While taking out printout every time i have to change no of copies , from 1 to 2 how can i make 2 copies as default
  • 159 Answers
In Windows, go to your printers folder from the Start menu. Right-click the printer you want to change, and select Properties. You'll get the same dialog box you see when running a print job, but changes you make here will become the default for this printer.
Posted on Mar 11, 2011
SYSTEM ERROR E007 ON CANON iR2018
Call to 1-800-243-0019 Canon ir 2018 system error e007 code means that the fusing film is out of Home Position or the film is ripped. You will need to most likely have the fixing film.
Apr 15, 2017 | Canon Office Equipment & Supplies
IR 3035 black copy
<Cause>
On some types of paper (especially those with a high calcium carbonate content), toner offset to the fixing film can
start to cake, moving from the fixing film or the pressure roller to the face or back of paper.
<Field Remedy>
Use the following service mode item to change the timing at which the fixing pressure roller is cleaned:
COPIER>OPTION>BODY>FIX-CLN
0: disable cleaning (default)
1: execute cleaning during last rotation every 500 printouts
2: execute cleaning during last rotation every 200 printouts
3: execute cleaning during last rotation every 100 printouts
Feb 14, 2017 | Canon imageRUNNER 3035 Black and White...
How do I set or change time?
You may view/download the manual at Owners Manual User Guide for Emerson CKD9901 Clock Radio
"Setting the Time of Day" is on page 9.
You should be able to get a printout of the manual at just about any office supply store. Take the manual on a thumbdrive or download it at the store and have them run off a copy. You'll have to pay for the printout, of course. Or you can just read the manual online.
Dec 31, 2014 | Emerson CKD9901 Clock Radio
Copies are light. I have changed toner twice. Even when I change exposure, copies still remain to light.
take out a internal printout .if this is also light then u have to clean the laser section as the mirrors may have got dusted
Jul 29, 2011 | Canon Office Equipment & Supplies
Keep copier ready; disable powersave option
This is going to be a user program:
1) press and hold both light and dark keys
a) the 2 buttons to lighten and darken copies
b) hold both for 5 sec until indicators light up
2) use the left copy quantity key show 2
3) press your copy key
4) use the right quantity key to change to 2 (max 90 sec)
5) press the copy key
repeat step 2 but change to 3 with left quantity key
press the copy key
change right number to (4 = 60 min, 1 is default at 5 min) then press your copy key.
Once done press both light and dark key again to exit
Note*** changing shut off timer and preheat will effect copy lamp ready state. Every 60 sec or so the scanner will move and reset. Some people do not like the noise is makes all the time. If you don't you can always change it back to the defaults. 2=0 and 3=1.
Oct 12, 2009 | Sharp AL 1631 Copier
HP6110 default paper size for copying
Yes, manually set your paper size using A4 or begin with A4 and leave it on auto (default) it will try and match it.
Instructions...
  • Press Menu
  • Option 1
  • Option 2
  • Select copy Setup
  • Select paper size
  • Hit the black triangle until the size you want displays
  • Then hit enter.
Dec 08, 2008 | HP OfficeJet 6110 All-In-One InkJet...
HP 4250 DTN will not print multiple copies
if this is ran through a network which i would think most likely due to the machine then you will need to change the number of copies to be printed on the control panel on the fron of your machine as well as that will have the final say over what comes out of it.
i think it should be as follows:
press the green tick, press down, green tick on print quality.
i may be worng on where its located as not used one for a while.
if i am wrong on it the go into the information menu and print out a menu map. this will show you which sub-directory its in.
Hope this helps.
Pete
Nov 03, 2008 | HP LaserJet 4250n Printer
Cant take printouts
Performing a Fault Reset 14 will reset your WorkCentre and will help to clear error codes.
  1. Find the pink Clear button on the Control Panel of the WorkCentre.
  2. Find the button below the word Auto.
  3. Press these buttons in the following sequence: [Clear], [Auto], [Clear], [Auto] NOTE: All of the lights on the Control Panel should go out and the LED Display should go blank. If the lights do not go out, then repeat step 3 until they do. It may be necessary to increase or decrease the pace of the [Clear], [Auto], [Clear], [Auto] sequence.
  4. Press the [10's] key one time and the [1's] key four times to enter '14' in the LED Display, as if you were to make 14 copies.
  5. Press the green [Start] button.
  6. Press the pink [Clear] button two times.
  7. The WorkCentre should now warm up and come to ready.
  8. If the above steps do not clear the error code, repeat steps 3 to 6 a second time.
Apr 05, 2008 | Sharp AR-5316 Advanced Digital Imager...
Light, Faint or Faded Copies
How is the quality when you just scan a document?
Dec 07, 2007 | Lexmark X83 All-In-One InkJet Printer
Printing a report
IS IT THROUGH EXCEL THAT YOU WANT TO TAKE THE PRINTOUT FROM? YES - OPEN A FRESH EXCEL SHEET. COPY AND PASTE EVERYTHING INTO THE NEW SHEET. TRY TAKING A PRINTOUT. YES - GOOD. NO - UNINSTALL AND REINSTALL MS OFFICE TRY ANOTHER PRINTOUT. YES - GOOD NO - CONTACT MICROSOFT VENDOR. NOTE : NO PRINTER DISQUALIFIES ANY MS DOCUMENT.THUS ERROR FROM MS VENDOR.
Sep 17, 2007 | HP Deskjet F340 All-In-One Printer
Computers & Internet Logo
16 people viewed this question
David Payne
David Payne
