dec 28, 2016 | Dryers
Tip
Dryer Breaker Issue
If your dryer is not heating at all, before you call a service company ,check your dryer breaker. You say why because the unit is running just not heating. You are correct it can run but not heat with a breaker tripped. See, the motor only requires 120volts to run and it requires 240volts for the heater to work. What happens is that 1/2 the breaker can trip leaving you with 120volts-enough to run the motor. Just reset the breaker and see if you get heat. This does NOT help most of the time as it is usually a faulty part however, its worth a try because this may be your lucky day and that's all it is...saving you money.Hope this tip helps someone!
on Jul 29, 2015 | Dryers
Hotpoint dryer model M460-G is not putting out any heat when i try to dry my clothes
First make sure you have a clean vent all the way thru. If it is it is possible it could be the heating element or a bad thermostat. BOth will require taking apart the back of the dryer. MAKE SURE YOU UNPLUG THE DRYER! You can get shocked real easy!
Jan 15, 2011 | Kenmore Dryers
Dryer will not get hot
in 99% of the case if the unit is running correctly but not heating the heat element is blown and will require replacement.
have a great day
sonic boom electronics australia
Jan 03, 2011 | Frigidaire Electric Dryer
I'm not getting enough heat from my dryer
If you are experiencing longer dry times and/or poor drying efficiency, the following link can give you some items to check before assuming there is a malfunction with the dryer:
http://www.fixya.com/support/r3578821-dryer_takes_too_long_to_dry
The number one cause of dryer heat related problems is poor exhaust ventilation. If not vented properly, a dryer will not dry efficiently, will take longer than required to dry, and will cause the heating circuits to overheat to the point of failure. The dryer will actually seem hotter as the heating circuits begin to overheat. This is also the source of many fire hazards if not resolved. Read through the link provided and review some of the potential causes. Hopefully, this may save you a service call. Let me know if you require additional assistance.
Jan 05, 2010 | Dryers
No heat on kenmore 97272100 dryer
The following link explains how to troubleshoot as dryer no heat problem:
http://www.fixya.com/support/r630242-dryer_runs_but_not_heat
First, double check your voltage at the wall receptacle. If incorrect, this will also cause the symptoms you describe. The reason: The drive motor only requires 110-120VAC to run, while the heating circuits require the full 220 service. If you are missing one leg of your 220 service, the heating circuits will not operate, but the drive motor will still run.
Next, pay particular attention to the section that discusses proper dryer ventilation. Most dryer heat related problems are attributed to poorly/imporperly installed dryer exhaust vent ducting, or a dryer that is clogged with lint preventing proper air flow. If left in a clogged condition, a dryer will actually overheat to the point of failure and you will experience repeated failures of any components you replace.
Read through the link provided and let me know if you have any questions. I hope this helps you.
Jun 22, 2009 | Kenmore 63942 Dryer
CTD00 Dryer spining but no heat
first you need to establish that you have the proper voltage to the unit. Even though the motor runs, it (the motor) only requires 110 volts. The heat requires 220 volts. The only way to check is with a volt meter.
Apr 07, 2009 | Hotpoint NWXR473EV Dryer
Heating element not getting hot
If the model number you have this listed under is correct, the heating element on this model is easy to get to. Follow these steps:
First, make sure you have the correct voltage at the wall receptacle and at the terminal block in the back of the dryer of 220-240VAC. If the voltage requirements are not correct, this can cause the heating circuits not to function, but the drum will still rotate. To access the dryer heating circuits, follow these steps:
1. UNPLUG the dryer before servicing. Dangerous voltages are still present inside the dryer with the unit turned off.
2. Remove the dryer vent hose from the back of the dryer.
3. Remove the back panel by loosening all screws holding the panel in place.
4. The heater box will be located on the right-hand side (as viewed from the rear). The heating element is housed inside the heater box with the Hi-Limit Thermostat located the closest to the heatet terminal and the Therm Cut-Out (TCO) located at the top end of the heater box.
5. Measure the TCO, first. This is the first likely cause of a no heat problem. A good TCO should read a short (0 ohms). 6. A measurement across the heating element should read about 15 ohms or less if good.
NOTE: Remove the wire leads from any components under test to ensure a proper reading. If any readings are abnormal, replace the component.
Illustrations of your dryer are available at searspartsdirect.com. Just type in your model number and look for item number 6, 15 and 17 under the "Bulkhead" heading. Repairclinic.com and appliancepartspros.com are also excellent sources for finding parts.
If you have questions, or require additional assistance, please let me know. I hope this helps you.
Jan 14, 2009 | Whirlpool LER4634J Electric Dryer
Timer runs but dryer has no heat
Okay...the following link will give you the steps necessary to diagnose and/or repair an electric dryer with a no heat problem:
Read the bottom of the link first. Verify your receptacle voltage is reading 220-240VAC. If you're only reading 1/2 the voltage you could be missing one leg of the 220 service. This will still enable the dryer to run, but the heating circuits will not operate. The reason is the drive motor only uses 110-120VAC, while the heating circuits require the full 220. If this is the case, a receptacle repair is required. Unless you are savvy with electricity, I would only recommend this repair be done by a certified electrician. If you're source voltage at the receptacle is good, then I would assume you have an internal component problem.
Read the section that discusses proper dryer ventilation. If the dryer vent ducting is clogged anywhere, and left in that condition, to dryer heating circuits will actually overheat and result in premature failure.
I hope you find this information helpful. Let me know if you require further assistance.
Nov 14, 2008 | Whirlpool Dryers
GE dryer. It does not get hot. How do you klnow if it is the thermostat or the heating element?
If your electric dryer doe not heat up, it could be the heating element opened ( meaning no current flow thru it, and no heat), thermostat or an over-temp sense switch tripped. These over temp 'snap type" switches are used as a failsafe to protect against unsafe temperatures as well as to prevent fires. Some of these switches have a reset button on them ( similar to those found on garbage disposers) and you may have to reset it manually to enable power to the heating element. These switches are situated in such a manner that if your vent system is clogged, temperature inside the dryer will exceed the safe limit and trip that switch. If you are reasonably handy and feel confident that you can safely troubleshoot and/or repair one of these components, it should be relatively simple to rule out the heater element as the problem by measuring its resistance with an ohm meter ( Obviously, all testing of this nature should be done wiith power disabled). Heating elements vary in resistance so any value that isn't an open ( meaning no continuity thru it) implies it is probably OK. If it does measure as an open, that is your problem and it needs replacement. Hope that helps...
Aug 07, 2008 | Dryers
Frigidaire FEX831CS Top Load Stacked Washer/Dryer Logo
26 people viewed this question
Top Frigidaire Washing Machines Experts
Gerry Harvey
Gerry Harvey
Charles T Nevin
Charles T Nevin
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
