Question about Akai PT4799HD Rear Projection Television
Spiderweb obstructing the projector on rear projection tv
How do i safely access the projector to remove this spiderweb?!
    Problem Solver:
  • 8 Answers
The back of the TV has a little plastic "pop away" peice, about 2 in by 3.5 in. It is just below the center in the middle. With a long cleaning tool, you can clean the lenses and the back of the screen, but do be carefull about scratching any surfaces! :)
Posted on Dec 22, 2008
Front screen has a spiderweb crack. how can we fix this?
No, there is not. Its normal to replace the whole applicance.
Dec 20, 2013 | Toshiba TP50G90 50" Rear Projection...
How do I clean Sony KP-61XBR300
The mirror rarely needs it---access for it requires removal of entire screen unit------the lens (3) can easily be reached from rear with the back removed---you also at that time can look up to see if mirror is dirty or smudged.
Mar 25, 2012 | Sony KP-61XBR300 61" Rear Projection...
How do I get access to the inside of the front screen. There is a spiderweb behind the screen. I have replaced the bulb and cleaned the fan but can't find out how to get to the front screen to get the...
Usually there are screws that hold the front part of the screen on. They are usually right on the edges in the back of the set. be carefull when you take the screen off. If by chance you may need to clean the mirrors inside the set. They are usually serface faced mirrors. meaning the mirror material is on the glass and can easily scratch or rub off easily.
Aug 09, 2010 | Samsung HLN467W 46" Rear Projection HDTV
Green projection lamp not working
  1. you will need a manual screwdriver to remove the panel. You need a soft non-abrasive cloth to avoid any contact with your fingers and the lamp assembly.
  2. Turn off the Projector. After the unit has cooled down properly, remove the power cord from the outlet..
  3. Remove Lamp Compartment Door. The lamp compartment on projectors islocated underneath the projector unit. For Rear Projection TVs, the lamp compartment is located in the rear bottom left or right side of the TV.. Remove the screws and the lamp compartment door.
  4. Remove Lamp Assembly. pull out the lamp assembly disconnect any power cords that is still connected to the lamp assembly. Put it aside and don't get it confused with your new lamp!
  5. Clean Lamp Compartment. Dust gets everywhere and while you have the projector open, use a soft cloth to remove any loose dust from the lamp compartment.
  6. Insert New Lamp Assembly. reconnect any power cables to the new lamp if present and slide the new lamp into the compartment in the same orientation that the original lamp came out.
  7. Replace Lamp Compartment Door. Set the lamp compartment door back into place and securely screw in the door without screwing it in too tight
Nov 03, 2009 | RCA P52939 52" Rear Projection Television
Toshiba TN50X81 Lens Cleaning
Usally access from rear panel, unplug and only wipe the lens with feather duster. do not mechanically move the projection tubes or you will effect the convergence of the 3 colors
Jun 17, 2009 | Toshiba TN50X81 50" Rear Projection...
Appears that lint is on one of the lenses
this could be a contaminant inside one of the lenses, or possibly spider webs inside the tv.. This is a very common problem. Remove the back of the tv, you will be able to look around the back of the screen with a flashlight and see if there are any spiderwebs. at this time you should also clean your lenses and mirror with some glass cleaner . this will improve your picture as well.
Nov 05, 2007 | Toshiba 46H83 46" Rear Projection...
Hitachi 61SDX01B
The problem is called green geometry.There is nothing wrong w/the green pix tube.It is critical to get the green geometry
accurate because the red and blue convergence overlays on
the green.If you have more than an alignment issue,that will need
repair before adjustments are attempted.
Oct 15, 2007 | Hitachi 61SDX01B 61" Rear Projection...
Spiderwebs under Screen, how do i clean it ?
Yes, I have seen this many times. Usually the best way is to remove the upper back cover and clean out the spider webs with a soft, dry cloth, but be careful because the mirror is mounted to the inside of the cover.
Jun 24, 2007 | Hitachi 50FX18B/19K 50" Rear Projection...
Akai PT4799HD Rear Projection Television Logo
66 people viewed this question
Top Akai Televison & Video Experts
Jaime Hernandez
Are you an Akai Televison and Video Expert? Answer questions, earn points and help others
