Question about Hoover Vacuums
I get a wining noise from the vacuum, like it is needing air
    Sergeant:
    Champion:
  • 250 Answers
It sounds like you have a obstruction on the suction porsion of the machine. Take the hose of the unit and see if the noise is still there. If not there is something caught in the hose brush or where the brush attaches.
Posted on Mar 11, 2011
  • Tim Venetis Mar 11, 2011
    If it is not in the hose you have to take the cover off the bottom to see if something is lodged in there.
How to remove red wine stains from carpet?
Get some Oxyclean spray from the grocery and use that.
Aug 08, 2017 | Vacuums
Making a high pitch wine, very noisy with no blockage.
Sometimes there is a tiny speck of dust caught between the top of the canister and the lid. Unlock lid, with a slightly damp tissue wipe around top on canister and then the rubber seal in the lid, dry with dry tissue, put back together, noise should be gone.
Mar 24, 2015 | VAX Appliances 2000 Canister Vacuum
My Sebo vacuum cleaner makes a whistling noise when standing upright
similar to the air relief on my dyson think it is so they don't burn motor up
Feb 17, 2015 | Sebo Automatic X4 Extra Upright Vacuum...
Sebo upright barged hoover- good suction using hose, brush wont turn, sounds fine when running, nasty wineing noise when stopping?? help!! i love my hoover, have checked for bolckages....
The real clue seems to be the brush is not turning, a bad belt is possible or a blockage at that head, if you cannot get the brush moving the rest does not matter.
Dec 03, 2012 | Sebo Felix Classic Bagged Upright Vacuum
I have an eureka capture + pet lover vacuum, I
A high pitch wine may be the sign of a bad bearing. Try to narrow down exactly where the noise is coming from. You may have to remove the brushroll and turn it on without it to see if it could be coming from there.
Jul 17, 2010 | Vacuums
No suction for Kenmore upright vacuum
You have not stated which model vacuum you have. Bipass vacuum have a bipass compartment which is under drive unit. Make sure there are no cracks around housing as this is where you vacuume is created. In order to have vacuum you must have airflow, in assences suction. No air flow, no suction. If the airflow is deverted somehow suction will stop. Your filter, your bag are all sources of air flow. Clog either and you lose suction. Start with loss of air, being cracks in housing,bag or filter
Feb 23, 2010 | Kenmore Vacuums
Loud noise/Sounds clogged
You could have a clogged air filter and vacuum is not getting air to motor. You could have hair and string buildup on ends of roller brush. You can put a vaccum hose over a broom handle to clean it out. Also, check the little elbow of the hose at the bottom f vacuum where it bends.
Aug 28, 2009 | Kenmore 35912 / 35913 Progressive Upright...
The vacuum drive makes a wining sound
Does It make the noise all the time or only when the machine is moving. If it does it only when you push the vacuum that noise is normal. The older Kirby transmissions make a whining noise when pushed.
Mar 24, 2009 | Kirby G6 Bagged Upright Vacuum
Buzzing sound
You ether have an air restriction, or your bypass valve is broken. If it is an air restriction: The motor requires more air flow to stay cool, the noise you hear is an emergency air inlet made to prevent overheating. You may need to use the hepa bag to help increase the air flow. Some hose attachments will cause this to happen, your performance indicator light (if you have one) should also be illuminated if it is an air flow issue. Check your hose for a blockage.
Jan 24, 2009 | Kenmore 35912 / 35913 Progressive Upright...
Loud whistling noise from back of vacuum
On the back side of most kenmore vacuums, there is an air relief diaphragm that, when the motor is sucking but there is no air flow, will pop, causing the sound you heard. check your hose for blockage, check your bag and or filter for blockage,even your attachments/wands can become lodged with debris. Often, after a few, the motor will get hot and the machine will shut down. This is a thermostat on the motor that protects it from overheating. I am quite sure that this will solve your kenmore woes, fine choice in vacuum, kenmore, tried and true. hope to have helped! Have a super, and hopefully sucking(ha ha) Sunday
Jan 03, 2009 | Kenmore 34720 Upright Vacuum
Vacuums Logo
47 people viewed this question
Top Hoover Vacuums Experts
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
