Question about OCE Office Equipment & Supplies
I AM GETTING ERROR CODE 0501 WHEN I TRY TO PRINT OUT A DRAWING FROM MY COMPUTER.
  • 17,970 Answers
Error 0501 is refer at low toner concentration problem.
I suggtes re-fill new toner and then off and on main switch some time, if the problem persists then you need to check the toner motor.
Maybe a clue as to the manufacturer might get you some respoonses. Want to fix something? www.manuals4you.com & www.justmanuals.com
Keep us updated; hope this helps
Posted on Mar 11, 2011
HI.How can i reset a copier minolta konica bizhub36?
  • Code: 0501
  • Description: Fusing heaters trouble (edge)
    • Detected temperature of the heating roller thermistor (TH2; edge) does not go up a given range of temperature even after a lapse of given period of time at warm up. • The warm-up is not completed even after the set period of time has elapsed after the warm-up is started.
  • Remedy: 1 Check the fusing unit for correct installation (whether it is secured in position). 2 Check the open/close operation of the right door. 3 Check the fusing unit CN30-PRCB CN16, fusing unit-relay CN4AC-DCPU CN2 for proper connection and correct or change as necessary. 4 Change fusing unit 5 Change PRCB 6 Change DCPU
This is from manual, try to reset trouble code:
1-Turn the machine "OFF".
2-Press the "STOP" button on the basic panel.
3-Keep the button pressed and turn the machine "ON".
4-Do not release the button, until the machine warm up.
5-After few seconds Error code will remove and machine will reset.Basic menu will show no error on LCD screen.This means error code has been removed and photocopier machine is ready to use.
Hope it helps
May 29, 2017 | Minolta Office Equipment & Supplies
2005 Hyundai santa fee problems with code 0501 abs lights and brake disappeared. When i turn ignition on there no communication with diagnostic computer all read zero cause check engine light code 0501
http://www.obd-codes.com/p0501
i dont envy your job if its not a speed sensor replacement. if it is a broken wire you are going to have to take apart the entire wire harness looking for it.
Sep 25, 2014 | Cars & Trucks
How to fix errore code 0501 ?
meter count, stop00 stop 01 enter access code
Jul 01, 2014 | Konica Minolta Bizhub 42 Laser Copier /...
0501 error on a Oce' 7055
1)0501 is low toner concentration problem
fill new toner and then off and on main switch many time
2)check toner motor.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Jun 18, 2009 | Office Equipment & Supplies
0501 error with Oce' 7056
Well, error 0501 is low toner concentration problem
fill new toner and then off and on main switch many time, if the problem persists then you need to check the toner motor.
Good Luck!!
Jun 04, 2009 | OCE 3140 Copier
Oce 9400 error code 0501
Good Luck!!
Thanks
Jan 12, 2009 | OCE 3140 Copier
100 people viewed this question
Top OCE Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
CheckitRight
CheckitRight
fares
Level 1 Expert
Are you an OCE Office Equipment and Supply Expert? Answer questions, earn points and help others
