Question about Lenovo IdeaPad Y510 Notebook
MY LENOVO LAPTOP MODEL IS -IDEAPAD Y510. I FORGOT BIOS PASSWORD. I DO NOT KNOW HOW TO REMOVE IT. I HAVE SUCESSFULLY INSTALLED WIN-7 , WIN-VISTA ULTIMATE SEVERAL TIMES BUT AFTER SOME TIME WHEN REOPEN,WINDOW IS NOT OPENING.SOME TIME SHOWING ERROR WINDOWS LOAD FILE MISSING. WHEN TRYING WIN XP INSTALLATION BLUE SCREEN APPEARING. MY LAPTOPS DVD WRITER IS BROKEN SO I INSTALL OPERATING SYSTEM WITH EXTERNAL DVD. LASTLY MAY I HAVE THE DIAGRAM OF INNER CIRCUIT OF MY LAPTOP'S MODEL BEACUSE I WANT TO KNOW THE JUMPER POSITION.
  • 3422 Answers
SOURCE: How to uninstall Vista and load XP in Lenovo Y510 Ideapad
You can have a look HERE what microsoft says about this error.
You''l need Windows XP SP2 to support a PCI-Express graphics card.
If you are using only PCI-Express graphics card, the only choice is to boot from the complete edition of Windows XP SP2.
If you intend to install with Windows XP or Windows XP SP1 and then use the upgrade kit of SP2, please disable PCI-Express in BIOS before starting the installation.
Under this circumstance, only PCI graphics card can help you monitoring the installation process at this stage. Then, upgrade the version to SP2. After upgrading is successfully completed, you can enable PCI-Express and start using PCI-Express graphics card.
Goodluck.
Posted on May 23, 2008
florin_decad
  • 203 Answers
SOURCE: My web camera isn't working.
Check the driver if is still at hes place , if is not there go to manufactor website and dowload the driver
Posted on Jan 16, 2009
Sameeraryan
  • 82 Answers
SOURCE: Lenovo 3000 Y 410 Laptop XP drivers installation
Dear the drivers which u have for vista for eg LAN / SOUND/ CHIPSET they all are common for any operating system ur load...............so don't take tension install xp & load the drivers.........................Sameeraryan
Posted on Jan 17, 2009
Geekman
  • 32281 Answers
SOURCE: replace keyboard on Y510
The keyboards on ThinkPads are easy to replace.
On the bottom of the laptop there are screws that hold the keyboard in place (possibly 3 or 4 screws). These screws can be identified by the tiny keyboard symbol next to these screws. Remove these screws, you need a small Phillips screw driver. You can now lift the keyboard off, you may need a small flat screw driver to lift it off. The keyboard is attached to the motherboard by one or two ribbon cables, they are held in place by slide catches, slide these catched to release the tension on the ribbon cable/s so you can withdraw the ribbon cable/s.
When you insert the new keyboard make sure the cable catches are in the released position before you insert the ribbon cable, insert the cable fully home and press the slide catches home to lock the ribbon cable to the motherboard.
At this stage I suggest you power up the laptop and test the keyboard to see if it is functioning correctly. If is not working properly, then the ribbon cable/s may need reseating again. When all is OK now fix the keyboard in place with the screws.
Posted on Mar 08, 2009
  • 523 Answers
SOURCE: Lenovo Ideapad Y510 NVIDIA Driver for WindowsXP
go to lenovo or ibm webpage and select drivers download, chose your model and your operating system and download the display driver make sure it says nyvidia display driver . this will fix your problem.
Best Regards
Posted on Mar 19, 2009
I have lenovo ideapad Y510 7758 laptop, i installed win 7 (64-bit) ultimate on that. where i found all drivers
I did a search on your model and seems they made this laptop with windows 8.1 to window 10 in mind and did not release drivers for windows 7. I seem this a lot. they do not wish to support older OS so they do not release the drivers for them.
Dec 11, 2016 | Lenovo Computers & Internet
Password bios lenovo y510
To reset the BIOS password read the information from this link.
In case of your Lenovo laptop the easiest method would be using software from Hiren's Boot CD as it's pretty hard to open it up and reach for the CMOS battery or the jumper and I wouldn't recommend doing it especially if it's under warranty.
