Question about Technics SCEH790 CD Shelf System
I have a TECHNICS SCEH790 HOME 5.1 I have a phono stage that turntable plugs into but I have pluged it into my AUX output and it's not working all DVD and CD's work fine, can you help me please, Many thanks ****
  • David Dunn
    David Dunn Mar 11, 2011
    What do you you mean you HAVE a Phono stage? A separate phono preamplifier? Is IT working? NO output or LOW output? Name it.
  • Michael Brown
    Michael Brown Mar 12, 2011
    Hi my phono stage is a azur 540p Cambridge Audio, I did have it working b4 but it was a friend who put it all together for me, now I have moved my hifi I can't get it to work, I have tried to look for a pic of back of my hifi to see which jacke to plug it into but had no luck, if you have a pic of wich one to plug it into that would be very helpfull, my e-mail is michaelb91210@aol.com that's if you have a pic to send so I can follow plan, many thanks ****
    Brigadier General:
  • 8,546 Answers
Register for free and get the manual.
http://www.retrevo.com/support/Cambridge-Audio-540P-Amps-manual/id/21962dj981/t/2/
It has one input and one output.
Rule of thumb - OUTs connect to INs
Posted on Mar 12, 2011
Kenwood turntable no sound?
Are you using a magnetic "PHONO" input on your amp/receiver, or just a line/aux input? The 'good' turntables from the 70's - 80's used magnetic catridges with a very low level output - you will need a phono preamp in order to hear the turntable. Only phonos (Crosly) that use ceramic catridges generate enough voltage without a preamp. Good luck and let me know if that answered your question.
Aug 10, 2014 | Technics SL-1210 Turntable
Hi I have a Technics SCEH790 CD Shelf System, plus a pre amp phono stage for my turntable, I have had this working in the past as it was a friend who whirerd it all together, I have moved my hi fi to a...
PHONO PREamp. Does that suggest anything?
No picture necessary. YOU can see it. I can visualize.
Turntable to the Pre-amp IN. Preamp OUT to ANY available RCA input (usually AUX,).
Mar 22, 2011 | Technics SCEH790 CD Shelf System
How do i connect technics turntable model SL-QD33 to technics stereo model SC-DV290 and what do i need to switch to on stereo to play records.
Have a look on the back input panel of the sc-dv290. Check for a "PHONO" input. If there is no phono input it will not play turntable. If there is: then plug it the turntable in and switch the SC-DV290 to PHONO mode.
Another way would be to purchase a "phono preamplifier" from ebay: Hook the turntable into the phono preamplifier, and the preamplifer into the SC-DV290 AUX input.
Feb 26, 2011 | Technics SC-DV290 System
Low volume through amp
you will probably need to buy a phono pre amp , i have a Dual 505 turntable that worked fine on my ROTEL amp but when i changed amps and went to NAD i had to buy a phono pre amp or else listen to really low sound . hope this helps
May 23, 2009 | Technics SL-1200MK2 Turntable
SL-BD22 SETUP
go to RADIO SHACK and get a pre amplifier module (hope its still available) , that will do the trick , AJ
May 20, 2009 | Technics SL-BD22 Turntable
Technics turntable plays but no sound with Sherwood receiver
The problem is the fact that the new receiver has no phono input. The phono input has an extra stage of amplification built in. Your receiver is working fine. You need to purchase a phono pre-amp. These run around $20. Connect the turntable to the preamp and the presmp output to any line level input on your new receiver and everything will work as expected.
Dan
Apr 12, 2009 | Sherwood RX-4103 Receiver
Humming
Do not connect your PC output to the Phono input, it is a mismatch. Thye output from the PC will be "line level" or the same level as tape input, aux input, CD input etc. The phono input line contains an extra stage of amplification required for turntables. If you attempt to use that input, you will fry it. Any of the other inputs on the receiver will work for you.
Dan
Apr 08, 2009 | Technics Audio Players & Recorders
No sound from my SCEH790 system from turntable...
Hi...
The aux wont work on a TT . You need a turntable pre-amp. Then you can plug it into the aux jacks.
Try partsexpress.com or mcmelectronics.com
Jan 11, 2009 | Technics SCEH790 CD Shelf System
Volume
Please let me know how your turntable is connected to the music system. I mean, to which input ? (Tape/Aux/Phono/VCR/CD) ?
Aug 24, 2008 | Technics SL-1200MK2 Turntable
Not a good sound
you can't...the technics need to be pluged into phono..because the signal has to be amplified for it to play...phono channels on amps and dj mixers have an amp built in....
Apr 06, 2008 | Technics SL-1200MK2 Turntable
Technics SCEH790 CD Shelf System Logo
124 people viewed this question
Top Technics Audio Players & Recorders Experts
 Grubhead
Grubhead
T-Comtech Repairs
T-Comtech Repairs
Electro Med Services...
Are you a Technics Audio Player and Recorder Expert? Answer questions, earn points and help others
