Question about D-Link AirPlus Xtreme G DI-624 Wireless Router (DI624RE)
Wireless router i think my router got fried during a storm. it will not turn back on. will it not work again and its a wireless router d-link 624
  • elvin3247 Aug 01, 2008
    the adapter didnt work thanks
  • 298 Answers
That will depend in its just the power adapter that got friend there is still a big possibility that the router will work with a different power adapter but if the router also got damaged during the storm. Then there is nothing that we can do about it. you will need to get a new one.
Posted on Jul 31, 2008
  • Jeffrey Pedimonte
    Jeffrey Pedimonte Aug 04, 2008
    Even if you have tried a different power adpater with the same specs as the original adapter then that means that the router also got fried out. You need to get a new router then.
We reset the d-link di-624 wireless router and now it will not let us sign back on without the username and password which we do not remember. how do i factory reset the router?
Hi, when you reset your router the password is reset to default, and that default is admin admin. And to reset it, at the rear is a small hole in the hole is a button, remove from the power, and depress the button for a few seconds, then connect the power and try to logon again with your browser using the default settings.
It is also all explained in your user manual link below...
http://www.retrevo.com/support/D-link-DI-624-Wireless-Routers-manual/id/420ci368/t/2/
Aug 18, 2010 | D-Link AirPlus Xtreme G DI-624 Wireless...
Everything appears to be working, but not internet connection
Turn off the firewall in both the router and the modem. try again-- once it is working ...just turn one of them back on..
May 16, 2009 | D-Link AirPlus Xtreme G DI-624 Wireless...
Using the DI-624 as a bridge
I don't think it can. An inexpensive wireless access point will work as a bridge. I use the TP Link brand with detachable antenna.
http://www.tplink.com/products/product_des.asp?id=116
Using the terms using the dlink router as bridge you get results of people who claim it can't be done because of firmware. The same question on the D-Link help site mentions DL to DL bridges, but not with the 624.
Carl
Jan 04, 2009 | D-Link AirPlus Xtreme G DI-624 Wireless...
I need a new D-Link model di-624. where can I buy this?
I would try Best Buy or Fry's, who should definitely have the product. Online, try ebay.com, amazon.com, and tigerdirect.com
here's a link to 625 model online.
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=2795002&CatId=2668
Dec 09, 2008 | D-Link AirPlus Xtreme G DI-624 Wireless...
Can't connect to the Internet via router
Well, this is a very generalized problem that others have, so i'll give you some starting tips. If you can connect when you plug your computer directly into the modem, then it sounds like your modem is bonding to your computer. There are a couple ways to fix this. The easiest is to ask your router to clone your MAC addess (not to be confused with a mac computer, a MAC address is a 10 digit code that uniquely identifies your computer on a network). See the attached image to find where it should be. c26d492.jpg
Once you set it to clone your machines mac address, unplug the computer from the modem, and plug in the router. If this doesn't fix it, please comment back and we'll try some other things. If it does, then give a good rating :-)
Steven
Aug 10, 2008 | D-Link AirPlus Xtreme G DI-624 Wireless...
I think my router got fried during a storm. it will not turn back on. will it not work again and its a wireless router d-link 624
If your router got fried during a storm, then its not going to come back on. So, its basically useless now. You will have to out & by a new one.
Jul 31, 2008 | Computers & Internet
DI-624 problem with wireless network
Buy the N router! That is the only solution. My signal weakened and went from the whole home to less than two feet if that at times. I bought the N router and it worked just like the G one did when I first bought it. Ya think somebodies got the limited life span worked out?
Jul 10, 2008 | D-Link AirPlus Xtreme G DI-624 Wireless...
D-Link AirPlus Xtreme G DI-624 router access
'user' login is just read only, so you really cannot change any config.
so when you reset the modem have you tried to login with "admin" and the default password? if not try to reset it again, but pushing the reset button at the back of the router for a few seconds but before that search for the default password of your router in some search engine. like type in the model of your " 'router' default admin password "
May 22, 2008 | D-Link AirPlus Xtreme G DI-624 Wireless...
DI 624 Wireless Broadband Router
So- Red - First of all don't rate yet. This will probably take a couple notes. So, let me make sure I've got this straight:
AT&T
V
V
Modem>>>>Linksys>>>>DLink( no status or pwr lt)
v v
ptr ptr
Is this crude diagram about right? Are the ptrs wired or wireless?
How many pcs? Wired or wireless? Getting their ip from which router? Linksys model #? Operating systems?
May 14, 2008 | D-Link AirPlus Xtreme® G DI-624 Wireless...
Di-624 stopped working
Hi sailaway!
. Make sure the router is going from the modem, to the port marked WAN, on the 624. You can test the cable, by plugging it directly into you computer, from the modem, if you want to. Disconnect the power from your modem, your router, and turn off your computer Wait 1 min. Turn on the Router, wait three full min's. Power up the 624, and wait one min. Power up the PC. Reason for the long wait on the modem is that it has to get data from the internet, to give to the router. If that don't hwlp, try changing the cable from the PC to the router, to a different port. If all that don't work, try resetting the router by gentley pressing a straightened out paperclip into the reset hole in the back. Hold it for 30 sec. If that fail resetting it, try holding it in while you unplug the 624 and plug it back in. If it resets, go thru the first steps to set it up again. If all that fails, your 624 may be bad. Had that happen to me. The steps I listed brought it back to life for about 2 months, and it died completely. Good Luck!
Jan 05, 2008 | D-Link DI-624 Air Plus XtremeG Wireless...
D-Link AirPlus Xtreme G DI-624 Wireless Router (DI624RE) Logo
76 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
