Question about GE Lands Phones
My phone is not ringing / no sound. Calls are coming in.....
  • 20 Answers
Increase volume of your phone or restart the phone once...or in the phone settings apply the option restore factory settings...your phone will restart and all problems will end up..
Posted on Mar 11, 2011
4 Suggested Answers
  • 3 Answers
SOURCE: Set not ringing
When you say you are the one responsible for the programming, are you referring to programming the "physical phone" or the PBX and line cards and system functionality?
You should have an extension on your phone. Has that extension for example 222 been translated at the PBX to ring on a direct number -> (xxx) 555-1222
Or by what you are describing, you are more looking at having "shared lines" that ring in multiple locations simultaneously, and once picked up somewhere a "line lock" should be in place?
Posted on Aug 13, 2008
SOURCE: Stop ringing at certian phones when outside calls come in.
http://dstech1.com/programming-line-ringing/
Partner, all releases.
Examples
Receptionist Call Routing. If you want calls to be answered by the receptionist first, set the lines at the receptionist's extension to Immediate Ring and the lines at the users' extensions to No Ring. (This is the factory setting)
Receptionist Backup. If you want all calls on a line to ring directly at users' extensions -with the receptionist providing backup -set the line at the users' extensions to Immediate Ring. Then set the line (or lines) at the receptionist's extension to Delayed Ring. An incoming call that is not answered by a user within 20 seconds will also ring at the receptionist's extension.
Programming
To change the way outside lines or pools ring at an extension:
  1. Press [ Feature ] [ 0 ] [ 0 ] [ System Program ] [ System Program ] [ Central Tel Program ].
  2. Enter the number of the extension to be programmed for Line Ringing. The green lights next to the line or pool buttons on the phone show the current Line Ringing settings for all lines assigned to the extension. (If a line is not assigned to a button, the green light next to the button is off.) The following ringing options can be shown by the green light next to the line button.
    • Immediate Ring - on steady
    • Delayed Ring - flashes slowly
    • No Ring - flutters quickly
  3. To change Line Ringing for any line, press the line or pool button until the button light shows the correct setting (the setting for the currently selected line or pool also appears on the display).
  4. Continue programming or exit programming mode.
Posted on Jan 13, 2009
cnavarro
  • 2460 Answers
SOURCE: The phones won't ring when calls are coming in. The lights on the phone light up but there is no sound
Uh oh, I just saw this. Is it in the main board 101-108 exts, or one of the expansion boards?
Ringing is set 3 ways, by the switch on the side of the phone, by programming, by features. First, make sure the switch is in the ring position and have someone call you on the intercom. If it rings, have someone transfer an outside call to you. If it rings, try dialing 790 on the intercom to reset station features. If none of this works, It's time to look at ring programming. It's done from the system programming mode at the main phone or from a PC. It's program codes 408-410 or section 3.2 from the Maintenance console.
The last ugly thing is it's a hardware failure.
Carl
Posted on Apr 29, 2009
No ring tone......
My Dear Your Phone Ringer Default
So Please change Ringer and Ringin Sound Problem will solved
Aug 24, 2012 | HTC Wildfire Cell Phone
The phone won't ring. How do I make it ring? I have gone to settings, sounds, ringer and alerts. When I click on that, the phone makes a ringing sound, but when calls come in, it is silent. Please...
Have you checked the switch on the top left of the phone?
That's the mute switch. Flip it in the Up position and that should fix your problem
If the phones ringing when you test the ringer in the settings, the ringer works. It's probably just muted..
I hope that helps...
Thank you
Aug 25, 2011 | Apple iPhone Smartphone
My phone is not ringing when I get incoming calls, beeping when I get txts, and it won't go on loud speaker. The volume is high. Its set to normal profile, with ringing volume high. Please advise.
Some how your phone was reset or had the tone turned off. Just follow the below guide and your audio should come back on. I would do a soft reset (turn off the handset, remove the battery then reinsert) before performing the instructions.
Tone settings
To select a ringing tone for voice calls, select Tones >
Ringing tone.
To select a ringing tone for video calls, select Tones > Video
call tone.
To set the ringing type, select Tones > Ringing type. You
can also set the device to sound a ringing tone that is a
combination of the spoken name of the caller and the
selected ringing tone, when someone from your contacts list
calls you. Select Tones > Say caller's name.
To set the volume level of the ringing tone, select Tones >
Ringing volume.
To set the various alert tones, select Tones > Message alert
tone, E-mail alert tone, Calendar alarm tone, or Clock
alarm tone.
To set the device to vibrate when you receive a call, select
Tones > Vibrating alert.
To set the volume level of the device keypad tones, select
Tones > Keypad tones.
I have included a link to download your user manual if needed, it comes as a PDF file so you need to have adobe PDF down loader
http://nds1.nokia.com/phones/files/guides/Nokia_E63-1_UG_en.pdf
Apr 23, 2011 | Nokia E63 Cell Phone
Doesn't ring or no sound coming out when I play music. But when I turn it off and turn on there is sound on the intro.
Hi, the ringer of the phone that makes you hear when someone calls or when you want to listen to music is faulty and needs to be replaced for you to be able to hear it ring when someone calls you and when you play your song.
Take care
May 21, 2010 | Cell Phones
How do I get edge 120 to ring when outside calls come i? Several of our phones do, but a couple of them don't. Can't find anything in the manual about setting a phone to be one of the phones that ring...
you need to goto the mobile settings and scroll to ringtones and select the ringing tone,volume and whether you want continuos ringing or not is there for you to choose.
Jul 16, 2009 | Lands Phones
Stop ringing at main phones when outside calls come in.
Here is a link to program line ringing.
It sounds like your extension is forwarded (confirmed by the one beep you hear on an incoming call.
From any display phone, press Feature 11
then enter your extension number 2 times. So if you are extension 20, do this:
Feature11-20-20
see if that does it.
May 28, 2009 | Lucent PARTNER18 Corded Phone
Carl
Apr 29, 2009 | Lands Phones
Fix phone line
It sounds to me like the phone line coming into your home has a short on it so when someone calls your phone it asts as you have answered it. Report the line trouble to your local phone provider as "RNA" (ring no answer) normal phone trouble ticket terms.
Nov 21, 2008 | Lands Phones
Programming a phone to pick up calls
I need more information. When calls come in, does the triangles appear on the phones you want to pick up? Do you have all the lines on the phones? Is sounds like you want only the "ringing sound" to happen on your phone, but have it appear on the others. Is this correct??
Dec 14, 2006 | NorStar M7310 Corded Phone
Lands Phones Logo
55 people viewed this question
Top GE Lands Phones Experts
Computer Repairing
Computer Repairing
Are you a GE Lands Phone Expert? Answer questions, earn points and help others
