Question about Sony Car Audio & Video
Hello, I just installed a Sony 250mp stereo into a 94 jeep grand cherokee limited. I have all the wires connected correctly but the stereo only works when the ignition is in the acc position. Once I start my vehical the radio doesn't work at all. Any ideas?
  • 2 more comments
  • 8panama9 Mar 11, 2011
    Thanks, one more thing, I tested the wire which I believe is the right one for ignition. When I role the switch to either acc or start my test probe shows I have power from factory harness to the back of the stereo, it doesn't make sense that it shows power going to the back of the stereo. Theoretically it should be working. Can this still be a wrong wire hook up problem? Or a alarm problem from the jeep itself.
    Ok, so I went and double checked my connections, I have the acc wire connected properly as well as the ign wire, I've checked the diagram countless times and even talked to a rep from scoche industries, the manufacturer of the cross over harness, the connections are pretty cut and dry, I was wondering if it might be the manufacturers security system because when you open the door the radio shuts off.
  • 8panama9 Mar 13, 2011
    Although the advice was sound, I still believe there is more yo my issue. I have the wiring correct. And I still believe it has something to do with the manufacturers security system. Why else would so many issues with lights blinking locks malfunctioning etc keep happening. Again all the wiring is correct.
  • 8panama9 Mar 16, 2011
    Thanks it was very helpful. Appreciate. the Info.
    President:
  • 2,047 Answers
This indicates that there has been a mix up in the wiring. Usually the acc position is when power begins to flow through the entire car system and also the power continues to flow when the car is turned on. But in your situation where the power was tapped from does not supply power when the vehicle is turned on. This happens when the source of the power powers something else when the vehicle is turned on. This could cause serious hazards to your car system if not sorted out properly as this could cause a car fire.
Best way to sort it out is to get an expert to help retrace the entire power wiring of the stereo. If possible get the stereo uninstalled and a fresh installation carried out so all the wires will be in place.
Hope this solution has been helpful?
Posted on Mar 13, 2011
    Top Expert:
  • Sony Master
  • 76,109 Answers
You have the power leads hooked up incorrectly, One lead is the "Keep Alive Memory", that is always hot (battery +), the second power lead is to the ignition on position, it is hot only when the key is turned to run or the truck is running. You will have two wires in the Jeeps stock harness that will be hot all the time and one that will have battery power when the key is turned to run, here are those wire colors, hook them to the corresponding power leads shown in the installation diagram of the Sony radio.
Jeep radio harness colors:
Car Radio Battery Constant 12v+ Wire: Pink
Car Radio Accessory Switched 12v+ Wire: Violet/White
If you have the wires hooked up right then just find a power sources that is hot when the key is in run or accessory at the base of the steering column and tap into it.
Posted on Mar 11, 2011
  • 1 more comment
  • yadayada
    yadayada Mar 11, 2011
    I have done hundreds of stereo installs over the years, and the wiring is always the first problem you look at, please follow my advice, have been doing this for 35 years.
  • yadayada
    The security system has nothing to do with the radio shutting off, it is called delayed exit, this keeps all accessories running until the control module senses the door is open.
  • yadayada
    Find another circuit that is switched by the ignition, then use that for the switched power to the radio, it is the easiest way around this.Make sure the wire you tap into stays hot when the door is opened and that it shuts off when the ignition key is turned off.
Vr3 vrvd630 wiring
This page might help: http://www.jeeppatriot.com/forum/showthread.php?t=7275
And this page will provide you with several pages to visit: https://www.google.com/search?hl=en&source=hp&q=+94+Jeep+Vr3+vrvd630+wiring+diagram&gbv=2&oq=+94+Jeep+Vr3+vrvd630+wiring+diagram&gs_l=heirloom-hp.12...2109.46750.0.48484.29.5.0.24.1.0.94.407.5.5.0....0...1ac.1.34.heirloom-hp..25.4.329.QRoy2DxAm28
Sep 05, 2014 | VR3 CD PLAYER MP3 WMA RDS CAR STEREO...
06 jeep grand cherokee limited stereo screen prob.
all you can do with magic is. (no books)
1: check fuses.
2: check connection.s
Dec 16, 2013 | 2004 Jeep Grand Cherokee
I bought a cd player for my 94 grand cherokee and bought a wiring harness for the speakers. And. I want to kno which colors are the speaker wires
1994 Jeep Grand Cherokee Car Radio Stereo Audio Wiring Diagram
Car Radio Ground Wire: Black
Car Radio Illumination Wire: Orange/Black
Car Stereo Dimmer Wire: Green/Red
Car Stereo Antenna Trigger: N/A
Car Stereo Amp Trigger Wire: N/A
Car Stereo Amplifier Location: N/A
Car Audio Front Speakers Size: N/A
Car Audio Front Speakers Location: N/A
Left Front Speaker Positive Wire (+): Green
Left Front Speaker Negative Wire (-): Brown/Red
Right Front Speaker Positive Wire (+): Violet
Right Front Speaker Negative Wire (-): Blue/Red
Car Audio Rear Speakers Size: N/A
Car Audio Rear Speakers Location: N/A
Left Rear Speaker Positive Wire (+): Brown/Yellow
Left Rear Speaker Negative Wire (-): Brown/Blue
Right Rear Speaker Positive Wire (+): Blue/White
Right Rear Speaker Negative Wire (-): Blue/Orange
google_protectAndRun("ads_core.google_render_ad", google_handleError, google_render_ad);
Dec 11, 2010 | Cherokee Jeep Grand 1994-1995 Radio...
I have a 94 cherokee limited 5.2 v8. which transmissions are come
The 46rh is a hydraulic transmission as where the 46re is an electric transmission. With minor wiring you can replace the 46re with the 46rh but not the other way around. Your transmission would stay in limp mode and wouldn't shift out of 2nd gear. So the answer is no.
Aug 23, 2009 | 1994 Jeep Grand Cherokee
1997 jeep grand cherokee limited with on board amp
try going through jcwhitney and possibly pioneer
Aug 04, 2009 | 1997 Jeep Grand Cherokee
Installing an aftermarket CD player.
Go to a stereo sales & installation shop, or even auto parts places usually have them now too, and get an adapter harness for your particular vehicle. They plug directly in to your existing harness, then you simply wire your new stereo to it,via directions. Few bucks now, will save hours of aggravation later,.and if you decide to sell vehicle later, and put old one back in, it's all there to plug back in, nice & clean.
Mar 27, 2009 | 2005 Jeep Grand Cherokee
I HAVE A 94 JEEP GRAND CHEROKEE PUTTING A PIONEER DEH-1900MP STEREO IN AND WHEN I SHUT IT OFF THE STEREO WONT SAVE THE PRESET STATIONS
the problem is you dont have the battery wire on the radio hooked up to a 12v constant. it sounds like you have to take the battery wire of the radio and hook it up to a wire that stays 12v all the time even when the car is off.
Feb 21, 2009 | 1995 Jeep Grand Cherokee
Car Audio & Video Logo
364 people viewed this question
Top Sony Car Audio & Video Experts
xxxxxx xxx
Larry Stiles
Larry Stiles
Philip Rowney
Philip Rowney
Are you a Sony Car Audio and Video Expert? Answer questions, earn points and help others
