Question about D-Link DIR-615 Wireless Router
I am trying to hook up a netgear universaL WIFI INTERNET ADAPTER to my tv and it says to push the WPS button on my router and i dont know what to push
    President:
  • 1,623 Answers
The dlink dir 615 wireless router hasnt got wps. So its no good trying to connect it via that way you can only do it via wep or wapor wap2 here is a link to the manual for your router http://static.highspeedbackbone.net/pdf/D-Link-DIR-615-Manual.pdf
Posted on Mar 11, 2011
I need how to set a password on the wifi AC1200
login to the router main interfacew normally by 192.168.0.1 the user and password are on a sticker on router somewhere and then there will be a tab in interface that will say Wireless the pass word can be changed via there. another alternative is if the router has WPS just press button on rpouter and on device find WPS connect in wifi settings and it will auto connect.
Sep 17, 2016 | NetGear Universal WiFi Range Extender...
Why did the router ID change when I linked it via the Wps button to the DSTV wifi gadget ?
Here's and excerpt from the Netgear WNR2000 user manual explaining that this is normal behavior for Netgear routers that support WPS..:
  • Keep Existing Wireless Settings. This check box is automatically selected after WPS is enabled to prevent unwanted settings changes, and is also selected if you have already specified wireless security settings or your SSID without using WPS. When this check box is not selected, adding a new wireless client using the push button or the Add WPS Client screen (see "Push Button Configuration" on page 2-14) changes the router's SSID and security passphrase. You might need to clear it if you are using certain registrars, such as for a Windows Vista PC, to configure the router through WPS.
Even if your router is not a WNR2000, it is likely that the configuration interface pretty much the same so you might be helped by looking at Chapter 2 page 17 in the WNR2000 manual here..:
Or else, go to Netgear support (NETGEAR Support Welcome), select Wi-Fi routers and download/display the user manual pdf and search it for "disable router's pin" or "keep existing wireless settings" and verify/change the setting so the router doesn't make changes when you use the WPS button.
May 20, 2016 | NetGear Computers & Internet
I bought a Sony DVD with wifi to get Netflix and it says push the WTF button but there is no button on my Netgear router. Do I need to upgrade my router or how do I synch to the DVD?
Ok firstly let me just state that the button in question is a "WPS" button and not all routers have these. Your sony dvd should have several methods to connect to a network please look these up in the manual and try a different method thanks
Feb 04, 2015 | NetGear Computers & Internet
Locate WPS button on FWAG114
Thanks for posting to Fixya!
According to the manual I found at the following link;
http://downloadcenter.netgear.com/en/product/FWAG114
www.youtube.com/watch?v=8ffqvIoxcOc
WPS is not supported on this router. However, my suggestion would be to reset the WN2500 to default with the reset and start fresh, using the manual setup. You can find the help you need here;
http://kb.netgear.com/app/answers/detail/a_id/19887
NETGEAR Support Answer WN2500RP FAQ
I hope this helps you with your setup!
Oct 05, 2014 | NetGear Computers & Internet
How do I find wps button on Netgear WNR834B
The Netgear WNR834B does not support WiFi Protected Setup (WPS).
You can follow the documentation in the manual to setup WPA-PSK (Pre-Shared Key) and use the key to add devices to your wireless network.
Manual: http://documentation.netgear.com/wnr834b/enu/202-10171-01/pdfs/FullManual.pdf
Jun 24, 2014 | Arris SURFboard SBG900 Wireless Router...
I got a Netgear WNCE2001 today. My router is a Verizon router. (The one with the WPS button on the front.) The security password is in WEP. When I try to connect it with WPS, the light on the WNCE2001 just...
which light is blinking ?
may be this help you ?
2. Select a radio button.
• Push and Connect (recommended). Either click the button or press the WPS
button on the rear panel of the Internet adapter.
• PIN Number. Select the radio button and a PIN displays.
The Internet adapter tries to join the wireless network for 2 minutes if you are using Push
'N' Connect, or 4 minutes if you are using a PIN.
3. Go to the router.
• If you are using Push 'N' Connect, press the router's WPS button.
• If you are using a PIN, log in to the router and type the PIN from your Internet adapter
in its WPS screen.
4. Go back to the computer that is connected to the Internet adapter, and make sure that you
are connected to the wireless network.
• When WPS is running, the WLAN LED blinks, alternating between green and amber.
• If the computer does not to connect with WPS, the WLAN LED is solid red for 5
seconds.
• If the computer does connect using WPS, the WLAN LED is solid green for 5 seconds
Then the WLAN LED returns to indicating a wireless signal.
Feb 12, 2014 | NetGear Computers & Internet
I dont no mypassword of wifi
If you got WPS capability on the device you are trying to connect you can push the WPS-button on the router, or you can login to the administration interface on the router (IP-address might be underneath unless you don't know it) and change the password to your liking. If you don't know the login and password for your interface then i guess the last resort is to find the reset button on the router and use the provided login that usually is found on a sticker underneath the device (your router), and simply set a new password for your WIFI.
Nov 18, 2013 | Zyxel P660HW-D1 Router
Mywifiext net
Netgear never gives a defined range in metres.
Will the WiFi adapter work with the TV, as it is designed to be controlled by a computer not a TV?
The USB socket on the TV is designed for being used as PVR, video recorder, not to connect to the internet.
You need to consult your TV manual, as I don't think it will ever work.
May 24, 2013 | NetGear Universal WiFi Internet Adptr...
Wps light blinking
CALL YOUR ISP FIRST.
wi-Fi Protected Setup (WPS) is a standard for easy and secure wireless network set up and connections. Some of NETGEAR's products use the name Push 'n' Connect for WPS. To use WPS, your product must support WPS and be compatible with WPA security. WPS can automatically set up a random network name (SSID) and strong WPA wireless security for wireless routers, access points, computers, adapters, Wi-Fi phones, and other electronic devices. WPS lets you use a push button or enter a personal identification number (PIN) instead of manually entering a network name (SSID) and password:
  • Push button. The WPS button is either on the product or a clickable button on a wizard or utility screen.
Jan 22, 2013 | Netopia Motorola 2247-n8 Wireless Dsl...
Can't get wnce2001 netgear adapter to work. Also have netgear wnr2000 router. Push and connect, I do have all green lights, but samsung tv states service is unavailable due to network interference.
I have a netgear wnce2001 universal internet adapter. It was previously configured to the wireless internet in home to work with Xbox. Just yesterday the WLAN line went out. Hooked ethernet and USB cable up to computer. Proceeded to the netgear wizard to reconnect adapter to network. Got as for as step 3 and then told that there is difficulty connecting to the existing network. Does anyone have any suggestions to help solve my current problem? How can I reconnect?
Oct 04, 2010 | NetGear Computers & Internet
D-Link DIR-615 Wireless Router Logo
478 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
