Question about GE JVM1630 Microwave Oven
I have a spacesaver model JVM1630CK01 and i replaced light switch and bulb underneath for stove light and the light stays on constantly the on off swicth seems to work but lights wont turn off
MicrowaveSvc
  • 9047 Answers
SOURCE: Need GE Spacemaker parts..
SEE http://tinyurl.com/gv383
We're happy to help and we appreciate your thoughtful rating of our answer.
Posted on Jun 23, 2008
SOURCE: Microwave Fuse keeps blowing
where is the fuse located on model jvm1851wd001
Posted on Jul 21, 2008
MicrowaveSvc
  • 9047 Answers
SOURCE: GE spacemaker microwave model #JVM1650SH
We see (and repair) this a lot. The problem is on the control panel, which we regularly repair nationwide by mail for $39.95 postpaid.
This light failure often occurs when a bulb goes out and the filament shorts, or when the bulbs are removed or installed without first unplugging the oven from the power line. Either can cause such a failure on the controller.
This can often also affect the exhaust fan operation, too. The lights and fan can be inoperable or stuck on too.
Details of our service and critical safety information and disassembly information is at our site, and our link is at our listing here on FixYa.
Feel free to contact me directly for more information & help.
William E. Miller
prototech@usa.net
http://www.microwavedisplay.com
Posted on Sep 10, 2008
MicrowaveSvc
  • 9047 Answers
SOURCE: GE microwave JVM1631BJ01 while replacing
We see (and repair) this a lot. The problem is on the control panel, which we regularly repair nationwide by mail for $39.95 postpaid in about a week.
At our Web site, you can get details of our service, plus we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
Feel free to contact me directly (and please remind me of your full model number) for more information & help.
William E. Miller
prototech@usa.net
Posted on Dec 22, 2008
  • 64 Answers
SOURCE: Have a GE microwave spacesaver oven/Model
call a pro. these units run at a deadly high voltage. simply not worth your life!
Posted on Jul 02, 2009
My surface light bulb burned out and I replaced it with a new bulb. But now the bulb stays lit and it won't turn off even though I turn it off from the light switch. Please help.
The only fix for it is to either buy another control board $300+ or if you are any good at wiring you can go the the hardware store get a manual toggle switch and install it under the microwave on the right hand side near the control area. But make sure the switch can handle the heat rising from the stove burners. We have about 120 of the microwaves on our properties and 6 of them have this issue. The relay internal switch becomes corroded and binds together from steam and boiling water. GE is JUNK.
Oct 30, 2011 | GE JVM1790 1000 Watts Convection /...
Light always on
We see (and repair) this a lot. The problem is on the control panel, which we regularly repair nationwide by mail for $39.95 postpaid in about a week or so.
This can often also affect the exhaust fan, cooling fan, turntable, and/or inside light operation, too.
Details of our service are at our Web site, along with a video showing how to remove a typical over the range control panel assembly in under 5 minutes.
Feel free to contact me directly with your brand, full model number and symptoms.
William E. Miller
prototech@usa.net
May 23, 2010 | Hotpoint RVM1425 Microwave Oven
I have a roper mounted microwave above my stove. i just need to know what kind of bulb goes underneath it.
Since you obviously intend replacing the bulb yourself (good for you!) you should first remove the old bulb and that will make it easier to find a new one. Chances are, its a common bulb, readily available wherever light bulbs are sold. Or, at the very least, a hardware store like Tru-Value or Home Base.
Feb 03, 2010 | Roper MHE14XKB Microwave Oven
Yesterday while using the stove top to cook some chili the lights under the microwave blew out with a loud "pop". It tripped the breaker switch so I reset it and everything works like it should except the...
Well I'm reaching here---if the bulb did not fracture/break then it sounds like a capacitor popped--check your owners manual for reset button but I don't think there is one for the lighting---In addition if you can see the circuit board--look for burn spot or wet spot. GL
Sep 18, 2017 | Kenmore 80412 Microwave Oven
CAN'T GET BULB ACCESS DOOR OFF TO REPLACE UNDERNEATH BULBS
Hello there:
first you need to remove the screws from the back of the microwave that hold on the casing and there might be some on the bottom too. then remove the outer casing
the bulb is under the casing towards the front right corner as you are looking at the front of the microwave
Sep 09, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Light under unit stays on
open the oven there are two or three safty switches near door one of the switch is for light if it is short then only light will remain on.by opening door light should come on set the time and hit start light will come again. replace that switch and it will be ok
Aug 07, 2009 | GE Advantium 120 Convection/Microwave Oven
Light bracket in over the stove ge microwave XL
You can usually find helpful exploded view diagrams and order parts by entering your full model number here.
Dec 06, 2008 | GE JVM1630 Microwave Oven
Surface light dimmer not working for spacesaver microwave
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
William E. Miller
prototech@usa.net
Dec 02, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Burning smell and light switch does not work
The controller needs to be repaired. We regularly repair these control board assemblies for only $32.50 nationwide, and that's much cheaper than replacing the board. For safety, disassembly and other info see http://tinyurl.com/yzjozk
Jan 14, 2007 | Whirlpool MH7135XE Microwave Oven
GE JVM1630 Microwave Oven Logo
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Shekar Avadhani
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
