Question about Dell OW7658 (J4624SK8115RT7D50) Keyboard
How do I stop the sound setting for my keyboard? I must have hit a setting and can't stop the sound on every key touch. PLEASE HELP
  • 2,229 Answers
This would be found in the accessibility options in the control panel. In Win7, it's in the Ease of Access Center that can be accessed through the control panel.
Posted on Mar 11, 2011
My mouse touchpad stopped working all of a sudden. I have also enabled the synaptics touch pad in device settings in the control panel. after doing all these also my touch pad is not working.
Check the keyboard it's possible the touchpad has been deactivated. You can toggle fn keys (fn + f2) or any fn key that has touchpad drawn on it. If this doesn't help. Am afraid the touch pad connector has to be checked & replaced in computer repair shop
Jan 27, 2013 | Lenovo Computers & Internet
HOW TO USE TOUCH RESPONSE
There are two samples for each note in the "Piano" sound samples. This allows you to play "soft = p" or "Loud = f" based on how hard you hit the keys.
The default setting of 2 suit most people. You can change the touch response to 3 (more hard) or 1 (less hard). With tough response set to 3 - you play mostly the soft samples until you bang the key much harder.
This is a keyboard that tries to give a bit of effect that an acoustic piano hammer mechanism would give.
Oct 29, 2012 | Casio Lk-110 Keyboard
My @ symbol is stuck on the " sign. I do not have an ALT GRA key. I have an ALT CAR key and and ALT key but neither seems to help. I've tried hitting the Fn key and 2 at the same time but still no...
Sounds like your keyboard in in UK mode, but is labeled for US. Or the other way.
In a UK keyboard, Shift+' (the key which is two spaces to the right of "L") should give you an @ sign.
Depending on your Operating System, you can use the CONTROL PANEL and REGIONAL SETTINGS to set the keyboard to be a USA keyboard, and then Shift+2 will give you an @ sign.
http://en.wikipedia.org/wiki/Keyboard_layout is a good reference for keyboard layouts.
Apr 17, 2011 | Toshiba 310CDT Keyboard
I have a Yamaha PSR-S700. Recently, the touch sensitivity in one of the keys stopped working. Very little pressure applied would cause the note to sound as if the touch sensitivity was off completely. Now...
You MAY be confusing touch sensitivity with VELOCITY sensing. Touch sensitivity is PRESSURE put on AFTER the note sounds that causes modulation. VELOCITY is what is used for example to control the loudness of pianoo notes depending how fast they are struck. VELOCITY sensing is done by using TWO contacts at every key... one closes first. IF one of these gets dirty, FULL velocity will be sensed and it will be LOUD. The contacts can be cleaned using ONLY 99% isoprophyl alcohol and Qtips after MUCH disassembly of the keyboard. The contacts are conductive rubber pills in silicone rubber domes. Clean boththe contacts and the circuit traces they pres down onto.
Apr 02, 2011 | Yamaha PSR-S700 ARRANGER WORKSTATION...
My touch pad is SUPER sensitive, when I type, my cursor ends up all over the place. I read up on hitting the f7 key, but I am totally computer illiterate. When you guys say hit the function key, do you...
From Dell:
Customizing the Touch PadYou can use the Mouse Properties window to disable the touch pad or adjust the touch pad settings.
  1. Click Start keyboar4.jpg , and then click Control Panel.
  2. Click Hardware and Sound.
  3. Click Keyboard.
  4. In the Mouse Properties window:
    • Click the Device Select tab to disable the touch pad.
    • Click the Touch Pad tab to adjust touch pad settings.
  5. Click OK to save the settings and close the window.
Oct 06, 2009 | Dell Inspiron 1526 Laptop
Inspiron 1545 keyboard problem
This is going to sound really weird but I found a fix. I've got a Dell studio XPS laptop and was getting annoyed by the same phenomenon. I discovered the problem was more common when my thumbs were close to/touching the touchpad. I cranked down the sensitivity of my touchpad and things got a lot better. Probably works for many different kinds of laptops.
For my machin - Steps to fix:
Mouse Control Panel: Dell Touchpad Tab: Click to change Dell Touchpad Settings: Touchpad Settings: Touchpad Sensitivity: Move it from near "Light Touch" to the middle.
I hope this helps someone. :-)
Jun 18, 2009 | Dell Spacesaver USB Keyboard J4624 SK-8115...
My programmable keys are no longer programmed.
Normal 0 Go to Control Panel.
1. Click on Keyboard.
2. When the Keyboard Properties come up, CLICK on Key Settings.
3. Then click on the DEFAULT. This should reset all the keys to original setting.
Hope this will help some. Bud
Oct 02, 2008 | Logitech Cordless Desktop S 510
Toshiba Laptop Keyboard problem
My Toshiba Satellite A45 S120 keyboard has a problem, some of the keys are not working. When you type it does noting. Sometimes when you start the computer, it continuously types the letter eeeeeeee. You can hit some keys randomly and this will stop, but if you start a program (eg. ms word) the same thing happens.
Sep 05, 2008 | Toshiba Satellite A85-S107 Notebook
Need to disable a key on my keyboard
check your keyboard in
Start/settings/control panel/keyboard right click open check what options available you may be able to stop key working
Jul 24, 2008 | Computers & Internet
Problem with keyboard
Hi
this is a comen problem with key boards what you could try is dissconnecting your keyboard from your PC and restarting you PC when you hear a bleep and a messidge on the screen follow the instructions and replug your keyboard back in another thing you could try is setting your keyboard to the UK setting this might help to
Nov 05, 2007 | Logitech Deluxe Access Keyboard
Dell OW7658 (J4624SK8115RT7D50) Keyboard Logo
26 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
