Question about Uniden GMR-325/2 2-Way Radio Walkie Talkie Dual Pack
How do I change channels on a uniden walkie talkie
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Uniden Master
  • 102,366 Answers
Press the channel-up/down buttons. See the items marked 3 and 4 on the illustration in this manual.
Posted on Mar 05, 2013
eradiostore
  • 1654 Answers
SOURCE: Motorola FV200 Walkie-Talkie
Scanning Channels
Use scanning to monitor channels for transmissions or to find someone
in your group who has accidentally changed channels.
1. Short press
MENU until the "Z" appears. The current setting
On/Off will flash.
2. Press either
+ or to turn On or Off.
3. Press the PTT to confirm or
MENU to continue set up.
Here is a link to the manual http://www.motorola.com/mdirect/manuals/FV200_userguide.pdf
Posted on Oct 23, 2008
SOURCE: binatone MR 250 walkie talkie is locked how do i unlock it?
Try holding down the ENTER button
Posted on Jan 13, 2009
AvioriX
  • 689 Answers
SOURCE: oregon scientific walkie talkies
Hi Neil
You can obtain the Owner's Manual (Contains simple instructions) from link below
http://www.expressfix.net/manuals/2WayRadios/OregonScientificTP329
Posted on Sep 06, 2008
  • 4 Answers
SOURCE: BellSouth 1010 walkie talkie receives constant static
you have opened up the squelch - refer to the manual to close and return radio to normal operation
Posted on Apr 30, 2010
  • 10 Answers
SOURCE: Is there a way I can change the channel on my
On the Motorolas you have to press the menu button until your current channel flashes. Then press the plus (+) or minus(-) sign to change the channel. 21 is a great channel and you can get distance on it.
Posted on May 10, 2010
We have three Uniden walkie talkies - two of them have a symbol of a walkie talkie above the channel - these two will not talk to each other - but they talk to the one without the symbol - how do I ge
Sounds like the PL tone is set on the two, with different tones. Go to the menu, find the tone screen, and turn off the tone (or set them all to the same tone). That should fix the problem!
Oct 03, 2014 | Uniden Radio Communications
What is the range of the uniden black walkie talkie gmrs 520
  • Pair of GMRS/FRS 2-way radios for person-to-person communication while hiking, skiing, and more
  • 22 channels (8 GMRS and 14 FRS); wireless range of up to 2 miles
  • Auto squelch function shuts off weak transmissions and unwanted noise at range limit
  • Single call alert tone; automatic power save circuit extends battery life; includes 2 belt clips
  • Each radio runs for up to 48 hours on 3 AAA batteries (not included); 1-year warranty
May 30, 2014 | Uniden Black Walkie Talkie Gmrs 520
What is the condition of the batteries? Try it with new ones and if you still have this issue, you need special equipment to test the output and sensitivity of the transcievers.
Mar 14, 2014 | Radio Communications
My Uniden walkie talkie keeps saying L very time I push a button
You've set the keylock feature on your walkie talkie. From the Uniden manual...
KEYLOCK
ON/OFF Press and hold the call/lock key until the "L" appears. After 1 second, the LCD will return to the channel display. To exit Keylock on mode, press and hold call/lock again. Note: While in keylock on mode, it will still receive transmissions.
Feb 10, 2014 | Uniden GMR-1035-2 2-Way Radio
Uniden walkie talkie says L every time I push a button
KEYLOCK
Feb 10, 2014 | Uniden Radio Communications
I cannot get my bellsouth walkie talkie model 2290 to unlock from a channel
The manual says to press and hold the MODE button for 5 seconds turn on or to turn off the LOCK mode. When locked, it prevents you from accidentally changing channels.
Jan 05, 2013 | BellSouth 2290 Walkie Talkie FRS/GMRS...
How to chang channel
Press the channelscan up or down arrow to change the operating channel (displayed channel number will increase or decrease). For full operating instructions you can download and print the factory guide, at no cost, here:
http://www.uniden.com/pdf/GMR325-2om.pdf
Bill B.
Nov 17, 2010 | Uniden GMR-325/2 2-Way Radio Walkie Talkie...
I took out the rechargeable batteries (replaced with regular AAA)in my Uniden walkie talkies and now one is set for channel 19 and one for channel 6 so they cannot communicate. How do I set the channels...
Press the channel/scan up or down arrow key to change3 the channel on either radio. Need the operating instructions? You can download/print them here:
http://www.banoggle.com/Products/Uniden/manuals/GMR-325-2om.pdf
Bill B
Aug 06, 2010 | Uniden GMR-325/2 2-Way Radio Walkie Talkie...
Only one unit of my Uniden walkie talkie model no 1038-2 works
Check programming. Channel and selective call must be the same on both radios. Check "mic" opening hole on the front case of the radio. The slightest bit of debris blocking this tiny hole can reduce transmitted audio to zero.
Jul 26, 2017 | Uniden GMR1038-2 (7 Channels) 2-Way Radio
Hello i have a Uniden GMR-325 (7 Channels) Two Way Radio that....
Hi Zachary
I predict that you have trouble with only one unit.
Try to find some one with either the same units ( on same Frequency of course) or a receiver that also covers same Frequency and transmit on one GMR then the other to esablish which unit is faulty!
The faulty unit should then become apparent, the buzzing could be caused by transmisson of the faulty unit, check all Antenna connections, even change antennas over on testing as prescribed above,
good luck John.
Apr 05, 2009 | Uniden GMR-325/2 2-Way Radio Walkie Talkie...
Uniden GMR-325/2 2-Way Radio Walkie Talkie Dual Pack Logo
1,512 people viewed this question
Top Uniden Radio Communications Experts
Jason
Steve
eradiostore
eradiostore
Are you an Uniden Radio Communication Expert? Answer questions, earn points and help others
