Question about Starbucks Saeco Italia Digital Barista Coffee Machine
My Saeco Digital Italia stream/hot water wand quit working. When I press stean and turn the knob it pops out (not off) and nothing comes out. Hot water also want come out.
    President:
  • 1,618 Answers
Push in on the knob when it pops out if that works then the steam valve assembly needs to be replaced, ask for the stainless steel valve replacement.
Posted on Mar 14, 2011
I need to descale my machine, now the screen says descale and "purge" and nothing happens when I press hot water on OR want to let steam out
There is a blockage in the steam/hot water circuit . Try poking the end of the steam tip on wand with a paper clip. Make sure turn the hot water on by pressing the hot water button and turning the steam wand.
Apr 08, 2015 | Saeco Magic Comfort Plus Espresso Machine
Starbucks Saeco Italia Digital Barista Fully Automatic Coffee Machine will not prime!
Here is what is said in the manual:
"Direct the steam arm on the drip tray.
Open the steam/hot water knob until a
steady stream of water is dispensed. Close
the knob. Insert the filter holder into the
brew head to pre-heat the filter holder.
The machine is now ready to dispense
coffee."
Apr 26, 2017 | Starbucks Saeco Italia Digital Barista...
How do i prime the machine.? i hav e tried every button.
Press the hot water button to select water then open the knob to run hot water from the steam tap.
Jan 27, 2011 | Starbucks Saeco Italia Digital Barista...
Will not prime
Try this make sure the end of the wand is clear, then open hot water knob and push in on button if that works, replace the steam tap rod.
Mar 06, 2010 | Starbucks Saeco Italia Digital Barista...
Flashing lights on my saeco italia espresso machine
I had the same problem, two green flashing lights with one red (water) all 3 would just keep flashing and not turn solid. No coffee can be made or hot water. I could not pump prime. The problem was the steam wand was blocked with old milk residue. It needs unblocking or you will never pump prime. I could not unscrew the steam wand...so I let it sink in a glass full of hot water for a few minutes and then turned the water knob counter clockwise to push out the softened residue. After that, everything was good. When water started flowing out of the steam wand, the red light turned off and the green lights turned solid. The obvious answer to why you can't pump prime is there is a blockage somewhere and best to start with the steam wand. --Mabada
Feb 22, 2010 | Starbucks Saeco Italia Digital Barista...
What does ventilate mean on my Saeco coffee machine. It will not work now.
i had this problem too once. its also could be because you have put hot water in the water tank....i had a family member do that and thats what it said....run cold water through wand and see what happens...
Nov 07, 2009 | Saeco 00034 Incanto Sirius Super Automatic...
Saeco Italia SUP021 YR green lights and red water light flashing
You can't manually reset. The machine will have to do it. I had the same problem, two green flashing lights with one red (water) all 3 would just keep flashing and not turn solid. No coffee can be made or hot water. I could not pump prime. The problem was the steam wand was blocked with old milk residue. It needs unblocking or you will never pump prime. I could not unscrew the steam wand...so I let it sink in a glass full of hot water for a few minutes and then turned the water knob counter clockwise to push out the softened residue. After that, everything was good. When water started flowing out of the steam wand, the red light turned off and the green lights turned solid. The obvious answer to why you can't pump prime is there is a blockage somewhere and best to start with the steam wand. --Mabada
Sep 14, 2009 | Starbucks Saeco Italia Digital Barista...
Saeco Digital Italia Fix
I had this same issue with my machine and unfortunately I had to send the machine back for repair. The steam knob should pop right back on, if positioned correctly. The people (Starbucks, Saeco) whom you spoke to were correct, that there is build up of steam (or back pressure) it will cause the knob to pop of in these conditions. The root cause of this problem is most likely (as in my case) that you steam wand is clogged. Even if you keep it cleaned externally, there may still be debris that builds up INSIDE the wand. To correct the problem, take some wire (we used decorating craft wire) that will fit into the end of steam wand. Push the wire as far up as you can and continue to move back and forth. Flush the wand either with steam or hot water and repeat several times. I do this every month or so to keep the debris from building up inside the wand. Good luck and I hope this works for you.
Mar 11, 2008 | Starbucks Saeco Italia Digital Barista...
Super espresso machine leaking
Hi
Your steam manifold needs to be replaced. I still have the original in mine but if you don't cool them down after steaming they will develop hair line cracks and leak after while. To cool it down after steaming push the steam button again, then open the knob and run it till you have a steady stream of water, then close the knob.
The replacement manifolds are black and have held up very well but they have a brass manifold re[placement but you will need new mounting hardware.
Feb 28, 2008 | Starbucks Saeco Italia Digital Barista...
Starbucks Saeco Italia Digital Barista Coffee Machine Logo
74 people viewed this question
Top Starbucks Coffee Makers & Espresso Machines Experts
Shehu Pro
Shehu Pro
eyecam
Are you a Starbucks Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
