Question about Kenmore Refrigerators
I have a refrigerator that came with my house when I bought it 6 years ago. I'm not sure of the model number. It is a side-by-side with ice maker and I want to change the filter. The water & ice have never tasted good, but the ice is terrible now. I can't find the filter anywhere. I have pulled it out of the wall, looked all over inside and can't locate it. The only numbers I can find are on the back. They are 2181912. I hope you can help me!
  • John Tripp
    John Tripp Mar 11, 2011
    I can help you find the number. On kenmore Side by Sides the fresh food side between door and seal near floor, behind the crisper drawer, door frame or interior walls of freezer or fresh food compartment. Return with the results and the number should be like this example 321.256478 Let me know and we will pick this up where left off, Thanks, Sea Breeze
  • 1073 Answers
SOURCE: Whirlpool Ice Magic-No Frost Refrigerator (I'm guessing 30 years old)
look above the bottom kick plate, on the right middle, or inside the fresh food interior walls been a long time to remember this sweety machine loved it too everything where it was needed to be
Posted on Jun 24, 2008
Arius
  • 446 Answers
SOURCE: Ice tastes bad even after I changed the filter?
allow your ice maker to dispose old water that is still stucked on its hoses, just throw those unpleasant ices's and water would simply replenishes with a a fres and good supply
Posted on Nov 27, 2008
  • 115 Answers
SOURCE: Water not flowing to Ice Maker
take your icemaker back out and take a hair dryer and blow it up the tube probably 10 to 15 mins
Posted on Dec 28, 2008
  • 57 Answers
SOURCE: strange taste in ice cubes
Did you use new water lines? If you did then clear the icecubes from the tray and use an appliance store cleaning solution to wash it out with. their solution is designed for fridge use and wont leave an after taste......Rinse well...... Also for awsome Ice......Install a large in-line water filter.... Makes mine taste like frozen mountain spring water with no nasty taste or smell. Hope it works for ya!
Posted on Jan 04, 2009
  • 78 Answers
SOURCE: Plastic Taste in Refrigerator Water
Hi there, I noticed the same condition when I left the filter in ours a little too long. The optimal performance from the filter is achieved (I have found) when you change it after 3 months. This is about the same amount of time it takes for the light to change from green to red on the filter light.
Hope this helps. ~Steve
Posted on Feb 25, 2009
The water dispenser is not putting out water and ice maker is not making ice. The fridge frequently cycles like it is trying to send out water.
it's still under warranty for up to 1 year,call whoever you bought it from and it should be repaired free of charge and next time you write send model number.
Dec 08, 2013 | Whirlpool 25.6 cu. ft. Side-by-Side...
I have a Kenmore side by side, model # 106.57032601 that I bought 4 years ago. The ice maker suddenly quit working. The refigerator/freezer work fine otherwise and I continue to have water from the...
Is your ice tray filling with water? If not, then I would suspect the water inlet valve (http://www.searspartsdirect.com/partsdirect/part-model/Kenmore-Parts/Refrigerator-Parts/Model-10657032601/0582/0165000/K0607002/00012?blt=06&prst=0&shdMod=10657032601 - Item 10)
If it does fill with water, but does not eject the ice cubes to start a new cycle, I would suspect the ice maker motor(Item 37). BUT if it is the motor, that part costs $91.22 and you can replace the entire ice maker (Item 100) for $157.95
Jul 10, 2011 | Kenmore Refrigerators
We have a Pure Source Plus model, no manual as it came with the house we purchased a year ago. Things worked fine then. A few months ago the water pressure lowered and temp changed(became warmer) for the...
the ice maker slows as the tempt in freezer gets warmer . icw cream get softer ect . ck for ice build up in back of freezer and the evap fan motor may be running to slow causing poor air flow . ck these first . mm
Aug 10, 2010 | Frigidaire FRS3R5EMB Side by Side...
Ice maker stopped working
Here is a tip that I wrote about the reasons why ice makers do not work.
Ice Maker Problems and Ice Maker Troubleshooting
heatman101
98978yi
May 10, 2010 | Whirlpool Gold White-on-White 21.9 cu. ft....
Water icing in ice maker tubing
Replace the water inlet valve . Water is seeping thru the valve when closed . Drops of water seeping thru and freezing inside the fill tube . After replaceing valve , be sure to remove the ice from the fill tube .
Aug 12, 2009 | Amana ASD2526VES Stainless Steel Side by...
Don't know how to make ice
If the refrigerator is the one that came with the house then it should be ready to go after about 6 to 8 hours. Lower the arm inside the ice maker to turn on most types. If there is a switch that should be turned on also. If you still have problem get the model number to me. You can find it near the floor and behind the fresh food compartment door frame. Sears uses a number like
213.25989
Thanks, Sea Breeze
May 23, 2009 | Kenmore Refrigerators
Ice Maker not working
Get me the model number. Put tap water in ice maker tray and make sure arm is down. Let it freeze. Wait and see if the ice will drop, this should allow water to come into the ice maker for another run. Let me know, Thanks, Sea Breeze
Apr 27, 2009 | Whirlpool GS6NBEXR Side by Side...
Ice maker stopped after electric shutoff
You may have a problem with the computer control board in the ice maker.  Try this.  Turn off the icemaker for about 2 minutes.
Turn on the ice maker and press the clear button.  Press and hold this button for 12 seconds to get it to force extract.  This will confirm that the motors will work and push the ice cubes out.  Afterwards, let it run by itself.  If it still doesn't make ice, you will need to replace the icemaker.
Sep 19, 2008 | LG LSC26905TT Side by Side Refrigerator
Refrigerator is making a loid noise
** the y do sound directly related. water is dripping down your ice maker falling on to bucket? well a small amount of water is also falling onto the evaporator fan assy, freezing and the **ise you hear is that fan blade "cutting" through the ice.you can lift the arm turning the Ice maker to the off position, itll stop calling for water,and your **ise should stop as well
Mar 10, 2008 | Refrigerators
Kenmore side by side refrigerator
Check the water valve in back of refrig.. u have a double valve... one side for water the other side for your ice maker.. make sure ice maker valve is working.
Sep 11, 2007 | Kenmore 57029 Side by Side Refrigerator
Refrigerators Logo
165 people viewed this question
Top Kenmore Refrigerators Experts
Sal DeAngelo
dweatherby
paulcarew
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
