Question about Bissell 1960-3 QuickSteamer Plus Upright Vacuum
My bissel quicksteamer will not stay on when I push the red button.
reddevil6
  • 1673 Answers
SOURCE: I have a Bissell Quicksteamer
Find some shop where you can order a bissell part, 2035617 is the part # for the owner manual. A pdf file is no longer available.
Posted on Apr 20, 2008
whytfang
  • 170 Answers
SOURCE: bissell manual
Sorry this is as close as I could come...but *** covers the Quicksteamer 1970 model...and surely it is the exact same process for yours...as this manual covers several models.....I found it at www.bissell.com.....I hope this helps...good luck and thanks For rating my effort....The Fang
http://www.bissell.com/images/UserGuides/1770_0206.pdf
Posted on May 20, 2009
  • 29 Answers
SOURCE: bissell quicksteamer 1770
The water sprayers on your Bissell are probably clogged. I had this problem this morning, myself, with my machine, about 15 months old. They get clogged up with mineral deposits. This is a *fairly* easy thing to fix yourself. Read all the way to the end before trying this fix. My model is different than yours, but many models are similar.
Unplug the Bissell. Remove the water container pieces from the top of the base. You'll probably reveal two red plastic pieces mounted in the Bissell's base, about .75" x .75". These spray water on your brushes when you press the water-and-soap trigger at the top of the Bissell's handle. These water sprayers tend to clog. See the metal spring running up the hose, behind each red water sprayer? As you squeeze the red plastic sides of one red water sprayer, use a screwdriver or other tool under the spring to wedge up the hose, to release the sprayer from its mount in the base. Stick a finger in the hole of the base of the Bissell where the sprayer was mounted and run it around the edges there including on the underside of the base to clean out any gunk you can find. Clean any gunk you can off the red water sprayer with an old toothbrush.
Now you need to remove the water sprayer from the hose. You need a pair of pliers. Use the pliers to squeeze the brass colored clip that is keeping the red water sprayed mounted to the end of the small hose there. Move the clip down the hose so it compresses the spring and is no longer on the red plastic water sprayer. Now you can twist and pull the red water sprayer out of the end of the hose. You'll need a little hand strength to do this. Just be careful not to break the water sprayer by using a tool. They're not particularly delicate, but breaking one would render your Bissell useless until it was replaced, so use a little care.
When you've removed a red water sprayer from the hose, put the outer end of the red water sprayer in your mouth and seal your lips around it, and try blowing through it. You can't blow air through it, right? It's clogged. Open up a paper clip and push it back-and-forth through the small hole in the end of the water sprayer back towards its middle. You'll probably push out a line of white mineral deposits. Clean them off the water sprayer with the old toothbrush, and try blowing through the water sprayer again. If air passes through clearly, you've fixed it. Now you have to put it back together. Push the water sprayer back on the end of the hose. Use the pliers to reposition the brass clip on the end of the hose over the water sprayer. Push the red water sprayer back into position in the base of the Bissell.
Now do the same for the other red water sprayer.
I had a problem when I fixed this on mine this morning, because when I pulled one water sprayer off, the hose advanced up under the spring and I couldn't reattach the red water sprayer, because it couldn't reach the end of the hose. So try to use the brass clip or some other means (rubber band, tape, another clip) to keep the hose from crawling up inside the spring after you pull the red water sprayer off the hose. If the hose gets up under the spring anyway, despite your best efforts, I fixed this by removing the six screws on top of the Bissell base (the surface of which the water tank mounts on top of), and then pried it up. You can pull out the hose, reattach the red water sprayers to the hoses, position the hose *very carefully* inside the base (there are mounts under there they need to fit into, so you don't break anything), push the red water sprayers through the mount holes and mount them, and then reattach the screws to the base.
There's something else you may need to do that can help get the water flowing. This one's easier. The Bissell uses pumps, which need to be primed. Sometimes an air pocket inside the machine keeps water from flowing. To prime the pumps, separate the two water tank pieces. Fill the base as usual and mount it on the Bissell without the top water tank piece. Plug the Bissell in and **turn it on**. (The Bissell must be running to do this.) Kneeling on the floor in front of the Bissell, reach up and press the soap and water release trigger at the top of the Bissell's handle and hold it in as if you wanted water to go through. On top of the water tank is a plastic grommet hole about 1 inch in diameter, through which you pour water to fill the tank. Seal that hole with the flat of your hand. You'll feel a bit of suction. Lift your hand up and down a few times. Release the trigger and repeat a few times. Now that you've cleaned out your water sprayers and primed the Bissell's internal pumps, I'm hoping water will GUSH through your Bissell once again.
