Question about Cameras
I cant find the serial number to my canon dc100 camcorder.its not on my instruction book or on the cam.theres a number under the battery but thats not it.im trying to open the coral dvd movie maker disc that came with the cam but i need the serial number
The coral dvd movie maker program is looking for its serial number
the serial number of the camera will not help you.
also called the product key or serial key.
it should be in its manual, box, or dvd case.
the serial keys are long like a windows OS key
example 4RT2-8XPT-89HT-PTR9-UCT0
it should be on a special sticker in the front or back of the manual,
on the back/side of the box, or on the dvd case that the dvd is in.
sometimes its on a seperate card.
Posted on Mar 11, 2011
When I turn on my camcorder it indicates that there is NO DISC...why is this??
remove battery to decharge internal capacitors for 8 hours
ought bring any software hiccup back to normal
also there might be a "reset hole' access with a pin somewhere on camcorder, try depressing
Nov 19, 2011 | Canon DC100 DVD Camcorder
The circuit board is troubled,it does not work,i have a dc100 and it's a mini dvd camcorder,what does it cost to replace a circuit board for this particular camcorder
go to the canon website, there are 1000's of people with the same problem, it the way the camera been made and they will fix it for free, they fixed mine...
Nov 01, 2010 | Canon DC100 DVD Camcorder
The camera will not turn on even when connected to the power supply, and the red light stays on indicating is fully charged but when I try to open the dvd disk will shut off and will not work at all
your cam is inshut down protect mode there is
an electronics problem in your power converter inside the cam ;if the cam go on whit the battery its your power supply....
Feb 07, 2010 | Canon DC100 DVD Camcorder
I turned on my dc100 today and it powered on, then went off. It will not power back on, even with the adapter attached. Earlier I was getting a "set date and time" message
sounds like the power adapter is failing, have you got a multy-meter to test if your gettin a voltage out of the adapter, the adapter should have an output voltage printed on the side, Also if the adapter is faulty it wont charge the battery so in turn wont fire up your cam it will just show on for a few seconds till the battery drains again. if you take your adapter to the local electrical store they will fined you one thats the same amperage/voltage and the correct polarity.
Jan 21, 2010 | Canon DC100 DVD Camcorder
Serial numbre installing ImageMixer for Canon HF-10
I have a problem with my cannon fs100, I am looking for the serial number and it's not any where near, under or over the battery. Please help?
Jul 14, 2009 | Canon FS100 Flash Media Camcorder
Editing videos taken from canon dc100 camcorder
I see here that . . .
"The DC100 takes 3-inch Mini DVD-R/RW discs, and like most of its competitors, can fit about 20 minutes of best-quality video on one. If you choose to initialize a disc for playing in a standalone player, the camcorder writes standard VOB files; if you initialize for future editability, it records in the VRO format. Windows Media Player can play the latter if you rename the file with an MPG extension, however the aspect-ratio information gets lost--that info is encoded into a separate file--so 16:9 video will get squashed into 4:3. "
Cnet Reviews.
Your videos are recorded in the common DVD format called MP2.
They have the extention .MPG so if you copy the video files to your computer, and change the end of the filename from VOB, or VRO to an MPG then your software can recognize it as the MP2 format that it is.
There is a Windows XP program, called Windows Movie Maker, it can open your video files and provide you with most of the video editing tools.
Cheers.
Jun 14, 2009 | Canon DC100 DVD Camcorder
No volume on canon DC100
Look on page 29 of your manual
Are you sure you do don't have the system muted?
Press the Menu, then System Setup, press SET. Select VOLUME then press SET.Adjust the volume with the left/right arrow keys, then click set.
Hope this helps...
If you don't have the manual (although I know you said you read the manual), go to:
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=SupportDetailTabAct&fcategoryid=261&modelid=13078#DownloadDetailAct
Mike
Nov 24, 2007 | Canon DC100 DVD Camcorder
Canon DC100 DVD
MAKE SURE ITS A DVD - R OR -RW IF CAMCORDER WILL NOT RECOGNIZE +R OR +RW IF ITS AN RW MAKE SURE YOU INITIALIZE IT
Nov 22, 2007 | Canon DC100 DVD Camcorder
Instruction manual
i had the same problem. you may have plugged your power supply into the a/v slot near the function button..that is what i did. there is another place near the lens to plug it in. try that and then finalize should be an option.
Aug 13, 2007 | Canon DC100 DVD Camcorder
Finalzing my disc
you can only finalize a disc in the dc100 with the power adapter on. (page 59 instruction manual)
Aug 01, 2007 | Canon DC100 DVD Camcorder
Cameras Logo
452 people viewed this question
Top Cameras Experts
Steve
Are you a Camera Expert? Answer questions, earn points and help others
