Question about Fujitsu Heating & Cooling
Fujitsu Halcyon Inverter. Error code 01. com error, indoor to outside unit. What can I check on this?
  • 86 Answers
SOURCE: Error CA for LG air conditioner model Q-12 AWR
1.sensar of remote control.
2.indoor unit sirkit board may be there is problem.change sirkit board by new one
3.if any requirement abt airconditioner pls mail me i can send u spare parts of air conditioner,.
mintex007@yahoo.com
Posted on Mar 16, 2008
notsomot
  • 67 Answers
SOURCE: Fujitsu AOT30PMAL inverter outdoor unit not working
Sounds like your compressor is seized or a start fault. If the unit is under five years old it should be under warranty. Call Fujitsu warranty out to have a look at it for you.
Contact details as follows
http://www.fujitsugeneral.com.au/contact.php
Sorry but either way I think your going to need a part there is very little that I can do unless your in WA.
Hope this helps
Posted on Jan 11, 2009
jgwhomeequip
  • 1902 Answers
SOURCE: Fujitsu mini split outdoor unit not running, but indoor unit is running after turnning on
Check the disconnect switch and make sure that both the fuses are good and not shot. If one is shot then the system wont work. There are two fuse. Also be careful due to you will be working around 210 volts
Posted on Jun 01, 2009
  • 4090 Answers
SOURCE: LG split (3 indoor) LMU360CE
02 Indoor In-Piping Error 2 times OFF
There is a complete guikde to problems on page 66 of users manual. If you dont have one get back to me with your email.
Posted on Aug 02, 2009
alishahid13
  • 8 Answers
SOURCE: How to use thermostat for heat on Fujitsu IAQ
This unit comes with a remote control (optional wall mounted wired thermostat available) as a standard feature. This unit is precharged with the environment friendly R-410a refrigerant. No additional refrigerant is needed if the line set is 49 feet in lenght or shorter. In addition to its very high 20 SEER efficiency rating, the 15RLQ is only 31 in. long which makes it the smallest Mini-Split System in its category through out the industry.
This category of equipment is ideal for smaller spaces where spot cooling is required. Several models in this category are ENERGY STAR Certified, meaning they save you money on your utility bill. Residential applications including sunrooms and additions are made easier with these air conditioners and heat pumps. Do you have a warm spot in your home? Fujitsu mini-splits can provide extra cooling capacity for those hard to cool areas. Commercially, their small size makes them ideal for small offices, providing individual temperature control.
Fujitsu's I.A.Q. Systems provide residential and commercial property owners an innovative solution for clean, temperature-controlled indoor air. The Halcyon IAQ systems deliver powerful heating and cooling, are designed for ease of use and maintenance, and feature an unobtrusive design which can be integrated easily into any decor. The Halcyon IAQ systems filter dust, pollen and odor making them the perfect addition to any home!
  • Wireless Remote Control
  • Plasma Filter
  • Sleep Timer
  • 24 Hour Timer
  • Dry Mode
  • Auto Louver: Up/Down
  • Auto Mode
  • Quiet Mode
  • Auto Restart/Rest
  • Auto Changeover
  • Low Ambient
  • Cold Prevention
Warranty All Fujitsu ductless mini-split air conditioners and heat pumps come with a 2 year parts and 6 year compressor warranty.
Important: All installations must be performed or supervised by a certified HVAC technician in order for the warranty to be valid.
Posted on Dec 08, 2009
I have two flashes on the timer light of my indoor unit of Fujitsu Inverter ASU9RLS
Serial signal (reverse) error, at operation start up. operation led - off, timer led - 2 flashes, coil dry led - off, check wire between indoor and outdoor
Jul 10, 2015 | Fujitsu ASU9RLS2 Single Zone Wall Ductless...
How to fix Fujitsu a1 error code for 15rls2 heat pump.
Try cutting power to the indoor and outdoor units for a couple of minutes. Restore power and see if the error returns. The A1 error for this line of units indicates high compressor discharge temperature, which translates to overheating outdoor unit.
If this error code remains after a hard power reset, it's time to pick up the phone. Either you have a refrigerant leak which has resulted in a loss of freon, or a blockage in the refrigerant plumbing that is backing up pressure in the system. Both conditions will require a major repair by an authorized service tech to get your heat pump up and running again. 25361378-awph1b3yhxdrnyqdcrsrelkr-4-0.jpg
Please mark my answer as helpful.
Jan 09, 2015 | Fujitsu 15RLS2 Halcyon Wall Heat Pump Air...
HOW DO I FIX FUJITSU AOU24CL1 SERIAL SIGNAL (REVERSE) ERROR, AT OPERATION STARTUP
Outdoor controller circuit board sounds faulty. This error means that the indoor and outdoor units cannot communicate. Replace the outdoor controller in this case. Check if there are more than one outdoor PCB as others can be damaged as well.
Jul 25, 2014 | Fujitsu HALCYON AOU24CL1 Mini Split...
Fujitsu aou30clx compressor location detection error
You must turn off of the power for 10 minutes. Then open the front of the indoor unit and push the emergency button for 10 seconds. The compressor will unlocked.
Apr 18, 2013 | Fujitsu 30CLX HALCYON Wall Mounted Mini...
My fujitsu inverter asta12jcc outside fan is not working. On the inside unit the operation light is on for a few seconds than the green timer light flashes every few seconds. but the fan inside is running.
Communication error between indoor to out door.Comms Error, check your wiring, remove external pumps. Split/Multi - check volts from terminal N to 3 = 0 - 65 Vdc, Multi V - 4 Vdc terminals 3 and 4
Jan 02, 2011 | Heating & Cooling
I have a Fujitsu inverter split system,(ASTA18LCC) which the power was removed for a while. Now when you start it up on any mode the red operation light is on briefely, then the green timer light flashers...
To work out what the error code ispress the orange start/stop button on the remote controller so unit operationis stopped.
Then press and hold "energy save" and "zone control" buttonsimultaneously for at least five seconds, the error code will be along thelines of En:nn where the "En:" is the error code and the":nn" indicates the indoor unit address if there are multiple indoorunits connected to the one controller. If the upper vertical bar on the capitalE is missing so it looks maybe like a 2 or something don't worry for somereasons they just do that
Some common error codes are:
E0 Communication error between indoor unit and wired remote control, check ifthere is 12VDC between terminal 1 + 3 at remote control and 8-9VDC pulsatingbetween terminal 2 + 3. If DC volts out of Indoor pcb is below about 11.6VDC itwill cause this error, the problem is normally dry capacitors in the 12 VDCpower supply section. This model has two power supply sections on indoor pcb.
E1 Communication error between indoor unit and outdoor unit,
EF Discharge temperature abnormal
Is it helpful?
Dec 27, 2010 | Fujitsu 24C1 Air Conditioner
Heating & Cooling Logo
594 people viewed this question
Top Fujitsu Heating & Cooling Experts
Fotis Papastamatiou
AJMAL KHAN
Donni Steen
Are you a Fujitsu Heating and Cooling Expert? Answer questions, earn points and help others
