Question about Philips MMS 321 Computer Speakers
Only one speaker works - Philips MMS 321 Computer Speakers
  • jessie2402 Mar 12, 2011
    thanx for your support,but i am from the netherlands and my englisch is not that bad,but some terms you use are difficult for me to understand.i will try to translate it in dutch.again thanks for your time.
  • Philips Master
  • 27,725 Answers
Try swapping the speakers around if the problem still persists either the speaker is faulty or
the speakers plug/outlet is usually at the back of the computer you will have to open up the computer to check the lead attached to the rear of the input plug make sure the connection is good
or you might have to clean the dust from your computer dust causes static which causes your computer to overheat and all sorts of problems
be sure to wear an anti static earth strap before touching anything inside your computer
have you tried this control panel sounds and audio,volume,advanced,speakers select the appropriate speakers from the drop down list or click start control panel administrive tools computer management device manager scroll to system devices + to expand,system speaker right click properties then select use this device (enable)
try cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the CPU central processing unit and your sound card dust causes static to build up in a computer causing it to overheat any many other problems
hope this helps don
Posted on Mar 11, 2011
    thanx for your support,but i am from the netherlands and my englisch is not that bad but some terms you use are difficult to understand.but i will try to translate it in dutch.thanx again for your time.
Need help with altec lansing ada 745 4.1 speakers
Does the right front speaker need to work in order for the whole speaker system to work?
The whole system can still work with or without it.
Here is an additional tip how to ..... Computer Speakers
Sep 29, 2012 | Altec Lansing ADA745 4 Speakers
RIght speaker not working in speaker system. Switching the left with right speaker make the right speaker work (not speaker) Plugging the 2 RCA into a different input changes nothing. 2 rear speakers...
Let's name the product and use FM for troubleshooting. Are you saying you have the Right Front and both rear amp channels/speakers not working? What DOES work?
Jan 17, 2011 | JVC Audio Players & Recorders
My samsung s3310 speaker doesnt work
i have samsung s3310 but has no speaker problem pl solve this
Sep 16, 2010 | Samsung Cell Phones
Worked last week computer crashes now restored speakers don't work now. another set of speakers work. &35's won't work on a different computer, Powers up clicks when plugged in but no sound /
You said, other speakers worked fine ono that pc right? And the speakers doesn't on other computers? Then surely the speakers are now defective. It might be the wirings or internal parts of the speaker. Check warranty of the speakers, if it is expired, then you have to replace the speakers.
May 25, 2010 | Boston Acoustics BA735 Computer Speakers
Computer is not recgonizing my speakers?
Check the speakers with any other device. Probably the speakers are not working or if they work fine, connect any other working speaker to your system and check whether if they work or not.
If the other speakers also don't work you probably have a faulty port.
Mar 30, 2010 | Gateway G-MAX2000 2-Piece Multimedia...
Speaker randomly works
Please check the link: http://support.dell.com/support/edocs/systems/ins1525/en/SM/index.htm
Hope it helps.
Oct 25, 2009 | Dell Inspiron 1525 Laptop
Windows 7 Audio Quadraphonic Not functioning well
Sounds like you are getting quad sound in the test process that checks them, yet when in windows media player or winamp (or whatever) your rear speakers aren't producing sound: Try setting your sound drivers to do something like "speaker fill" then you are set. I'm under the belief that stereo sounds aren't being matrixed into all 4 speakers.
Mar 25, 2009 | Computers & Internet
My right control speaker doesn't work.
your speaker control cable is not working right try to push the cable in to the speaker a litte bit and then try.
May 13, 2007 | Harman Kardon HK595 Computer Speakers
Philips MMS 321 Computer Speakers Logo
143 people viewed this question
Top Philips Audio Players & Recorders Experts
Gyula Lacz
 Grubhead
Grubhead
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
