Question about Garden
How to replace fuel filter: location of filter
As you look at the tractor from the front, the right side should have the fuel filter eigther connected directly to the carburotor or splitted between two fuel lies. if it is threaded to the carburator disconect the fuel line first using pliers if clamped or wrench if line is threaded. secondly remove filtger from carburator using wrench or pliers if clamped. replace fuel filter in direction marked flow towards carburator. if it is not marked blow through one side of filter if you get air going through it imagine that gas was flowing through there instead and replace according to flow.
Posted on Mar 11, 2011
Where is the fuel filter located?
Fuel Filter
A combination fuel filter/pressure regulator assembly is used, which is located on the top of the fuel pump module.Here's a link on replacing the fuel filter.
Repair Guides Fuel Filter Removal Installation AutoZone com Here's another link on relieving the fuel pressure before replacing. Repair Guides Fuel Filter Removal Installation AutoZone com
Apr 10, 2016 | 2005 Dodge Neon
Feulfilter
For FUEL FILTER details, check the help links mentioned below:---
Where is Fuel Filter Located on 1987 Toyota Camry?
http://whatisbyme.blogspot.in/2012/05/where-is-fuel-filter-located-on-1987.html
2004 GMC ENVOY: Where is Fuel Fill Tube Located?
http://schematicsdiagram.blogspot.in/2012/06/2004-gmc-envoy-where-is-fuel-fill-tube.html
How to replace fuel filter on 2000 holden VT Commodore?
http://technoanswers.blogspot.in/2012/02/how-to-replace-fuel-filter-on-2000.html
These will help.
Thanks.
Dec 06, 2012 | 1994 Buick Century
How to change fuel filter catrige and micro filter on BMW X3
IF YOU HAVE FUEL FILTER WITH FUEL PUMP ASSEMBLY YOU HAVE TO REPLACE FUEL PUMP ASSEMBLY REMOVE THE REAR SEAT BENCH IN ORDER TO REPLACE THE FUEL PUMP ASSEMBLY. NOW IF YOU HAVE FUEL PRESSURE REGULATOR AND FUEL FILTER AS ONE UNIT.BECAUSE FUEL PRESSURE REGULATOR BUILT TO THE FUEL FILTER.TO REPLACE FUEL FILTER, FIRST DEPRESSURIZE THE FUEL SYSTEM BY REMOVING THE FUEL PUMP RELAY LOCATED ON THE COWL.THEN CRANK ENGINE UNTIL IT DIES LACK OF FUEL.THE CRANK ENGINE OVER FEW TIMES TO MAKE SURE ALL FUEL OUT THE FUEL LINES.LOCATION OF FUEL FILTER UNDER THE VECHICLE MOUNTED TO THE LEFT SIDE OF THE CHASIS.
Jul 12, 2011 | 2009 BMW X3
Where is the fuel filter for Mazda MPV V6 3LT petrol filter located
The fuel filter for your vehicle is located on the Fuel Pump Unit, which is located in the vehicle fuel tank. The Fuel Pump Unit must be removed from the top of the fuel tank in order to replace the Fuel Filter.
Feb 27, 2011 | 2004 Mazda MPV
How do i change the fuel filter in my 1985 cadillac deville (gasoline)
FUEL INJECTED ENGINES The fuel filter on fuel injected vehicles may be located in one of two locations. On all 1976–79 vehicles except the Seville, the filter is mounted in the engine compartment near the fuel pump. On the 1976–79 Seville, and all 1980–85 vehicles, the fuel filter is located on the left side of the chassis just ahead of the rear axle. On 1986–89 vehicles, the filter can be found near the frame, in back of the left front wheel. There are two types of fuel filters used on the gasoline fuel injected vehicles, the one-piece disposable inline filter, used on all 1982–86 250 and 1988–89 273 V8 engines, and the replaceable element type filter used on all the other engines. CAUTION
Fuel is under high pressure: if the steps below are not followed, the fuel could spray out and result in a fire hazard and possible injury.
  1. Disconnect the negative battery terminal.
  2. Release the pressure from the fuel system:
    • Without pressure fitting: Cars without a pressure fitting in the fuel line, cover the fitting to be removed with a shop towel while loosening so that fuel will be absorbed. Dispose of gasoline properly.
    • With pressure fitting: Locate the pressure fitting in the fuel line and remove the protective cap. Loosely install a special valve depressor (G.M. tool no. J-5420) on the fitting. Wrap a towel around the fitting to block any spray and slowly tighten the tool until the pressure has been relieved.
