Question about Cooktops
HI THERE I HAVE A EUROKERA CERAMIC HOB YESTURDAY IT SHOWED UP AN E9 ERROR CODE TODAY NO ERROR CODE BUT THE PLUS MINUS BUTTON DOES NOT WORK WHAT COULD THE PROBLEM BE AND HOW CAN I FIX IT
5 Suggested Answers
  • 1462 Answers
SOURCE: Zanussi Ceramic hob ZKT641H front/main left zone does not heat up
can't give you much guidence - will be either regulator or the plate itself. no easy way to find out. you will have to remove the hob top and check for continuity thro the plate. ifplate is ok, then power up and check for supply to the plate. if no supply, then the regulator will be at fault
Posted on Aug 28, 2008
  • 254 Answers
SOURCE: I can't unset the child safety lock on my diplomat ceramic hob
get the model number if a cooktop will be underneatth on sticker.... go to kitchaid.com and locate thier manuals and literature section where u can download a copy or print one out.... hope this helps
Posted on Feb 06, 2010
SOURCE: Eurokera hob - lights flashing, buttons not working
hi i have a eurokers ceramic hob and it has not worked in about a yr. it is touch screen and only 1 mth old when problem happend it was like it over heated and now when you turn it on it flashes on the dial i cnat make out it and the hob wont come on. pls help it is brand new and dont want to throw it out.HELP PLS
Posted on Dec 20, 2010
SOURCE: I have a Eurokera Cooktop Ceramic Hob. The
my euro kera cooker is suddenly switching of after a few seconds it is switched on
Posted on Sep 04, 2011
HOW DO I UNLOCK MY SCHOTT CERAN CERAMIC HOB
l means locked hold two left buttons at same time or the two right buttons or the bottom two buttons or top two buttons should solve your problem you have to do it prety quick or the computer thinks a child is trying to turn on the appliance
Jul 28, 2014 | Whirlpool W5CE3024XS 30" Electric Cooktop...
Telefunken spare parts australia
Try turning off the power for a short while to allow the p c board to re set itself turn it back on and individually turn on each elements for a few minutes. Good luck
Ray
Apr 16, 2014 | Kuppersbusch Glass ceramic induction hob...
My John Lewis ceramic hob is locked and comes up with error code E R 0 3. I think the product code is JLBICH 602 ?? Please can someone help.....I'm starving!!!
press the two left buttons at the same time to reset or the two right buttons to reset if it doesnt work try oxfam
Feb 23, 2012 | Cooktops
Hey, what can I do if on a ceramic hob there is no error message but a letter "L" at each section? The control buttons don't respond I only can switch off and on again but nothing happens. Please...
You've probably accidentally activated the child-lock "L". It would help to know which model you have as the deactivation method can vary on different models. However, this is the process for activation or deactivation on the EKI-848 which looks like the one in the above picture:
Switching off the childproof lock
1. Press the ON key.
2. Then immediately press the Plus key of the cooking zone at the left-back and the Minus key of the cooking zone at the right-back simultaneously.
3. Then press the Minus key in order to deactivate the childproof lock. The "L" will go off.
If this doesn't work or you have a different model, please post back and I will let you know the correct deactivation method for your model.
Hope this helps.
Regards,
BElectric
Nov 23, 2010 | Kuppersbusch Glass ceramic induction hob...
Have a baumatic ceramic hob displayin letter 'L'
the solution is already on fixya i just tried it and it works.press the right key and the minus key at the same time release the right key hold the minus key for 10seconds and the L will disappear
Jan 25, 2010 | Zanussi 23 in. ZKT641H Electric Cooktop
Dec 26, 2009 | Cooktops
Aug 27, 2008 | Zanussi 23 in. ZKT641H Electric Cooktop
Got the same problem, and remembered I've kept the manual book
L means locked. I dont know how Ive managed to do this as well
Anyway it says:
Cancelling the key lock
After switching ON the control the child safety feature can be deactivated. Here it is necessary to simultaneously operate the front right cooking-zone-select-key and the MINUS-key and then operate the MINUS-key alone. If all steps hae been carried out in the right order within 10seconds the key lock gets cancelled and the control is OFF. Otherwise the input will be considered incomplete, the control remains locked and switches-OFF after 20 seconds.
After a renewed switching-ON/OFF key all displays show 0", the display dots are blinking and the control is ready for ooking. If a cooking zone is "hot", "H" will be displayed instead of the static 0".
Followed their instructions & still not worked. ,I am still confused and baffled after these instructions........................
Mar 28, 2008 | Zanussi 23 in. ZKT641H Electric Cooktop
Cooktops Logo
71 people viewed this question
Top Cooktops Experts
Paul Carew
Are you a Cooktop Expert? Answer questions, earn points and help others
