Question about LG RE-44SZ21RD 44" Analog Television
LG RE44SZ21RD Picture Fault
(i) Picture is over to leaft of screen and is totally green. I guess the colour wheel has dropped off its bearings or similar. Is this difficult to fix and does it need a dust free cabinet to be sure of cleanliness?
(ii) When this TV was delivered by Currys, I noted it was upside down, when the carton specifically stated it should be kept the right way up - could this have contributed to the damaged/broken colour wheel? If this could be proven, should I claim off Currys?
  • 1 more comment
  • cooldrummer Jul 31, 2008
    This TV has probably only been used for max 500 hours, is it normal for the colour wheel to fail at such useage?
    I am very dissapointed in failure at such low hours of use - any comments?
    Fine thanks - can at least talk to the vendor with some confidence now! Steve.
  • LG Master
  • 19,396 Answers
When this happens you have to replace color wheel
Posted on Jul 31, 2008
  • Ginko
    Ginko Jul 31, 2008
    The green on a side of the screen means you have to replace color wheel.
    Currys has an excellent customer service ask them if they provide replacement here: 08445 61 62 63 at office hours
  • Ginko
    Ginko Jul 31, 2008
    Color wheel can fail even before the year of usage, check the guaranty terms and contact the vendor.
Thank you for the answer, but i got for flat tv but mine is crt tv.so is it apllicable to that crt tv also.I got LG 29 INCHES FOUR YEARS BACK, NOW IT IS GIVING A PROBLEM WHEN I ON THE TV ITS OK BUT A
Hi Babu
Check all the solder terminals at the CRT base card. If any of it get loose at the solder terminals, this kind of fault can happen. It is very difficult to detect a dry solder terminal, as it will be microscopically small. can\'t be seen by naked eye. To this type of fault, what we technicians do is, to resolder all the suspected solder terminals. In 90% of this kind of faults, get rectified by this. You too can try this. Be sure not to short circuit adjacent solder terminals to make a short circuit by any solder bridge short, when re-soldering. Electro help
Oct 28, 2014 | Televison & Video
I got LG 29 INCHES FOUR YEARS BACK, NOW IT IS GIVING A PROBLEM WHEN I ON THE TV ITS OK BUT AFTER SEVERAL MINUTES THE PICTURE BECOMES GREEN AND PICTURE COMES LIKE NEGATIVE IN COLOURS. WHEN I SWITCH OFF
Fault with the main power supply regulator board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
It will be best to replace the power supply regulator board as card basis rather than making "Surgery" to it; which usually will make loss for both money and time. Even though you can make it right, it will cost around an amount equal to the cost of a new board; including the cost of (spare parts + service charge) More to say, most of the spare parts to it will be difficult to get from open electronic spare part market. This is true to most of the flat panel TV power supply boards; irrespective of its brand and screen size.
Oct 27, 2014 | Televison & Video
Mitsubishi model LT-52249 picture is green
A plain green screen indicates mostly a to a panel fault. If you're sound in electronics, and wish to get more details, check this link. http://electronicshelponline.blogspot.com/ Selecting the view option, either to Mosaic / Flip card, can be selected by the drop-down list, by the top left of the display window, will make surf easy. You can also do a search, by type in the brand name / model number / IC used, in the search box at the top right of the display window.
Screen-shots to defective LCD panels are given. Compare it to that of your TVs' and make sure about the fault. Surf the site.
Nov 02, 2013 | LG 42LC2D 42 in. LCD HDTV
My tv has suddenly gone to an all pink picture. What do I do???
Possible that the green gun has failed or there is fault in the drive to the green gun or a circuit issue in the drive.
You can tap the TV and see if the colour returns, if so there is soldering issues. Check the CRT board which is behind the picture tube as due to heat the components could develop dry soldering. Solder all suspected joints, solder the chroma IC and drive.
This must solve or if the green gun does not respond the picture is a suspect and a rejenuvation is the next step.
Jul 07, 2012 | LG Televison & Video
The picture is blue on every channel, but still has sound and picture
Hi
Hope is might help , if the others colours red and green are showing on the screen then resetting the grey scale as per service manual might clear the problem , but if one colour is missing then voltage cheek,s of the cathode voltage on the tube might give a clue to the fault a possibity might be a fault in the tube. regards Derrick.
Jan 30, 2011 | JVC Televison & Video
Screen just turned green. Sound but no picture.
Contact your LG repair centre. There will be a problem with the main board settings for the RGB gain levels, this is the area which sets up the colour balance. A factory re-set may cure the problem but more likely the EPROM settings on the main board would need to be rectified.
Nov 29, 2009 | LG Televison & Video
I bought a lg flat screen 37' from home shopping club it keeps shutting off i have check the timer they are all off please help
hey can someone help me i got a LG projection i have replaced the lamp and then had green and coloured screen and now got no picture at all.
Mar 14, 2008 | LG Televison & Video
Green as a frog!!
ya take frog out lol jk did u cheak ic chips the cables mixed up ?
Jan 31, 2008 | LG 52SX4D 52" HDTV
LG RE-44SZ21RD 44" Analog Television Logo
335 people viewed this question
Computer Repairing
Computer Repairing