  3. Replace the filter as follows:
    1. On the replaceable element type filter; the fuel filter element is replaced by unscrewing the bottom cover and removing the filter element. Replace the element and gasket with an AC type GF 157 or equivalent. Hand tighten the bottom cover.
    2. On the in-line disposable type filter; the fuel filter canister is replaced by loosening the fitting on the end of the filter, then use a pair of pliers to expand the clamp on the other end and slide it down past the point where the hose extends over the inlet of the filter. Gently twist and remove the hose, unscrew and remove the fitting. Remove and discard the old filter. Install the new filter into the hose and replace the clamp. Reinstall the fitting, and check for leaks with the engine idling. NOTE: A dry fuel system on cars equipped with EFI/DFI may require a substantial cranking period before starting. Be sure to crank the engine in short bursts, allowing time for the starter motor to cool between each burst. Fig. 1: Fuel filter location, disposable type — 1986–87 8-250 and 1988–89 8-273 engines 85871013.gif
      Fig. 2: Fuel filter location, sealed type — 8-250 and 8-273 engines 85871014.gif
      Fig. 3: Common fuel filter location — lower right corner 85871093.jpg Fig. 4: Removing the fuel filter hose clamp 85871094.jpg Fig. 5: Removing fuel filter lines — always use a back-up wrench 85871095.jpg Fig. 6: Removing fuel filter mounting 85871096.jpg
Jun 29, 2010 | 1985 Cadillac DeVille
2001 bonneville sle where is the fuel filter located?
The fuel filter is located on the fuel feed pipe, between the fuel pump and the fuel injectors. The paper filter element (2) traps particles in the fuel that may damage the fuel injection system. The filter housing (1) is made to withstand maximum fuel system pressure, exposure to fuel additives, and changes in temperature. There is no service interval for fuel filter replacement. Replace a restricted fuel filter.
Dec 07, 2009 | 2001 Pontiac Bonneville
Just bought a 96 golf. I'd like to replace the fuel filter as the thing was past empty and the engine sputters a little bit. Where is the fuel filter located?
if you have the digifant fuel system.fuel filter is located under the vechicle near the rear axle. the cis fuel system fuel filter is located under the hood on the fuel distributor.you have to remove air filter housing to get to it.besure to relieve fuel pressure before replacing fuel filter.if not gas will spray everywhere can cause fire.gas pressure is very high.
Nov 21, 2009 | 1996 Volkswagen Golf
Where is it located? The fuel filter. My 2003 KIA sorrento will not accelerate up hills. Either hwy or city. On level ground it is fine. Is the fuel filter possible my proble. AGain if so, where is it...
For Kia Sorento 2003-2005 the fuel filter is located inside the fuel tank and is replaced with the fuel pump as an assembly.
Fuel Pump - Removal & Installation
  1. Before servicing the vehicle, refer to the precautions at the beginning of this section.
  2. Remove or disconnect the following:
    Rear seat Access cover Fuel pump electrical connector
  3. Relieve the fuel system pressure.
    Fuel lines Fuel pump and filter assembly
To install:
  1. Install or connect the following:
    Fuel pump and filter assembly Fuel lines Fuel pump electrical connector Access cover Rear seat
  2. Start the engine and check for leaks.
Hope helped with this (remember rated this help) Good luck.
Nov 19, 2009 | 2003 Kia Sorento
The fuel filter (2) is located under the rear of the car, behind the fuel tank. There is no service interval for fuel filter replacement. Replacement is required only if the fuel filter becomes restricted. e37512d.gif
Oct 30, 2009 | 1999 Chevrolet Malibu
Fuel filter location for 1996 honda odyssey
All of the fuel filters with exception of the V6 Odyssey models are located on the vehicle's firewall, in line with the fuel line feeding the engine's fuel rail. The fuel filter on the 3.5L V6 Odyssey is located in the fuel tank and requires fuel pump removal to access. Fuel filters located on the firewall should be replaced if the fuel filter exhibits signs of seepage or corrosion. Always replace a fuel filter and its sealing washers if the fuel system has become contaminated, if the fuel system fuel pressure drops below specification prior to replacing the fuel pump, or whenever the fuel pump is replaced.
Jun 06, 2009 | 1998 Honda Accord
Garden Logo
115 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