As you probably have learned the hard way, as I did, it's VERY important to do a lot of cleaning of the Bissell after each use, more than the manual tells you to do. Clean the bottom of the unit. Empty all the water. Thoroughly rinse out both water container pieces. Unscrew the three clear plastic pieces, one in front, two on the sides, that surround the brushes, and rinse them thoroughly in water. Clean off the brushes and all the lint and gunk around and above the brushes. (A water spray bottle and toothbrush are helpful here.) Tip the machine and blow all the water out of the hole in the base. Release the red clip springs on the red water sprayers and blow on them. Doing this will slow the failure of the Bissell. It's a great little machine for the money, but it does have a learning curve and need more pampering than a vacuum cleaner, doesn't it??
Posted on May 29, 2009
  • 389 Answers
SOURCE: operating instructions for bissel quicksteamer
Download user manual from the Bissell website
Posted on Feb 14, 2010
SOURCE: I have a Bissel quicksteamer
ours do not have the sucking power it should ????? and the water is is slow to start out plzzzz help ...ant tips will help tu Darrell
Posted on Mar 13, 2011
Why wont my bissell quicksteamer **** up the water?
Hey Kailyn, having no suction is a problem. Here's a quick link to troubleshooting steps to assist you.
http://www.bissell.com/FAQDetail.aspx?id=1092&cid=ccsocial
Jan 12, 2013 | Bissell 1770 Quicksteamer II Upright...
What's your problem? how to replace nozzel for bissell quicksteamer
The User Guide for your Bissell 1770 QuickSteamer can be found here:
http://canada.bissell.com/images/UserGuides/1970-2080_English.pdf
Available replacement parts may be ordered online here:
http://canada.bissell.com/Products/p/1770+quicksteamer/ak/replacementparts/Product.aspx
Was not sure if you meant you were having difficulty with actually removing and replacing the nozzle? Please reply if you need further asistance
Oct 27, 2011 | Bissell 1770 Quicksteamer II Upright...
Need instruction book for bissell model 1770
Information on your Bissell QuickSteamer 1770 can be found here:
http://canada.bissell.com/Products/p/1770+quicksteamer/Product.aspx
The User Guide for the 1770 /1970 Series is here:
Apr 13, 2011 | Vacuums
Need to download PDF format Parts Manual for Bissell 1950-3 Quicksteamer plus -- is there one available?
BISSELL User's Guides can be downloaded at www.bissell.com
On the front page under Customer Service click on User's Guides and enter the model number of your unit.
User Guide will be displayed as a PDF file.
Sep 19, 2010 | Bissell 1950-3 Quicksteamer Plus Vacuum
Where can i order a quicksteamer plus 1950 clean water tank?
I had a look at the Australian variant of this model and located parts number 407-0931 Clean Water Tank.
My best suggestion is that take this part number and contact your local Bissell Service Center, go to the Bissell International website to locate information for your country.
May 26, 2010 | Bissell 1950-3 Quicksteamer Plus Vacuum
Bissell manual
May 20, 2009 | Bissell 1699 ProHeat Clear View Upright...
Ilost the instructions for my bissel quick steamer. I need to know how much solutdion to use and also dthe general use.
HI Try out:
http://www.bissell.com/Product_Search.aspx?Criteria=Bissell+1770+
Click on the right Quicksteamer models (there are two, one green, one blue) and hit up the correct PDF user manual download. Has this been Fixya for you? Please rate accordingly, thanks.
Mar 28, 2009 | Bissell 1770 Quicksteamer II Upright...
Apr 20, 2008 | Bissell 1699 ProHeat Clear View Upright...
Quicksteamer
Below is link to the directions for use for your vacuum: http://www.bissell.com/images/UserGuides/2070.pdf Just download to your computer and view with a pdf viewer or print it. Good luck.
Jun 13, 2007 | Bissell 1960-3 QuickSteamer Plus Upright...
Bissell 1960-3 QuickSteamer Plus Upright Vacuum Logo
Top Bissell Vacuums Experts
Jim Thurston
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