Feb 09, 2011 | Lenovo IdeaPad Y510 Notebook
My lenovo ideapad Y510 is not able to start windows vista which was preloaded into it when purchased.as soon as it is switched on, fan start running and it gets shut down after sometime without starting...
This sounds like a problem with the operating system. The best way I know to fix this is to wipe the old operating system off and install windows 7 with a full install disc.
Windows 7 Home Premium is more stable and faster than Vista ever was, but will cost $199.99 or so for the full version, or if it's possible to install with the upgrade, $119.99 or so from Microsoft.com.
If your Vista could be started, you could theoretically go to the recovery console and 'recover' it or go to help-> restore and restore to an earlier date where the computer wasn't malfunctioning. However, these options aren't available if you cannot even start windows.
Feb 02, 2011 | Lenovo IdeaPad Y510 Notebook
When i install the driver for lenovo y510, the message appears"windows cannot install the software for Image, ask your hardware vendor for assistance" please tell me what is the prblem with my...
what is your os??
check the device manager is there any webcam installed
if you use win 7 the driver or software from the y510 cant be installed on it so take another software like cyberlinkucam because the software and driver fr win vista
Jan 14, 2011 | Lenovo IdeaPad Y510 Notebook
WEB CAM IS NOT WORKING IN MY LENOVO IDEAPAD Y510 LAPTOP AFTER INSTALLIN WINDOWS 7. PLEASE GUIDE ME.
Hi satyadevbujj,
Based on concern, Y510 camera driver for Windows 7 is not yet released based on Lenovo's support download site. Hence, you still can try updating the camera using the windows vista camera driver. Just go to this link.
--> after downloading, install the driver then restart your computer.
Hope it helps,
Thank you for using FixYa.
Oct 21, 2010 | Lenovo IdeaPad Y510 Notebook
Download webcam drivers
Download Here
For complete and updated driver just follow the link
*Brand: Notebook
*Family: IdeaPad Y510
*Operating System: Your Operating System
*If the driver for Windows 7 is not available you can use the Windows Vista Driver. Just make sure to check the version of the OS for Win7 32bit download Windows Vista 32bit Driver for Win7 64bit use Windows Vista 64bit
*You can also use Option 3: Lenovo Smart Downloading
*After Installing the driver press F5 + FN to enable the wireless switch
Thanks for using Fixya
Jul 19, 2010 | Lenovo IdeaPad Y510 Notebook
Hello, I am using Lenovo Y450, recently I had a an unexpected problem "BOOTMGR is missing" and just fixed it by installing a new windows, but then the touchpad is no more working. Can anyone please give...
Reinstall the Synaptics Pointing Device touchpad driver.
For XP Operating system click here.
For Vista 32 bit Operating system click here.
For Vista 64 bit Operating system click here.
For Win 7 32 bit Operating system click here.
For Win 7 64 bit Operating system click here.
Click on the Download link on the download page to have the driver. after installing the driver kindly restart computer.
Should you have anny other concerns please leave a comment.
Cheers~
Jun 24, 2010 | Lenovo IdeaPad Y510 Notebook
Can't find drivers for win 7 64-bit for lenovo y510
Windows 7 is a new platform and every hardware manufacture is developing the driver suits for it.Meanwhile you will have to download the drivers directly from the chip manufacturers site e.g. for sound you can download it from http://www.realtek.com.tw/downloads/.
About the chip manufacturers you can know from the Y510 page where the drivers are there for Vista or XP.
Thanks.
Dec 28, 2009 | Lenovo IdeaPad Y510 Core-2 Duo: Y510...
I want to install XP in lenovo y510
okie! a question? i have installed windows Xp with Sp3 on my Y510. Now whenever I try switching back to AHCI mode i end up with a BSOD. would it make any difference if i leave it in the compatibility mode? or how can i get it back to AHCI mode
Feb 17, 2009 | Lenovo IdeaPad Y510 Notebook
Lenovo IdeaPad Y510 Notebook Logo
87 people viewed this question
Top Lenovo Computers & Internet Experts
Michael Vincent Cruz
Are you a Lenovo Computer and Internet Expert? Answer questions, earn points and help others
