Question about Marshall Mg15dfx 15-Watt Combo Guitar Amplifier
Marshall MG15DFX - Sound cuts out randomly when using distortion or effects. Turning amp off then on solves it only until it happens again. Does not seem to affect the clean channel. Could it possibly be a loose connection somewhere?
  • Marshall Master
  • 5,603 Answers
There are many things it could be... I often quote the probabilities based on many ears experience and the symptoms the person posts.
Based on what you have posted, there is an intermittent... the unit vibrates while operating... there could be a loose connection, however my guess is you will find bad soldering at one of the pots that control the distortion. The solder often breaks loose as the sometimes support the circuit board from the leads of these pots. Also switches that solder to the board and sometimes jacks for foot switches break loose.
Open the unit and inspect the solder joints. It often takes an experienced eye to spot the tiny grey ring around the solder meniscus that signals a failure.
Posted on Mar 12, 2011
Marshall Amplification Marshall MG2FX Guitar Combo Amp power turns on but no sound
Hi!
At this point, I would just take it to a tech rather than poke around in it. It sounds like the power section is the problem as you have guessed, but without the technical knowledge you'd be shooting in the dark. That particular amp is right on the line of being expensive enough that would be worth repairing, but you might do just as wel to check Ebay for another used one.
Good Luck!
May 21, 2014 | Marshall Amplification Marshall MG2FX...
Marshall amp
Marshall are very good amp. but when it gets faulty its a headache. kindly get a technician and check the amp part or anr dry joint from the capacitors due to vibration and age.
Apr 08, 2014 | Music
Marshall mg 50 dfx amp sounds muffled?
Turn off the effects or go inside and unplug the little sound card. It is only a few samples of real effects, not the real thing. It's like a cheap PC sound card separate from the other components and has a small power plug on it. Wiggle that plug or unplug to see if it changes. It won't cut her sound, just the effects. Make sure the effects are off and verify, if using a footswitch, that it is working properly.
Mar 21, 2014 | Music
Distorted speaker sound - only 18 months old not played at volume - is it likely to be the speaker or electronic ? Is this a common fault - will it happen again making this amp unreliable ? Not as...
this is a electronic problem. there must be a capacitor/s in the output section that's swollen and will keep giving the same problem unless its replaced.
G.
May 29, 2011 | Marshall Amplification Marshall AS100D 2x8...
Where is the serial number on my marshall amp mg15fx
Behind the amp, right around where the power-supply is. Usually the right hand side at back of amp. Serial numbers are labeled as: S/N########
Mar 14, 2010 | Marshall Mg15dfx 15-Watt Combo Guitar...
No output from my Marshall MG15DFX
could be effects module or sound output i.c. also check send and return jacks
Feb 04, 2010 | Marshall Mg15dfx 15-Watt Combo Guitar...
I have a problem with the digital fx section on the amp. No single effect works anymore, even when the fx level is on maximum..
probably a bad solder joint on the circuit board where that pot is soldered in. check it out and reheat and apply a little more solder. or its just a dead pot.
yostamplifier.com
Jan 18, 2010 | Marshall Mg15dfx 15-Watt Combo Guitar...
Input jack replacement
oh yes it can be fixed quite easily,...but you are best to bring it down to your local music store and have them do it, they'll be fair in price and your amp will be done right,....(no time for that breakin down stuff when your playin your guitar), thanks, cracklin joe
Jan 07, 2010 | Marshall Mg15dfx 15-Watt Combo Guitar...
Mg15dfx Amp issue
Most of these use an amplifier chip in the TDA family of 5 or 7 pin audio amps.
If you play real loud you may overheat the chip and it will go into shutdown to protect the chip.
Sometimes htey don't put adequate thermal conductive grease on the chip causing it to overheat.
Remember this is a small practice amp, not a powerhouse.
It sounds like it is going into "motorboating" as it is called.
Dec 11, 2009 | Marshall Mg15dfx 15-Watt Combo Guitar...
Marshall Mg15dfx 15-Watt Combo Guitar Amplifier Logo
207 people viewed this question
Top Marshall Music Experts
matt martin
matt martin
Leonard Jeffrey
Level 1 Expert
rjivaro
Are you a Marshall Music Expert? Answer questions, earn points and help others
